When you add new tracks to the playlist just drop them into your playlist and they will be added
But there is a better way
Empeg has many tricks up it's sleeve
say you have ten albums on your empeg with ten tracks each and out of these albums you have two of your favorite songs on each album. Go into emplode and copy them and paste them into a playlist called favorites so to play your favorite songs you just lay this playlist. This means you have a total of 120 tracks on the empeg.
WRONG you only have 100 tracks as when you copy and paste in emplode you are just creating a shortcut to each track.
This has a huge advantage as it also works with playlists i have my playlists arranged in two ways one is by genre and the other is A to Z so for example REM have an entry under Rock and also an entry under R if fact REM are also listed under my girlfriend playlists. But the cool bit is when you drop a new album into REM under rock it turns up under R as well. But this only works if you upload the tracks once to the empeg and then cut and paste around the playlist structure.
P.Allison fixer of big engines Mk2+Mk2a signed by God / Hacked by the Lord Aberdeen Scotland
