With a bit of careful planning, you should be able to drill a hole into the sled to put a screw into. Get some flat headed machine screws and have the head on the inside of the case, there should be enough clearance.
You will need to be precise with the location of the screws though!
-- Murray I What part of 'no' don't you understand? Is it the 'N', or the 'Zero'?
