That looks like a cool tool!
I saw in another thread that there was some success with getting a Palm to speak TCP/IP to the empeg via IR. After getting a TCP/IP link, has anyone tried to use PalmVNC to connect to the VNC server on the empeg? IIRC, the Palm's IR speed can do 115200 bps, right? The empeg's 128 x 32 screen has 4096 pixels, but at 2 bits each fits a whole screen into 1024 bytes (uncompressed). That means that without compression, the 8192 bits could be updated 14 times per second! Drop it down to 10fps to allow for some VNC, TCP & IP protocol overheads and it'd still be decent. With compression, you could get a higher frame rate, but the Palm may not be able to keep up with that.
Thoughts? Is the Palm fast enough to display visuals from the empeg?
