Tony,
I just did a test for RAM in Hyperterminal I have pasted the output below:
0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0212 drq=1 but irq=0 (no drive connected?)
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 32
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
And here is the output from hyperterminal for boot up:
01f0 ram test done
0200 ide detect
0210 command issued
0300 dsp/i2c test
03f0 dsp/i2c ok
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the ker
nel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v285 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Fri Jul 26 11:13:49 EDT 2002
empeg-car player (hardware revision 9, serial number 10101980)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: probing with STATUS(0x50) instead of ALTSTATUS(0xff)
hdb: IBM-DJSA-230, ATA DISK drive
hda: probing with STATUS(0x50) instead of ALTSTATUS(0xff)
hda: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:b
c
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Comp
þStarting player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
Do you notice anything unusual?
It is funny, when I left work I put it in the car and it booted OK. Then about 2 minutes later it squealed and froze up again. then I pulled out the unit and reapplied power. It started to boot but got stuck on the logo screen. Now I am at home and it boos right up. I am very frustrated right now. I was hoping that I could get a hang while booting up so I could captureit in hyperterminal.
Dave
MK2 12Gb
MK2a 60Gb
