#127099 - 19/11/2002 19:48 What TV?
Well it has been time for a new TV for quite a while, and the $50 coupon in Sunday's Best Buy flyer pushed me over the edge.
It is pretty much down to two TV's, but I'm open to suggestions.
Sony 27" WEGA KV-27FS100
Toshiba 27" 27AF42
Spec. wise and price wise both TVs are almost identical, give are take $20 and an input. And both are a hugh step up from the current 13" Toshiba.
Any opinions on which will be the better TV? It will be paired it with a same brand DVD player and, once they come out, a Series 2 Directv TiVo.
Help!
#127100 - 19/11/2002 20:05 Re: What TV? [Re: Phoenix42]
visuvius
The WEGA all the way. You will not be dissappointed. I'm not big sony freak or anything, but that is a kickass tv.
Also, when i used to work at the Good Guys, we got like 0 returns on WEGA's as compared to, well, more with Toshibas. We never had open box wega's, and the one time we did, i bought it. The Toshiba isn't a bad set, however, IMHO, the Sony is a better set.
#127101 - 19/11/2002 20:17 Re: What TV? [Re: visuvius]
genixia
Didn't you mean "We very rarely had...." ??
#127102 - 19/11/2002 20:22 Re: What TV? [Re: Phoenix42]
matthew_k
I'm not a sony freak either, but I'd recomend the wega too, as far as reputation they're the best out there. I've got one of the 24'' ones, and it's been great so far.
As I've been starting down the road of unviersal remotes this week, I've got to recomend making sure everything you buy has "discrete codes" available. For those who don't know what they are (me, 48 hours ago), they're remote codes which perform one action instead of toggling a state. A seperate code for power on from the code to power off, for instance. The other example is selecting inputs. This will make macros which can actually perform valuble functions possible. I got a ReplayTV this weekend, and I'm learning the immense value of JP1 enabled remotes, even though I havn't built the interface cable yet.
Good Luck, and enjoy the new TV.
#127103 - 19/11/2002 20:37 Re: What TV? [Re: matthew_k]
oliver
i got a 32 inch wega shortly after they first came out, and it sucked. I had 3 of them, they all sucked! it took sony over 9 months to finally give me my $1500 back! I'll list the problem that i can remember the tv having.
1. the picture was tilted, but not the whole picture just from the center of the screen to the right, really annoying when you spend $1500
2. when watching a dvd, and sometimes when watching tv, there would be a green bar like 4 inchs wide scroll from left to right! wtf is that about?!?!?
3. the tv weighs like 150+lbs! its huge 32 inch, and has like no handles to carry it. and i live in the second floor of a house built in 1900 with a staircase in a U. and carrying those 3 tv in and out of my house to the store/repair shop sucked. in the middle of winter no matter. On one of the returns back to the shop, after we loaded it into the van. i took the first turn... and BAM! i thought the tube broke.... tv was now sitting flat (tube down) in the van (was upright ) but the case was just cracked they didn't even notice it was cracked, but it was pretty bad, we put a sticker over it .
Anyways, that my sony story. and i'm still looking for a tv. a buddy of mine is going to get that exact Toshiba tv. i like it alot!
#127104 - 19/11/2002 21:14 Re: What TV? [Re: Phoenix42]
dcosta
Loc: Massachussetts
http://www.bestbuy.com/detail.asp?e=11101060&m=1&cat=24&scat=1470
It's a bit more expensicve,
but you get quite a bit more tv for $200 extra
if $200 extra is a deal breaker, perhaps $50 extra is better for this:
http://www.bestbuy.com/detail.asp?e=11161137&m=1&cat=24&scat=27
It's same Sony you looked at only it has 2 tuner PIP and an extra set of AV inputs on the rear...
... definately worth the $50 upgrade IMHO
Edited by dcosta (19/11/2002 21:18)
__________ davecosta Hijacked 60GB MKIIa 2.0b13
#127105 - 19/11/2002 22:13 Re: What TV? [Re: Phoenix42]
Happy Birthday Dignan
My parents have a 30" WEGA, and it's got such amazing quality. I really wish I had a TV like that.
Oliver, I'm not sure why you've had such bad experiences. I didn't quite understand you, did you say you've had the same malfunctions on 3 identical sets? That seems like a very odd thing to happen.
#127106 - 19/11/2002 22:55 Re: What TV? [Re: Dignan]
oliver
Yes, actually the first wega only had the screen tilted.
The Second tv had the tilted screen, and the green bar scroll from right to left all the time.
The Third had the tilted screen, green bar mostly on video 1 or 2, almost never in tv/tuner mode.
All of the tv's had a hard time showing true black, it was always grayish. I had the first one sent into a sony repair shop, 2 weeks later when i got it back, it was 10x worse than it was to begin with. I had probally about 5 different sony techs come to my house to mess with the hidden setup menu, each time they only made the problem worse!
#127107 - 19/11/2002 23:04 Re: What TV? [Re: oliver]
Interesting. With all of those repeated faults on multiple TV's, I'd suspect environmental.
This was on different sources or always the same source? With the TV's installed into the same spot each time? And did other brands of TV installed into the same spot with the same source have zero problems?
Seems really strange to have that many egregious defects in three different TV sets.
#127108 - 19/11/2002 23:04 Re: What TV? [Re: oliver]
Neutrino
Not to de-rail your search for a TV but what ever happened to front Projectors?The ones you mount on the ceiling and view on a screen?They seem to have lost popularity.
#127109 - 19/11/2002 23:08 Re: What TV? [Re: Neutrino]
They are alive and well. The highest-end home theater systems are all done with front projectors.
A properly-done front projector system is more expensive and tougher to install/maintain than the new crop of rear-projectors, so for the midrange installations, rear-projectors have the biggest market share for highdef and widescreen DVD home theater systems.
#127110 - 19/11/2002 23:57 Re: What TV? [Re: genixia]
visuvius
yeah i suppose that is more accurate. But, the majority of the returns were for the 13" WEGA's; I don't really count those. I never got a return on any of the 24's or 27's. And i think i can remember one return on the 32", never on the 36's.
#127111 - 20/11/2002 00:12 Re: What TV? [Re: tfabris]
oliver
I tested the tv with my sony dvd player, a friends toshiba dvd player and my tv output card in my computer. I plugged it in 3 different spots in my house. I tried endless amounts of rca+video cables, s-video cables, the 3 video rca connection.
The repair shops hooked up many different video sources, and they all displayed the same problems.
#127112 - 20/11/2002 00:39 Re: What TV? [Re: Neutrino]
Waterman981
Loc: Salt Lake City, UT
-Michael
#040103696 on a shelf
#127113 - 20/11/2002 02:43 Re: What TV? [Re: Phoenix42]
I notice neither are widescreen. Are you guys is the US still not buying widescreen, i.e. 16:9 ratio, screens ?
#127114 - 20/11/2002 07:23 Re: What TV? [Re: andy]
lectric
Loc: New Orleans, LA
I just helped a friend hook up his widescreen. Beautiful picture. Unless you count the fact that everyone on the screen had gained 30-40 pounds. You COULD watch it in stretch mode, where everything was the right proportion, but then everything was missing the top and bottom 1/8 of the screen. So watching ANY sport was out of the question in that mode. Or you COULD use letterbox, which puts these big gray bars on either side of the screen, but the manual tells you not to do this, or you could burn in the bars fairly quickly. I think I'll wait till more things are broadcast in widescreen. And out of curiosity, WHY WOULDN'T THEY MAKE THE BARS BLACK?!?! There could be no burnin then. It just makes no sense to me.
#127115 - 20/11/2002 07:47 Re: What TV? [Re: lectric]
Thankfully in the UK almost all new programming (including stuff produced in the US) is in widescreen now.
I have never seen a widescreen TV that adds grey bars when running in 4:3, that's just plain bizarre.
P.S. how can some people who have widescreens not tell when they have the apect ratio set wrong. I keep finding people who say "widescreen is crap". Then I take a look at their setup and they have:
- set their set top box or DVD player to output 4:3 instead of 16:9
- set their TV to stretch the 4:3 picture to 16:9
Mad as a box of frogs...
#127116 - 20/11/2002 07:50 Re: What TV? [Re: andy]
g_attrill
Loc: Hants, UK
I noticed that most US TV programmes are 4:3 - eg. CSI, Buffy. I have heard a lot about HDTV - considering most effort is going into getting that in the marketplace the US is not going for 16:9 at all?
I made an impulse purchase of a Turkish made unbranded 16:9 from Sainsbury's a few weeks back - cost £229 and it is pretty good, certainly not Wega quality and the speakers are very bad but the screen is reasonably straight edged and flat. It could blow up in a few years and I won't be annoyed - it is a huge step up from a 14" 4:3!!
Gareth
(getting the thing home was fun - had to unbox it and strap it in the front seat of the Caprice!)
Gareth
#127117 - 20/11/2002 07:52 Re: What TV? [Re: lectric]
djc
Loc: chicago
if the bars were black, the phosphors in those regions would not be "exercised" while watching standard 4:3 video. you really want all of the phosphors across the screen to wear evenly, for those times when you do watch 16:9 sources. otherwise, over time, those areas where the black bars were would appear brighter than the rest of the screen.
--dan.
#127118 - 20/11/2002 08:06 Re: What TV? [Re: djc]
lectric
Well then make them a different shade of grey or something. They HAVE to be able to do SOMETHING.
#127119 - 20/11/2002 08:16 Re: What TV? [Re: andy]
g_attrill
Loc: Hants, UK
A lot of people with w/s TV's are still using terrestrial signals and switching the 14:9 letterboxed picture to 16:9 mode - some TV's (like mine) don't have 14:9 zoomed mode so are pretty much useless without a decent source. There is/was a thing called "PALPlus" which made TV's switch to w/s automagically but I don't know if it's still used.
Gareth
#127120 - 20/11/2002 09:19 Re: What TV? [Re: Phoenix42]
Hmmm....well several votes for the WEGA, and one for the Toshiba.
dave costa, you are right in saying that for the extra $50 you do get some wort while stuff. But PiP does not appeal to me, I just don't watch that much TV.
But keep the advise rolling people. I still need a matching DVD player, and is there any point in getting a Progressive scan DVD player with either of thoes TV? Bear in mind this will be the main TV and I won't be jumping to get a HDTV set when they hit the shores. Granted the price differance between Progressive scan and thoes with out is pretty narrow...
Thanks guys.
#127121 - 20/11/2002 09:35 Re: What TV? [Re: Phoenix42]
jbauer
Loc: San Francisco, CA
I bought a 36" Wega when it first came out, had all kinds of problems with it - mostly with the geometry of the picture. After repeated visits by Sony and several hours of complaining and climbing their corporate ladder until I spoke with a VP, they replaced it with the next years model. I now have the KV-36XBR250 and I love it. Especially for the anamorphic squeeze mode, which hasn't yet been discussed here.
I'm now thinking, though, of upgrading to a 16x9 HD tube set...
- Jon
#127122 - 20/11/2002 10:11 Re: What TV? [Re: andy]
Widescreen TVs exist, but until very recently they were waaaay more expensive than 4:3 TVs.
I recently purchased a TV that supports HD (the 16:9 format in the US, which has some, but not much, usage), and I got one that has a 4:3 glass tube, but will switch to 16:9 if it sees an appropriate signal.
#127123 - 20/11/2002 11:31 Re: What TV? [Re: wfaulk]
Just get a plasma display...then you don't have to worry about letterbox burn-in or exercising phosphors...
#127124 - 20/11/2002 11:37 Re: What TV? [Re: JBjorgen]
Funny. A company I used to work for had a plasma display that, when not in use, displayed our company logo, since it wouldn't burn in. Guess what? It burned in. Made for a nice watermark on presentations, though.
#127125 - 20/11/2002 11:44 Re: What TV? [Re: JBjorgen]
Ezekiel
Loc: NH USA
...or that pesky extra $3000 in your pocket.
-Zeke
WWFSMD?
#127126 - 20/11/2002 11:45 Re: What TV? [Re: wfaulk]
ah...I speak as a fool then!
#127127 - 20/11/2002 12:10 Re: What TV? [Re: Phoenix42]
TheRhino
Loc: Aurora, CO
I've owned a 36" Sony Wega Flat Screen for 3 years now, and have had no problems with it - except for the fact that it weighs 2 trillion pounds (a rough estimate).
Rhino
[color:"blue"]Rio MKII 60GB Blue[/color]
[color:"orange"]empeg MKII 50GB Amber[/color]
#127128 - 20/11/2002 12:13 Re: What TV? [Re: JBjorgen]
Well, not really. Everyone says they won't burn in. It's hard to fly in the face of that. But my first-hand experience says otherwise.
