#129956 - 09/12/2002 22:24 Another Cheap PC
I'm trying to put together a cheap PC for my roommates. They each need a new one (one of them desperately), so I've been looking at options.
I want to keep it really really cheap. Like in the $300 range, which is entirely possible.
I'm thinking this mobo that Rob linked me to. Then I'm suggesting a lower end XP processor like the 1600+. That's up to about $110.
Then all I need is a cheap case/PSU, 256MB memory, and possibly a hard drive. Oh yeah, and a video card. Hmmm. I'm seeing this going over $300. but I'm sure that's fine.
Any suggestions?
#129957 - 09/12/2002 23:25 Re: Another Cheap PC [Re: Dignan]
robricc
Check out this machine I built a couple months ago based on the Asus A7N266-VM nForce motherboard. It was designed to be very inexpensive while still giving good performace and quality. Most components were bought at newegg. The customer has not had a single complaint, so all is well....
#129958 - 10/12/2002 00:05 Re: Another Cheap PC [Re: robricc]
ragoopumpkin
Try checking www.gotapex.com. They have a dell posted for $350 including free shipping. Not a bad system. I picked one up a couple weeks ago for $364 after tax with 256mb and a 40x burner.
#129959 - 10/12/2002 06:32 Re: Another Cheap PC [Re: Dignan]
http://www.techbargains.com/news_displayItem.cfm/17422
has some more details on the offer ragoopumpkin mentioned
Rob, can you post more details on that budget box you built? or is it just the motherboard, CPU, Ram, modem & case?
#129960 - 10/12/2002 08:29 Re: Another Cheap PC [Re: Phoenix42]
robricc
It had a burner and hard drive as well, but that's about it. I did not provide a monitor. I eneded up charging just under $400 (no profit) and the thing was quite fast. I naturally used the onboard sound, video, and NIC.
#129961 - 10/12/2002 08:44 Re: Another Cheap PC [Re: Dignan]
I don't know exactly what you're looking for, but have you considered those cheap WalMart PCs?
#129962 - 10/12/2002 12:28 Re: Another Cheap PC [Re: wfaulk]
Those are a little too cheap, I think. But I'll look at them again.
I've never been straight on this, what is different in a Celeron?
Thanks, guys, for your suggestions.
#129963 - 10/12/2002 12:40 Re: Another Cheap PC [Re: Dignan]
Mostly, it's got a smaller built-in L2 cache.
#129964 - 10/12/2002 13:42 Re: Another Cheap PC [Re: wfaulk]
and a slower front side bus
or does this apply to the current celerons?
#129965 - 10/12/2002 13:55 Re: Another Cheap PC [Re: Phoenix42]
Correct. Celerons have generally been one step below the high end processors for FSB speed. Current Celerons that fit into Pentium 4 boards run at 400mhz FSB, while the modern P4 chips run at 533.
In the past, raising the speed of the FSB was an easy way to overclock the Celeron and get good peformance boosts. But due to other crippling that Intel has done, a Celeron will not match a P4 of the same speed. (Unlike the Celeron 300A glory days).
#129966 - 10/12/2002 14:02 Re: Another Cheap PC [Re: drakino]
My main machine at home is still a Celery 566 OC'd to 850 with just a regular fan. I've been playing with the idea of getting an upper level XP, but haven't gotten around to it yet.
#129967 - 10/12/2002 14:06 Re: Another Cheap PC [Re: drakino]
The slower current P4s have the same FSB speed as the Celerons, IIRC. But the faster ones have a faster FSB.
#129968 - 11/12/2002 00:35 Re: Another Cheap PC [Re: robricc]
Thanks guys for the tips, but I'm just going a different direction. I do want to build them a good quality machine, and I'd like to avoid the Celerons and Durons if possible. It's okay to have lower speeds, because they can always upgrade later. I mean, look how long it's taken them to get a new PC this time.
So I'm probably going to go with the mobo I originally mentioned. Then I'll probably also try the cheapest 1500 or 1600 Athlons. After that, I need help on these things, and if you can find good ideas that might be sold at Newegg, that would be great too:
-video card
-hard drive
-case/PSU
-memory (256 at most)
-possibly a monitor for one of my roommates **
Again, I'd like inexpensive, but not cheap on quality. Looking forward to any advice.
**what does it mean when you turn on a monitor and for the first minute or so that it's on, everything is an orange hue, then it slowly goes normal? I'd call it a crappy Gateway, but what would you?
#129969 - 11/12/2002 06:27 Re: Another Cheap PC [Re: Dignan]
Ezekiel
Loc: NH USA
I'd call it normal warming up for a lower-cost monitor. The Dell 17" monitors we have at the office (well, not _me_) are really slow to warm up, 30-40 seconds. They just slowly fade in from black. My Viewsonic EF70 17" and LG Studioworks 995SE 19" snap right on. A minute would drive me nuts.
-Zeke
WWFSMD?
#129970 - 11/12/2002 06:47 Re: Another Cheap PC [Re: Dignan]
robricc
If the computer that monitor goes with is still under warranty, Gateway will replace just the monitor with no problem. I once owned a Gateway Pentium 75 (shudder) and it came with a 15" Trinitron tube. A couple months before the warranty was up on the machine, which was now disassembled, the monitor started whining. I called up Gateway and they sent me a newer model Trinitron a couple days later with return instructions/labels for the busted one.
I was very impressed with their service.
#129971 - 11/12/2002 10:36 Re: Another Cheap PC [Re: robricc]
That does sound like good service. I'm sure his is not under warranty, I think it's in it's 4th year of existence.
Unfortunately, he hates Gateway. He has one of those desktop/tower thingies that comes with a little stand. Unfortunately, it's so thin that when he got a new graphics card for Christmas one year, it wouldn't fit inside the case. So it's just been sitting in his room for a year or two. That sucks.
#129972 - 11/12/2002 12:45 Re: Another Cheap PC [Re: Dignan]
genixia
Memory - stick to a reputable manufacturer such as Crucial (who are very reputable, and available at newegg or direct from www.crucial.com)
HD - you're going to have to read around a bit. Every HD manufacturer has had horror story series of drives... As long as you avoid those particular series, there's not much in it IMO. Go for the cheapest big-name (are there any others??) branded drive in your desired capacity. You might want to consider 5400rpm drives for cost efficiency - seek times are slightly longer, but bandwidth should be comparable.
Vid card...What's the intended use? Office, gaming or AV? Do you require DVI output (ie, do you have/intend to buy a flat panel monitor). This is probably where your greatest additional cost or saving will be made, so decide carefully..
Case/PSU. It's still hard to beat Antec for a case/PSU combination in terms of quality and value. I'd avoid 'no-name' brands, especially for PSUs.
#129973 - 11/12/2002 12:56 Re: Another Cheap PC [Re: genixia]
I saw vpr Matrix drives at my local BestBuy a month ago or so. I'd never heard of them before, but maybe I'm out of the loop. Looking at their web site, they look like they're probably rebranded WD drives, which is odd considering BestBuy also sells WD.
#129974 - 11/12/2002 13:02 Re: Another Cheap PC [Re: wfaulk]
robricc
vpr-Matrix is a Best Buy-only brand. So, I would assume it's like CompUSA branded hard drives. Once you open the CompUSA box, there is a Maxtor drive inside.
Other than that, the only non-big name brand hard drive is probably Samsung. Not that they're a small company, but you don't assosciate them with hard drives. Before that was JTS (Atari), but I have not seen a drive from them in years.
#129975 - 13/12/2002 15:16 Re: Another Cheap PC [Re: Dignan]
tracerbullet
Loc: Minnesota
I like that board, in fact I just picked one up from Newegg for a machine for my sister for X-mas. The built-in audio and ethernet save a few bucks. The RAM option (SD or DDR) also really helps, I picked up a pair of 128MB Kingston sticks from Best Buy for $9.99 each. SDRAM's on sale everywhere right now it seems. I ordered a chip from TCWO (Thompson's), always had good luck with them as well as with Newegg. Duron 1.1 was about $35 shipped. Of course depends on the app if you want to spend for the XP (my sis is just going to do college papers on hers).
Just wanted to put my vote in for that being a fine board for the price.
#129976 - 13/12/2002 15:41 Re: Another Cheap PC [Re: tracerbullet]
Thanks for your input. Glad to hear that everyone has had no problems with this board.
I have another question. It's very difficult to find a decent cheap monitor. What would you suggest in 17" or better?
#129977 - 14/12/2002 10:28 Re: Another Cheap PC [Re: Dignan]
The monitor is the one thing that you'll keep and use as long as it works properly, so, unless you can find one for next to nothing, I'd say not to cheap out on it. Samsung seems to have the best quality and lowest price combination right now from my perspective.
#129978 - 15/12/2002 11:48 Re: Another Cheap PC [Re: wfaulk]
I just bought a Samsung VGA panel for my parents. I'm using it right now as I've yet to deliver their machine. The whole machine was built quite cheaply as well. I went the Celeron route for them and built on an Aopen MX4B (MicroATX) mobo in an Aopen H340 slim desktop case. Had to use a low-profile video card but everything else (LAN, sound, etc..) is built into the mobo. 40GB IBM drive, 256MB of DDR RAM (too bad I wasn't paying PC133 prices).
They've yet to see the system but I'm sure they'll be happy with it. Everything's black to match, including keyboard (Compaq with 7 extra top soft buttons, USB) and mouse (logitech optical - had to pay a premium to get it in black - MS optical is nicer and cheaper, IMO)
And for myself, I've built a cheap, but not so cheap, Shuttle system (SS51G) - my living room/TV system. It'll probably have a RADEON 9700 All In Wonder in it when done (using built-in SIS right now). I'm really pleased with the whole Shuttle experience - I've become extremely tired of the mid-tower format.
#129979 - 15/12/2002 12:28 Re: Another Cheap PC [Re: hybrid8]
JeepBastard
Loc: Brooklyn
I went with the shuttle as well, YOu can put together a good shuttle for about $500 and lower.
I went with about $600 for a shuttle box and motherboard, 512 megs ram, and a 2.4 ghz pent.
I actually added some more cost by buying a new 80gb HD with 8meg cache that really makes it fly, its really quiet too.
Future mods coming this week is maybe the glowing front face, a TDK 52x burner , a Wireless (D-link) PCI card and a matrox triple head parhelia card.
The onboard 5.1 audio and video is excellent for games and other stuff
YOu still get one agp slot and one pci slot for anything else
with oodles of usb and firewire ports as well as network connection
www.shuttleonline.com
(follow the reviews link fr tom hardware review.
Im never ever getting a tower again
my current blog
#129980 - 15/12/2002 17:28 Re: Another Cheap PC [Re: JeepBastard]
Yeah, I've been looking at the shuttles a lot in the past few days. I was designing a system for my girlfriend, and have been quite fascinated by the whole design concept of the Shuttles. Unfortunately, yes the price would be around $500, but that's also without a monitor, keyboard, and mouse. For her she would need those things because we would be replacing a laptop.
I wouldn't get a Shuttle for myself as my main machine. Too small for the man who owns a Lian-Li PC75. Sort of like polar opposites.
#129981 - 15/12/2002 18:05 Re: Another Cheap PC [Re: Dignan]
Laura
Loc: Greenhills, Ohio
I'll have to read about the Shuttle. My daughter is going to buy a computer after Christmas and is looking at HP's and I'm trying to steer her away from them. Her boss is going to be paying half and it will be used for her work and her husbands business. I would enjoy building her a nice computer. She wants to keep it around $1300 including a new printer and monitor.
Laura
MKI #017/90
whatever
#129982 - 15/12/2002 19:16 Re: Another Cheap PC [Re: Laura]
JeepBastard
Loc: Brooklyn
It knocks those clumsy towers out the box. It has tons of inputs and outputs and it's quiet. Why would you want a huge noise tower? Espectially if you never use more than 1 PCI slot. You can save a lot of desk space.
Everyone who sees mine wants one. It's the best.
my current blog
#129983 - 15/12/2002 19:21 Re: Another Cheap PC [Re: JeepBastard]
Laura
Can I ask exactly what you bought and where you got it at? And you said you spent about $600 on it right?
Laura
MKI #017/90
whatever
#129984 - 15/12/2002 21:02 Re: Another Cheap PC [Re: JeepBastard]
tracerbullet
Loc: Minnesota
Hehe, I'd love one of the shuttles as well, but I'm me, and... I have a RAID board jammed with devices, and need my tower! I have every PCI slot used, plus some of those metal pieces that fit over the PCI-slot-holes (the case has more holes than the board has slots) with connections from the motherboard. Add some switches, variable fan speed pots, etc. along the front, and I love the big case. Of course, it's slid under the desk, so it doesn't really matter what size it is.
I was looking at a shuttle for a multimedia PC for the living room, but figured instead of that, I might as well just get some long cables and run things off the server in the basement. It's already made, relatively unused, and already paid for (the server hidey-hole is underneath the living room and running a wire would be easy here). Video up to the TV, sound to the stereo, and perhaps a KVM switch to extend a mouse and keyboard.
Also - I know you know, but just have to say - size does not equate to noise. I have a low-noise Antec power supply, two Panaflo's for the case (that I very well might not even need), and a variable speed YS-Tech fan over a huge Thermalright heatsink. When the heat or A/C turns on in the house, the airflow out of the vents is louder than this tower is.
My next acquisition in that area will probably be a year or two off - and it will be the baddest-assed laptop you ever saw
#129985 - 15/12/2002 21:37 Re: Another Cheap PC [Re: tracerbullet]
I'm with you, man. Well, not entirely. I don't have my case nearly full at all, but I still love it. In fact, I just have 2 PCI cards and a couple of CD drives.
But you're right about disk drives. I'm planning on putting a 3rd hard disk in and that's something you just can't physically do with the Shuttle. I think it's cool and has it's place, but I love my beautiful silver tower. Plus, the neons inside are nice
#129986 - 16/12/2002 07:14 Re: Another Cheap PC [Re: tracerbullet]
revlmwest
Loc: Hartsville, South Carolina for...
Let me introduce you...
Michael West
#129987 - 16/12/2002 13:32 Re: Another Cheap PC [Re: JeepBastard]
Sorry, did I say I had only 1 shuttle? http://space-simulator.lanl.gov/
To make the Shuttle even quieter (it's not that quiet actually) you can replace both the main and power supply fans. If you're at all interested in Small Form Factor PC's, you must check out the forums at http://www.sudhian.com
I've got two HDs in my case right now. a 60 and 20GB. The 20GB will likely get replaced with an 80 or larger at some point. This is going to be a movie machine and PVR. I suppose with a 9700 in it I should also play some games or something...
I should start another thread. I need to know some good titles that will play well with any of the following: gamepad (analog or digital), digital joystick (old-style WICO/arcade), wireless keyboard with IBM-style pointer thing.
BTW, the mod I'm doing right now s to stealth the optical drive (look sit up on the sudhian SS51G FAQ page).
#129988 - 16/12/2002 16:31 Re: Another Cheap PC [Re: revlmwest]
tracerbullet
Loc: Minnesota
Oh yeah, Area 51... I know about that one. I guess what I'm implying is that for me to be able to afford it! is about a year or two off. At that point my main machine will likely become a server, I'll sell the current one to a friend for cheap, and then I'll get the ultimate laptop as my new main unit.
Wow, I knew about that one, but forgot how cool it was *drools*.
#129989 - 16/12/2002 17:30 Re: Another Cheap PC [Re: Laura]
JeepBastard
Loc: Brooklyn
Yes.. but i put it together myself from parts from http://www.newegg.com
I think places like http://www.tigerdirect.com have it already assembled kits. You may have to do a little foot work on that. It's still new, but I know shuttle signed a deal with either dell or compaq to bring them to market next year.
If you know how to put together a PC or can find one assembled already, you will beat the crowd. Do a search on google for shuttle XPC and i think a few will come up that are already assembled.
Mine is extremely quiet, pretty much stock. THe modern hard drive I think helped a lot. It's right here on my desk and sometimes I don't hear anything. Especially since the fan regulates its own speed.
$327 Case/motherboard
$329 for 512MB ddr 333mhz xms cosair Ram & 2.4 Ghz Pent 4
thats just under $700 for almost topof the line stuff.
my current blog
#129990 - 16/12/2002 17:42 Re: Another Cheap PC [Re: JeepBastard]
Laura
It's more fun building them then buying them already put together. I'll run the idea by her this weekend. I would still have to add a hard drive, dvd player or cd-rom, monitor and printer to the $700 but that would put it around $1300 so maybe that would be ok. Wish I could afford to build a new one for myself.
Laura
MKI #017/90
whatever
#129991 - 20/12/2002 06:32 Re: Another Cheap PC [Re: Laura]
mardibloke
Loc: Penarth, UK
Sure is lots of fun building, I have the mini-itx bug, running 3 around the house already ( sigma Xcard is handy for the TV based PC ), with an M9000 waiting for a case.
Rod, UK
#129992 - 20/12/2002 07:46 Re: Another Cheap PC [Re: mardibloke]
I like how that mobo is so small they had to make the lithium battery vertical to make it fit.
How well does this thing output video? My AIW card does it only fairly.
#129993 - 20/12/2002 08:49 Re: Another Cheap PC [Re: JeepBastard]
For what it's worth, you can configure a Dell OptiPlex GX260 small form factor or an SX260 with a low-end Celeron CPU for around $700 (no monitor) and then spend another $900 on the 20" flat panel display of doom. If silence matters more than oomph, these machines are hard to beat. Of course, you ge tempted to say "well, how about a larger hard drive, and a CD burner, and a faster CPU .." and next thing you know, you've added another $1000 to the machine.
#129994 - 20/12/2002 09:03 Re: Another Cheap PC [Re: Dignan]
mardibloke
Loc: Penarth, UK
The ones I have already are not that great at video, DVD playback is not possible. But they have one PCI slot, so the one under the TV has the RealMagic Xcard installed. Think you can get a riser card to give two PCI slots, but this would not work in the small [url=http://mini-itx.com/reviews/2688R/}Cubid Cases[/url] I use. Bigger cases are available though.
The new M9000 board is not only a faster processer, but also has much better multimedia support ( 5.1 sound, better video, uses faster memory, plus firewire and USB 2.0 ). As I said its sitting on my desk waiting for a case.
Rod, UK
#129995 - 20/12/2002 09:27 Re: Another Cheap PC [Re: mardibloke]
robricc
While we're on the subject of Mini-ITX, check this out.
#129996 - 20/12/2002 09:31 Re: Another Cheap PC [Re: robricc]
Man I wish that I had the Japanese language pack installed......and that I could still read Japanese
So is the idea with that thing that you can roll your computer around on the floor? I wonder what use a ball-shaped PC could have...
#129997 - 20/12/2002 11:53 Re: Another Cheap PC [Re: Dignan]
world.altavista.com does a reasonable job on it.
However, my favorite part of the translation is the header ``With spatula drawing formation''.
