Page 4 of 13 < 1 2 3 4 5 6 ... 12 13 >
#160105 - 14/05/2003 10:21 Re: Best Portable player right now? [Re: Daria]
maurij
What do you know about power over ethernet? can any standard ethernet port deliver power? ie could i hook up a wireless bridge to the empeg without a power brick if the bridge supported PoE? do you know if the empeg serial connector delivers power?
Jason
#160106 - 14/05/2003 11:08 Re: Best Portable player right now? [Re: maurij]
maczrool
Loc: Louisiana, USA
How thick is the Pearl? It appears to be fairly large in that respect. Does it support recording? The new iPod will soon be doing so.
Stu
#160107 - 14/05/2003 11:56 Re: Best Portable player right now? [Re: maczrool]
trs24
Actually, it already does... sort of.
- trs
#160108 - 14/05/2003 12:29 Re: Best Portable player right now? [Re: trs24]
maczrool
Loc: Louisiana, USA
Yeah I know about that and have tried it, I just don't consider that supporting recording, b/c you have to go into an undocumented diagnostic mode. Background noise is a bit high and of course six seconds is not very useful. Still when they come out with a software update and proper connections, I think the quality will be outstanding, given the specs on the ADC chip. Depending on if they put level meters and gain adjustment into the software, it might even serve as a worthy replacement for my long trashed Sony DAT.
Stu
#160109 - 14/05/2003 16:10 Re: Best Portable player right now? [Re: maczrool]
Happy Birthday rob
Pearl is indeed thicker than the iPod, albeit it substantially shorter. We have an entirely different design philosophy (with little details such as a useful battery life) which some people will prefer, while others will go for iPod. I won't even try to convince a Mac fan - I know you guys catch anything Apple deign to throw at you
No plans for recording in version 1.0. There's plenty of headroom, though, as we use the next generation of the chip used in the iPod. Even so I'm not convinced that single speed capture is going to be the killer feature - quality playback features such as the cross fader and fully parametric EQ are more important.
#160110 - 14/05/2003 16:23 Re: Best Portable player right now? [Re: rob]
maczrool
Loc: Louisiana, USA
So you are using the WM8731L? Pretty nice.
Stu
#160111 - 15/05/2003 02:48 Re: Best Portable player right now? [Re: maczrool]
Happy Birthday rob
Yes, at it happens, but I was actually talking about the processor.
#160112 - 15/05/2003 03:55 Re: Best Portable player right now? [Re: rob]
Actually we use the 8721, not the 31. We have no line inputs. We do, however, have USB host with which to attach ADCs should we want them...
#160113 - 15/05/2003 06:14 Re: Best Portable player right now? [Re: rob]
I've never had the first problem with the battery life in my iPod, other than it seems to use it up more quickly than I'd expect lying around turned off.
#160114 - 15/05/2003 07:24 Re: Best Portable player right now? [Re: wfaulk]
booey
i forgot to even ask, does it have an FM tuner?
man i hope so!!
brian
#160115 - 15/05/2003 07:28 Re: Best Portable player right now? [Re: booey]
My iPod? Nope.
#160116 - 15/05/2003 08:26 Re: Best Portable player right now? [Re: altman]
maczrool
Loc: Louisiana, USA
The 8721 is what the iPods used to use, if I remember correctly. So you probably use the built in USB controller on a PortalPlayer PP5002 then right?
Stu
#160117 - 15/05/2003 10:49 Re: Best Portable player right now? [Re: wfaulk]
Happy Birthday rob
The new iPod has a stated battery life of 8 hours. That means it is going to be somewhat less in reality. A smaller battery was used to shave a couple of mm off the thickness.
#160118 - 15/05/2003 10:55 Re: Best Portable player right now? [Re: rob]
Mine is one of the older ones with a stated life of 10 hours. While I can see people possibly wanting more than that, even given the inflation of the stated spec, I'd have to say that it hardly qualifies as not being ``a useful battery life'', even at 8 (or whatever that means IRL).
#160119 - 15/05/2003 10:58 Re: Best Portable player right now? [Re: wfaulk]
Happy Birthday rob
I wish all our portable customers thought like that. They're used to CD players with 30 hours of playtime.
#160120 - 15/05/2003 11:21 Re: Best Portable player right now? [Re: rob]
A good point. And I actually have one of your portables (for my wife), though I need to get a memory card for it.
#160121 - 16/05/2003 10:42 Re: Best Portable player right now? [Re: maczrool]
The 5002 doesn't have a host USB controller. We don't use the 5002.
#160122 - 16/05/2003 11:32 Re: Best Portable player right now? [Re: altman]
maczrool
Loc: Louisiana, USA
Their site says it features an "integrated USB 1.1 Device Controller," but thanks!
Stu
#160123 - 19/05/2003 02:06 Re: Best Portable player right now? [Re: maczrool]
Yes, "device controller" is a USB slave (just like the empeg-car); "host controller" is what we have in Pearl
#160124 - 19/05/2003 09:11 Re: Best Portable player right now? [Re: altman]
maczrool
Loc: Louisiana, USA
Very good! I forgot to make that distinction. I obviously don't do much work with USB .
Stu
#160125 - 19/05/2003 10:38 Re: Best Portable player right now? [Re: rob]
puckalicious
Sorry if this was discussed already, but how does the Pearl compare to the new Ipod in terms of mass? I stopped by my local Apple store and played around with an Ipod and it was much heavier than I expected. The posted weight of the Ipod is 5.6g (6.2g for 30Gb) but I think the small size makes me feel like it should be lighter.
#160126 - 19/05/2003 12:14 Re: Best Portable player right now? [Re: puckalicious]
Happy Birthday rob
I'm pretty sure you meant ounces.
#160127 - 19/05/2003 13:33 Re: Best Portable player right now? [Re: rob]
phi144
Loc: New Hampshire, USA
Amazing design.
Someone else asked this as well. But, will this include an FM tuner?
Edited by phi144 (19/05/2003 13:43)
Doug
#160128 - 20/05/2003 04:23 Re: Best Portable player right now? [Re: rob]
puckalicious
Wow is that ridiculously light! Yes I meant ounces. (punching myself)
So, are you able to answer the question?
#160129 - 20/05/2003 06:06 Re: Best Portable player right now? [Re: puckalicious]
Happy Birthday rob
I only have postage scales to check with, post they show the Pearl prototype as being exactly the same weight as the smallest iPod. Weight really isn't an issue in either case.
#160130 - 03/06/2003 03:01 Re: Best Portable player right now? [Re: rob]
thinfourth2
What are the chances of it appearing somewhere in holland next month
#160131 - 03/06/2003 03:06 Re: Best Portable player right now? [Re: thinfourth2]
High, considering it's almost in beta now...
#160132 - 03/06/2003 04:10 Re: Best Portable player right now? [Re: altman]
CrackersMcCheese
Any 'unofficial' UK release dates?
#160133 - 03/06/2003 05:30 Re: Best Portable player right now? [Re: CrackersMcCheese]
Nope, but if you really want one (as usual) get it from the US. They will be getting it first.
#160134 - 03/06/2003 10:58 Re: Best Portable player right now? [Re: altman]
puckalicious
Looks like Rio won't be the only player with a 1.5GB model according to this.
Twelve companies so far have plans to release products with the drive. RCA/Thomson, Rio and five other manufacturers will come out with MP3 players with the Cornice Storage Element (SE), and a major U.S. retailer will feature a Cornice-based player from Korea. The first products will hit shelves this quarter, according to Cornice.
Looks like alot of competition for the 1.5GB model, what about Pearl??
