As Promised here are the Links for the Alpine GPS Empeg Knock off product
(drat for some reason alpine is Hiding Links so you will need to look for the items sorry)
Main Unit IVA-D900
http://12.145.140.137/html/D2_n_1_n_n.html
A picture is worth a thousand words and one look immediately tells you "all pictures are not created equal." The IVA-D900 has 400% more pixels, that is 1.15 million pixel elements, the picture is proof enough. Along with 50W x 4 built-in power and 3 PreOuts (4 volt), it's ready to control XM Satellite Radio, a Hard Disc Drive (HDD), video games, navigation and more. The ultimate mobile theater system is now a reality and this DVD player with a motorized screen performs flawlessly.
7" Fully Motorized Wide Screen Monitor
• 50W x 4 MOSFET Amplifier
• Built-in Dolby Digital/DTS Decoder
• Bass Engine® Plus
- Subwoofer Level Control
- Bass Center Frequency Control
- Bass Band Width Adjustment
- Treble Center Frequency Control
- Subwoofer Phase Selector
- Bass Type Control
- 4-Ch Digital Time Correction
- 3 Position 12 dB/Oct Crossover
• MediaXpander™
• XM Satellite Radio Ready
• MP3 Text Information Display
• Quick Search Function
• CD/CD-R Playback
• CD Text, Text Display, Text Scroll
• M DAC
• MaxTune SQ Tuner
• 3 Auxilliary A/V Inputs with Remote Control Input
• Dedicated Navigation Input
• Dedicated Camera Input
• 2 Auxilliary Monitor A/V Outputs
• Navigation Audio Mix
• 3 PreOuts (4 volt)
• MM Driver (Hard Disc Drive) Ready
• MobileHub Ready
• Ai-NET Control Center DVD/CD/MP3 Changer Controller
• "Digital Art" Spectrum Analyzer Display
• RUE-4190 Universal Wireless Remote Control Included
Piss Poor Empeg Knock Off
HDA-5460
CD Player
0 Data Detect Mute
1 Disc DP-S Mechanism
8x Oversampling
CD Text
CD Text Display
CD Text Scroll
Digital De-emphasis
Digital Servo
Disc Play/Pause
Disc Title Memory
Elapsed Time Display
Forward/Backward
M.I.X. (Random Play)
Music Scan
Music Sensor
Regulated 1-Bit DAC
Repeat (One/All)
T.S.M. (Title Search Menu Scroll)
T.S.M. (Title Search Menu)
General-Head Units
1 PreOut
Anti-Theft Detachable Front Panel
Detachable Trim Plate
Operation Indicator
HDD Control (Hard Disc Drive)
BioLight Display
DJ Music Mix (Music Genre DJ Interface)
Detachable HDD (16GB)
MP3/WMA/WAV Playback Capability
Mobile Multimedia Driver Software
Music Visualizer
Stand Alone Play
Stores approximately 3,000 songs
Specs:
CD Player
Channel Separation (1kHz) : 85dB
DAC Type : 1-Bit
Dynamic Range (1kHz) : 95dB
Frequency Response : 5Hz—20kHz
Number of DACs : 2
Oversampling : 8X/352.8kHz
Sampling Rate : 44.1kHz
Signal-to-Noise (SN) : 105dB
Total Harmonic Distortion (THD) : 0.008 %
General-Head Units
Chassis Size (W x H x D)in : 7" x 2” x 6”
Chassis Size (W x H x D)mm : 178mm x 50mm x 152mm
Maximum Mounting Angle : 30° from Horizontal
Nose Piece Size (W x H x D) : 178mm x 46mm x 18 mm
Nose Piece Size (W x H x D)in : 6-11/16" x 1-13/16" x 11/16"
Operating Temperature (°C/°F) : 60°C (140°F) to -10°C (14°F)
Power Requirement : 14.4V DC (11V to 16V)
Pre Output Voltage (Before Clipping) : 2 Volts
HDD Player
MP3 Bit-rate : 64/80/96/112/128/144/160/192/224/256/320 kbps
MP3 Sampling Frequency : 48/44.1/32/24 kHz
Removal HDD : 16 GB
WMA Bit-rate : 64/80/96/128/160/192 kbps
WMA Sampling Frequency : 48/44.1/32/24 kHz
GPS Nav Unit
NVE-N852A
Alpine's DVD PowerNav system was the first to the US market and no one does it better! It's easy to put in an address, business phone number, business name, whatever - and it finds it all, giving you turn-by-turn directions all the way to your destination! It's got over six million points of interest such as ATM's, restaurants, shopping malls, even hardware stores and garden nurseries. And it finds these destinations fast, finishing calculations to your destination in mere seconds! Even if you miss a turn, DVD PowerNav will get you back on your course quickly and automatically.
GUI (Graphical User Interface) for Drivers
• Alpine DVD-ROM Mechanism
• High Performance CPU and Graphics Engine
• 12 Channel GPS Receiver, Gyro Sensor and Speed Sensor
• Wireless Audio/Navigation Remote Control Included
• Freeway Exit and Entrance Name Guidance
• SmartMap Pro 8.5 GB Dual Layer DVD-ROM
• Coverage across the US and parts of Canada (see coverage map for detailed areas)
• Over six million points of interest (POIs) from NavTech and InfoUSA
