I am trying to install a new drive in a MK2a and when I run the drive builder it won't find the player. I have tried both builders.
The player shows up in hyperterminal. Here is the log.
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v325 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Apr 2 17:15:11 EST 2003
empeg-car player (hardware revision 9, serial number 40104261)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x99b78
Tuner: loopback=0,
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005b80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DI
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:a
5
Partition check:
hda: unknown partitio
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024
count=1
EXT2-fs: unable to
e000 v1.04
Copying kernel...
l.
Tuner: loopback=0, ID=0
empeg state support initialised 0089/88c1 (save to d0005d00).
5
Partition check:
hda: unknown partition table
count=1
EXT2-fs: unable to
e000 v1.04
Copying kernel...
l.
e000 v1.04
Copying kernel...
l.
5
Partition check:
count=1
EXT2-fs: unable to
