This could be due to one of a few things:
1) Difficult to index into a VBR file with the current XAudio playback engine. This is the same bug that causes the FF/REW problems. If this is the case, the problem should go away with 1.1 since they're using a different playback engine.This might be the case, however I would see that as a bug (either in the XAudio package or empegs software), because current position should be kept as the current byte position in the file (implicitly by number of currently playing mp3 frame or explicitly).
2) You said that the reboot happened because of memory problems. Well, the player doesn't save its state unless you physically pull the power. A soft reboot, or a reboot due to a software crash, won't save the player state.I know. However, though I first saw that behaviour on a reboot due to a soft reboot (crash), I was able to reproduce it by simply skipping well into the file, letting it play for a while (until the time display stabilized), hold the top button to turn the empeg of (to standby), remove it from the sled, put it back in (it boots, then turns to standby), turn it back on. Now I´m only half as far into the file as I was before turning it of.
3) You're still having crashes due to memory problems? Haven't you contacted Empeg support and gotten it fixed?It got picked up yesterday, and I´m hoping to have it back
soon. I´m already missing it alot
![](/images/icons/wink.gif)
cu,
sven
(MkII 12GB
blue, #080000113)
