#223444 - 19/08/2003 00:24 tRio 0.1.4 alpha4
pauln
Folks,
I've just put an alpha4 version up on sourceforge and updated the docs and site. See http://triot.sourceforge.net . The new "Web Front-End" link in the banner gives the low-down on the new applet (I'm sure it's still littered with typos though).
I think this version is just about fit for general consumption, so give it a go and let me know how you get on. I'd imagine an alpha5 will be required over the next few days.
Paul
Paul (the tRio guy)
#223445 - 19/08/2003 17:59 Re: tRio 0.1.4 alpha4 [Re: pauln]
Jerz
Loc: Jesusland
OK, I'm embarrassed, but I had the previous alpha working, then it stopped working (presumably when I screwed something up) so I then installed alpha 4 and keep getting (wish I knew how to cut and paste from cprompt)
"trio.player.TRioPlayerServerException: Error connecting to JReceiver
Pleas check that JReceiver is running and properly configured.
at trio.player.TRioPlaerJRecServer.connect(unknown Source)
...listArtist(unknown source)
and unknown source for the rest
the:
by: jreceiver.common.rpc.RpcException:xmlrpc-problem invoking method [Drivers.Register]
etc
Any ideas?
Jrec seems to be working fine when I tell it to play a playlist within jetty.
Thanks.
#223446 - 19/08/2003 18:12 Re: tRio 0.1.4 alpha4 [Re: pauln]
basf_audio
newbie
Loc: Saint Louis
Paul,
Thanks for the updated 0.1.4 alpha version. I see that the crashing during the shuffle selection has been fixed! I'm still working through testing out your new release but I have to say that all is looking great! Thanks!
-Dave
#223447 - 19/08/2003 18:33 Re: tRio 0.1.4 alpha4 [Re: Jerz]
Jerz
Loc: Jesusland
Nevermind...I've been working myself over for many hours and I've got it working. It's AWESOME
<<kicking self...how in the eff did the trio roll go from players to foobal? I could have sworn that's what it said>>
#223448 - 19/08/2003 19:34 Re: tRio 0.1.4 alpha4 [Re: pauln]
Jerz
Loc: Jesusland
Paul -
tRio 0.1.4 alpha4 ROCKS! I'm streaming internet radio to one receiver and listening to that one with four others. It works perfect and once installed is extremely simple to use. I can't wait for my two other receivers to arrive.
I just need to figure out what I'm going to do with the HSX-109
#223449 - 19/08/2003 23:28 Re: tRio 0.1.4 alpha4 [Re: Jerz]
happy_hammer66
newbie
I can use the web interface on the server pc, but was trying to use on a different one on the network(win98), is this supported?
i will try trio 0.1.4 alpha4 with jrec 0.2.3 at the weekend to see if it can work.
great work.
bill
#223450 - 19/08/2003 23:32 Re: tRio 0.1.4 alpha4 [Re: happy_hammer66]
pauln
Some folks have been struggling with this, but it works fine for me:
- you must have the java 1.4.2 plug-in installed on the other machine
- make sure you specify the address/name of the tRio Server machine in the address and the :8090 bit.
Otherwise, what are you seeing in you web-browser and in the java console?
Paul
Paul (the tRio guy)
#223451 - 20/08/2003 06:12 tRio 0.1.4 alpha4 and dhcp [Re: pauln]
donp
In the "other enhancements" for this release it says something about :
tRio should now work with windows and router-based DHCP servers.
How do I do I get this working? Up until now I have been changing setups whenever the Rio got a new address.
#223452 - 20/08/2003 07:26 Re: tRio 0.1.4 alpha4 and dhcp [Re: donp]
Jerz
Loc: Jesusland
Works great for me.
Although I can't tell you how to fix your situation, I can tell you how I did my install (maybe that'll help?)
I installed the first part of JRec (latest version) (did not install the second part )
installed tRio per instructions
and installed Rio Audiomanager that came with the Rio ver1.4
I've got a linksys cable dsl router that handles my dhcp.
So far, so good.
#223453 - 20/08/2003 09:24 Re: tRio 0.1.4 alpha4 and dhcp [Re: donp]
pauln
What you need to do is create a "reservation" for the receiver's MAC address on your DHCP server. You specify the ip address you'd like assigned in the reservation so that the receiver will get the same one every time.
If you don't know what the MAC address is, then you can:
- look in the original ARM software - I think it shows the MAC addresses for the receivers that have connected
- look in your DHCP sever logs
- close all your dhcp servers down and power a receiver off and on again - after a few minutes it gives up and shows the info on it's LCD display
Hope this helps
Paul
Paul (the tRio guy)
#223454 - 20/08/2003 11:19 Re: tRio 0.1.4 alpha4 and dhcp [Re: pauln]
donp
OK.. I don't think the Linksys can assign some fixed and some dynamic, though it is ok with clients that come in knowing what their fixed address is.
I'll try having the Linksys ignore the Rio's address request so the linux jrec server can assign it a fixed address as in the jrec install directions.
#223455 - 20/08/2003 22:36 Re: tRio 0.1.4 alpha4 [Re: pauln]
shawnharper
Paul - first, thanks for all your hard work.
I just got my first Rio yesterday, and set aside some time tonight to play with tRio, and have it working (mostly).
I'm running XP, and still have ARM (jReceiver is the next free evening).
I've got the web applet running fine, and it'll play songs on my HD just fine. However, when trying to stream, I get the following error: (this is only the first handful of lines)
PlayerStream (/192.168.0.105) - streamStart()
Opening station content url: ST6, conn: sun.net.www.protocol.http.HttpURLConnect
ion:http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=8167&file=filename.p
ls
Opened station content url: ST6, method: GET, header fields: {X-Powered-By=[PHP/
4.1.1], Connection=[Keep-Alive], Date=[Thu, 21 Aug 2003 05:16:10 GMT], Keep-Aliv
e=[timeout=15, max=100], Server=[Apache/1.3.26 (Unix) PHP/4.1.1], Content-Type=[
audio/x-scpls], null=[HTTP/1.1 200 OK], Transfer-Encoding=[chunked]}
got line: [playlist]
got line: numberofentries=5
got line: File1=http://64.236.34.141:80/stream/1018
Opening station content url: http://64.236.34.141:80/stream/1018, conn: sun.net.
www.protocol.http.HttpURLConnection:http://64.236.34.141:80/stream/1018
Updating config file
Error: java.net.ConnectException: Connection timed out: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
Any clues for this newbie?
Thanks.
#223456 - 21/08/2003 00:53 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
pauln
A few questions:
1. Are you getting this for all stations, or just this one?
2. Does it it happen consistently?
Paul
Paul (the tRio guy)
#223457 - 21/08/2003 06:33 Re: tRio 0.1.4 alpha4 [Re: pauln]
pauln
Mark has just pointed out to me that there's a bit of a blunder in the tRio docs.
The address for the web front-end is http://xxxxx:8090/trio-applet.htm and not /web-applet.
I'll update the site.
Paul
Paul (the tRio guy)
#223458 - 21/08/2003 07:33 Re: tRio 0.1.4 alpha4 [Re: pauln]
shawnharper
1) I only have one station (for now).
2) I am getting the error repeatedly (every time I try to stream anything).
Thanks for the help.
#223459 - 21/08/2003 13:47 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
pauln
I think we need to establish whether it's just that one station that's the problem. Try adding a few more (Virgin Radio is fairly reliable) and let me know.
Paul
Paul (the tRio guy)
#223460 - 21/08/2003 13:56 Re: tRio 0.1.4 alpha4 [Re: pauln]
shawnharper
I tried it with the four "stations" that are in the web applet as default, as well as tried it adding a few "stations" of my own.
Same result/error each time.
#223461 - 21/08/2003 14:04 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
hipped1
Are you able to stream the shoutcast streams to winamp on your computer? None of the default stations worked for me but I used the new drag and drop from shoutcast.com to populate my station list with a working list (nice feature by the way).
#223462 - 21/08/2003 16:14 Re: tRio 0.1.4 alpha4 [Re: hipped1]
shawnharper
I'm not at home to test, but are you saying I can drag and drop into the tRio web applet from Winamp??? That'd be great. I'll try it this evening.
#223463 - 21/08/2003 17:53 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
hipped1
Shawn,
Actually I was suggesting that you make sure the shoutcast stream works by playing it through winamp. That way you could rule out connection/firewall issues.
As for the trio and drag and drop, I went to the shoutcast.com website, and then dragged the" tunein" icon over the trio web interface and a dialog box popped up which allowed me to add the url without retyping and allowed me to rename the stream (eliminating in my case the number of users from the description). Good luck
#223464 - 21/08/2003 18:20 Re: tRio 0.1.4 alpha4 [Re: hipped1]
Jerz
Loc: Jesusland
Great tip! Just drag and drop the "click to listen" icon to the web interface...awesome!
#223465 - 23/08/2003 18:32 Periodic Crash in Trio server [Re: pauln]
TinnedFish
Loc: Oregon
Howdy,
I'm getting a crash in the trio server. Maybe this will be useful:
Behavior:
Periodic (4 times in 24 hours) audio stops from Player. Timer for the current track continues to increment, but the player is unresponsive (no button clicks can change state). Trio window shows incrementing Connections from the player, but no pickup. jReceiver does not indicate any errros. I'll paste a crash below.
Has occured once while streaming, and three times while listening to tracks (Genre on Shuffle from Jreciever).
Windows 2000 Server, SP4, 256M RAM, Celeron 566
tRio 0.1.4A
Jreceiver 0.2.5
Java j2re1.4.1_03
Let me know if there's a debug/log setting I can enable to get more data.
snip.....
*** Short JRec content read - setting EndOfTune. src_id: 3326, tuneOffset: 5997
640, bufferOffset: 0, reqLength: 4712, readLength: 3545
PlayerStream (/192.168.0.6) - End Of Tune. nextTune: 23rd Psalm Feat. Gramps Of
Morgan Heritage
PlayerStream (/192.168.0.6) - Next get: 7200
java.lang.NoClassDefFoundError: javax/net/ssl/SSLSocket
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown So
urce)
at jreceiver.client.common.ClientContent.getBytes(ClientContent.java:104
at trio.player.TRioPlayerJRecServer.getContent(Unknown Source)
at trio.player.TRioPlayerStreamImpl.streamGet(Unknown Source)
at trio.player.TRioPlayerStreamImpl.processDataRequest(Unknown Source)
at trio.player.TRioPlayerStreamImpl.messageReceived(Unknown Source)
at trio.TRioUnit.notifyMessageListeners(Unknown Source)
at trio.TRioUnitControlThread.run(Unknown Source)
Got connect from /192.168.0.6
....this goes on until tRio server is restarted, then it picks up the connection immediately.
TinnedFish (bruce)
#223466 - 24/08/2003 03:57 Re: Periodic Crash in Trio server [Re: TinnedFish]
pauln
Bruce,
This is bizarre - it seems to be trying to open a secure connection (SSL) to your station or audio file. Do have any unusual security settings?
Paul
Paul (the tRio guy)
#223467 - 24/08/2003 06:24 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
donp
I haven't had much luck with the default stations... maybe too many listeners on at once?
Other stations have worked well for me.
#223468 - 27/08/2003 12:51 Re: tRio 0.1.4 alpha4 [Re: hipped1]
shawnharper
paul/h1pped1 -
Back from travelling, and still can't get trio to work with streams. Verified the target stream works (tried it in winamp). Can you look at the error below, and help me out?
Thanks.
Opening station content url: ST8, conn: sun.net.www.protocol.http.HttpURLConnection:http://62.236.36
.72:80/stream/1040
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at trio.player.TRioPlayerShoutcastServer.shoutcastConnect(Unknown Source)
at trio.player.TRioPlayerShoutcastServer.getContent(Unknown Source)
at trio.player.TRioPlayerARMServer.getShoutcast(Unknown Source)
at trio.player.TRioPlayerARMServer.getContent(Unknown Source)
at trio.player.TRioPlayerStreamImpl.streamStart(Unknown Source)
at trio.player.TRioPlayerStationStream.join(Unknown Source)
at trio.player.TRioPlayerUnitStream.setUnderlyingStream(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(Unknown Source)
at sun.rmi.transport.Transport$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
#223469 - 28/08/2003 04:20 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
pauln
Shawn,
Sorry, but I'm running out of ideas as to what your problem might be. I tried one of your stations and it worked just fine for me. And so it's got to be something to do with your set up.
When you say that it's working through winamp, is this from the same machine that the tRio server is running on?
The last resort would be to run a network trace to compare what's happening when you tune in via winamp vs. tRio.
Paul
Paul (the tRio guy)
#223470 - 28/08/2003 08:27 Re: tRio 0.1.4 alpha4 [Re: pauln]
shawnharper
Yes, Winamp, tRio, and ARM are all on the same computer (my only computer ).
Can someone hold my hand through a "network trace" as this is quickly getting over my head.
Would going from AMR to JRec have any chance of solving my problems? This sucks, because the main reason I got the receiver was to stream internet radio. I'm bummed, but not hopeless.
#223471 - 28/08/2003 13:20 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
hipped1
You might also wish to test Rioplay as its easy to switch out the receiver.arf file and give it a quick try. http://rioplay.sourceforge.net/
#223472 - 28/08/2003 17:18 Re: Periodic Crash in Trio server [Re: pauln]
TinnedFish
Loc: Oregon
Wow, no weird settings that I know of. I installed JRE/Jetty/Jreciever just for this application. The machine did reside on a corporate domain before they closed the doors, maybe JAVA inherits security settings from Win2k Server? Someday I'll try a fresh OS reinstall and see if it goes away.
Another theory - my boot drive is dog dog slow (circa 1998). Maybe disk access speed is slower (while requesting detailed sorts of 80gigs of music) than the timeouts for tRio, and it's trying to connect to the drive via alternate methods (ala SSL?) Again, I'll see if I can find a faster drive to swap out.
I'll keep banging on it. thanks for the app...
TinnedFish (bruce)
#223473 - 29/08/2003 01:45 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
pauln
Shawn,
I PM'd you about this last night (UK time) - have you got this?
Paul
Paul (the tRio guy)
#223474 - 29/08/2003 13:05 Re: tRio 0.1.4 alpha4 [Re: pauln]
shawnharper
Got the PM (sorry I was slacking) and installed the SW. What's next?
An aside: anyone ever have the audio drop out for ~1 second, evrey 7-20 seconds? Happens sometimes - haven't been able to determine the trigger.
#223475 - 29/08/2003 13:38 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
julf
I have it - but not quite as frequently. 1-sec dropouts at moderate intervals. Have been blaming my curent makeshift set-up, with an XP box running ARM from a samba-served file store on a Linux box.
#223476 - 29/08/2003 14:09 Re: tRio 0.1.4 alpha4 [Re: julf]
shawnharper
I think it's about time for me to have a seperate music server, that I keep in a closet or something. There's 2 other people using this one (wife and reoommate) and it'd be simpler that way.
Question: I've never used Linux. I've been born and raised on Windows.
Should I use a Linux or XP Pro box? (I have win 2k also)
Thanks.
#223477 - 30/08/2003 01:04 Re: tRio 0.1.4 alpha4 [Re: shawnharper]
julf
Well, I feel (rather strongly) that Linux (or even better, OpenBSD) is far superior as a server platform. But there is a significant learning curve.
My advice is go for Linux *iff* you also want to use the opportunity to learn about Linux. If you just want a server with minimum hassle, go for WinXP based on the "better the devil you know" principle. Avoid w2k.
#223478 - 30/08/2003 09:23 Re: tRio 0.1.4 alpha4 [Re: julf]
shawnharper
Hmm. Learning curve. I definitely want to learn Linux, but life's too hectic right now to take that on. I just want music that plays reliably.
XP it is. Thanks.
#223479 - 01/09/2003 19:33 Re: Periodic Crash in Trio server [Re: TinnedFish]
mwmorris57
I seem to be having the same problem. When I last experienced this I was runnging jrec 2.5, jetty 4.2.11, trio 0.1.4.alpha4. I was using ARM with DHCP disabled, getting DHCP from my linksys BEFSR41 router. I had a dhcp range of 192.168.1.129 through 192.168.1.200. All other devices on my network are fixed ip. I've since turned off DHCP in the router and re-activated in ARM. I'm trying to see if this will correct the problem. My hard deive is about a year old so its pretty fast. Can't remember the exact specs.
#223480 - 02/09/2003 09:51 Re: tRio 0.1.4 alpha4 [Re: pauln]
Jerz
Loc: Jesusland
OK for some reason at the office I get just the gray background when starting the web interface any ideas?
Edit: Please see attachment. It definatelys says that the applet started and I don't see any errors...
3752-trio front end.JPG (270 downloads)
Edited by Jerz (02/09/2003 14:57)
#223481 - 02/09/2003 14:38 Re: tRio 0.1.4 alpha4 [Re: pauln]
jvolino
I am having trouble getting the Player tab to make the player info page display on the web interface. Initially it didn't work, then it did, now I can't get it to work at all. I see the Status page, but when I click on the Player tab, it either ignores my click or turns light grey without switching the Player page (Status page remains visible). I am on WinXP Pro SP1, running with ARM as server, have JRE 1.4.2_01 installed. I have 3 Rios active on my LAN.
It looks like there's an exception generated on Java console in response to clicks, but the Copy button doesn't seem to copy it to the Windows clipboard (any tips?).
The first error listed is:
java.lang.IllegalArgumentException: setSelectedIndex: 3 out of bounds
at javax.swing.JComboBox.setSelectedIndex(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.getModePanel(Unk. src.)
etc...
Thanks for all your work!
--Judd Volino
#223482 - 02/09/2003 19:01 Re: tRio 0.1.4 alpha4 [Re: jvolino]
jvolino
Well, I was able to get the Player tab to work again. It seems like when I tried to get to the tab for a freshly-booted player, it wouldn't work. But if I started something playing from the player itself, then I could click on the tab. Is this to be expected?
#223483 - 03/09/2003 08:22 Re: tRio 0.1.4 alpha4 [Re: jvolino]
shawnharper
jvolino - I have the same problem frequently. I think the "system" is finicky about what order you do things, and how long you wait between starting each app. I haven't found the recipe yet.
Anybody know the recipe?
i.e.
Turn receiver on
Wait 15 sec
start tRio
Wait 25 sec
start web interface
be happy, play music.
#223484 - 03/09/2003 11:14 Re: tRio 0.1.4 alpha4 [Re: Jerz]
Jerz
Loc: Jesusland
Well, I've got the front end working at the office (at home no problems) and everything seems to work fine except:
1. I hit "play" and nothing happens. I can skip to the next song but it will not play. I can also pull up a radio station and everything "looks" fine except it won't play.
2. The only play options are "quen n play" or "radio" nothing else.
It was much easier getting the old PII 400 to work.
#223485 - 03/09/2003 13:44 Re: tRio 0.1.4 alpha4 [Re: Jerz]
Jerz
Loc: Jesusland
Nevermind... for some reason I had to assign static ip's to the trio server as well as the player which was done in my sonicwall firewall. Works perfect now.
#223486 - 03/09/2003 15:02 Re: Periodic Crash in Trio server [Re: TinnedFish]
pauln
Bruce,
I've had another look at this and the problem is actually happening in JReceiver and not tRio.
Do you know how to use mysql? If not, look at the Verify Database Initialization step in the jreceiver install instructions (http://jreceiver.sourceforge.net/jrec-install-server.html).
Please run the following query in mysql:
select * from mfile where src_id = 7200;
The 2nd value this returns is the key into the folder table. Then run this query (changing nnnn to the key value) and let me know what you get:
select * from folder where id = nnnn;
Paul
Paul (the tRio guy)
#223487 - 03/09/2003 15:11 Re: tRio 0.1.4 alpha4 [Re: jvolino]
pauln
Judd,
This looks like something I'll have to look into. Please write it up as a bug at http://sourceforge.net/tracker/?group_id=72920&atid=536118 .
Paul
Paul (the tRio guy)
#223488 - 05/09/2003 00:17 Re: Periodic Crash in Trio server [Re: pauln]
TinnedFish
Loc: Oregon
Nothing too juicy here I don't think... Anything else? Sorry for the slow comeback, I was busy helping the wife have a baby.
mysql> select * from folder where id = 957;
| id | name | parent_id | path |
| 957 | The Man Comes Around | 954 | D:\Start\Johnny Cash\The Man Comes Around |
1 row in set (0.04 sec)
#223489 - 05/09/2003 00:58 Re: tRio 0.1.4 a4 - WebInterfaceCrash Jukebox mode [Re: pauln]
TinnedFish
Loc: Oregon
Steps:
1. open http://pacemaker:8090/trio-applet.htm
2. Select Player tab. Note page opens in Radio mode.
3. Select Jukebox. Client hangs. Note logs:
Trio.bat
<snip>
Got http request: GET /trio-applet.htm HTTP/1.1
Got http request: GET /trio-applet-0.1.4.jar HTTP/1.1
Got http request: GET /images/rio-small.gif HTTP/1.1
getting image: file:/C:/Program Files/tRio-0.1.4.alpha4/images/rio-small.gif
*** start of TRioPlayerJukeboxDlg
Exception listing Albums: jreceiver.common.rpc.RpcException: xmlrpc-problem invo
king method [Menus.getAlbumMenuRecs]
Message: xmlrpc-problem invoking method [Menus.getAlbumMenuRecs]
Root cause: org.apache.xmlrpc.XmlRpcException: jreceiver.common.rpc.RpcException
: bus-problem getting album menu recs
at org.apache.xmlrpc.XmlRpcClient$Worker.execute(Unknown Source)
at org.apache.xmlrpc.XmlRpcClient.execute(Unknown Source)
at jreceiver.common.rpc.xmlrpc.XmlRpcBaseImpl.execute(XmlRpcBaseImpl.java:63)
at jreceiver.common.rpc.xmlrpc.MenusImpl.getRecsHelper(MenusImpl.java:135)
at jreceiver.common.rpc.xmlrpc.MenusImpl.getAlbumMenuRecs(MenusImpl.java:49)
at trio.player.TRioPlayerJRecServer.listAlbums(Unknown Source)
at trio.player.TRioPlayerTreeSelection.populateChildren(Unknown Source)
at trio.player.TRioPlayerTreeSelection.hasChildren(Unknown Source)
at trio.player.TRioPlayerJukeboxSequencer.setCurrentSelection(Unknown Source)
at trio.player.TRioPlayerJukeboxSequencer.<init>(Unknown Source)
at trio.player.TRioPlayerJukeboxDlg.<init>(Unknown Source)
at trio.player.TRioPlayerJukeboxMode.enterMode(Unknown Source)
at trio.player.TRioPlayerFrame.modeChanged(Unknown Source)
at trio.player.TRioPlayerUnitSettings.setMode(Unknown Source)
at trio.player.TRioPlayerUnitStream.setPlaybackMode(Unknown Source)
at java.lang.Thread.run(Unknown Source)trio.player.TRioPlayerServerException: Error listing Albums.
Caused by: jreceiver.common.rpc.RpcException: xmlrpc-problem invoking method [Me
at jreceiver.common.rpc.xmlrpc.XmlRpcBaseImpl.execute(XmlRpcBaseImpl.java:69)
... 21 more
jrec_jetty.bat log:
<snip>
Sep 4, 2003 11:57:03 PM jreceiver.client.mgr.MgrLauncher registerWithServer
INFO: MgrLauncher: registering with server
23:57:03.680 EVENT mgr-launcher: getProperties: external file=C:\Program Files\
JReceiver-0.2.5\etc\jreceiver.properties
Sep 4, 2003 11:57:04 PM org.apache.struts.util.PropertyMessageResources <init>
INFO: Initializing, config='jreceiver.client.mgr.Messages', returnNull=true
23:57:38.751 EVENT Started HttpContext[/]
Sep 4, 2003 11:57:42 PM jreceiver.common.rpc.xmlrpc.XmlRpcBaseHandler execute
WARNING: cannot service rpc request for method=getAlbumMenuRecs user=trio
Message: bus-problem getting album menu recs
Root cause: Message: db-problem getting menu album recs
Root cause: Message: db-problem encoding results
Root cause: Message: sql-problem getting menu recs
Root cause: java.sql.SQLException: General error: Got error 'empty (sub)expressi
on' from regexp
at org.gjt.mm.mysql.MysqlIO.sendCommand(Unknown Source)
at org.gjt.mm.mysql.MysqlIO.sqlQueryDirect(Unknown Source)
at org.gjt.mm.mysql.MysqlIO.sqlQuery(Unknown Source)
at org.gjt.mm.mysql.Connection.execSQL(Unknown Source)
at org.gjt.mm.mysql.Statement.executeQuery(Unknown Source)
at org.gjt.mm.mysql.jdbc2.Statement.executeQuery(Unknown Source)
at jreceiver.server.db.MenuDB.getRecs(MenuDB.java:182)
at jreceiver.server.db.MenuDB.getRecs(MenuDB.java:214)
at jreceiver.server.db.MenuDB.getAlbumMenuRecs(MenuDB.java:74)
at jreceiver.server.bus.MenuBus.getAlbumMenuRecs(MenuBus.java:81)
at jreceiver.server.rpc.MenusDirect.getAlbumMenuRecs(MenusDirect.java:69)
at jreceiver.server.rpc.xmlrpc.MenusHandler.getRecsHelper(MenusHandler.java:95)
at jreceiver.server.rpc.xmlrpc.MenusHandler.executeHandler(MenusHandler.java:75)
at jreceiver.common.rpc.xmlrpc.XmlRpcBaseHandler.execute(XmlRpcBaseHandler.java:44)
at org.apache.xmlrpc.XmlRpcServer$Worker.execute(Unknown Source)
at org.apache.xmlrpc.XmlRpcServer.execute(Unknown Source)
at jreceiver.common.rpc.xmlrpc.XmlRpcServlet.doPost(XmlRpcServlet.java:113)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:360)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:294)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:558)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1714)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:507)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1664)
at org.mortbay.http.HttpServer.service(HttpServer.java:863)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:775)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:939)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:792)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:201)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:289)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:455)
00:00:00.044 EVENT Log age 2003_08_29.jetty.log
-TinnedFish (bruce)
#223490 - 05/09/2003 01:45 Re: Periodic Crash in Trio server [Re: TinnedFish]
pauln
And your music is stored in d:\start?
Paul (the tRio guy)
#223491 - 05/09/2003 01:51 Re: tRio 0.1.4 a4 - WebInterfaceCrash Jukebox mode [Re: TinnedFish]
pauln
Bruce,
How often does this happen and can you recreate it easily? It been reported to me once before (in 0.1.4.alpha1), but no one else seems to have encountered it and I can't for the life of me recreate it. And so I was hoping that it was something wierd with their jreceiver set up. But alas.
Remind me, is jrec running on a Linux or Windows box?
Paul
Paul (the tRio guy)
#223492 - 05/09/2003 08:49 Re: tRio 0.1.4 alpha4 [Re: Jerz]
Jerz
Loc: Jesusland
Well, I'm having problems getting the web interface at the office working properly once again. The receiver works fine but the web interface will not go to the "player" tab. The "status" tab works fine and even allows me to reboot the unit. The strange thing is that it *was* working fine two days ago just after I set the static ip addresses.
Attached is the info from the java console.
java version 1.4.2
#223493 - 05/09/2003 11:39 Re: Periodic Crash in Trio server [Re: pauln]
TinnedFish
Loc: Oregon
Affirmative. The server is scrapped together from parts, so I have three drives, each with a folder in the root. Named Start, Middle, and End. Jreceiver is set up to scan all three as roots.
#223494 - 05/09/2003 11:45 Re: tRio 0.1.4 a4 - WebInterfaceCrash Jukebox mode [Re: pauln]
TinnedFish
Loc: Oregon
Happens every time for me, following the steps described. I can live with it if I'm the only one. I tend to live in the Queue and Play mode.
Could also be my slow boot drive (and hence the jreciever drive). If it's doing a huge query of the database on a per track basis, that might exceed a timeout somewhere down the pipe. I'm working to replace the drive (actually not working, but as soon as I land a job I will! <grin>).
Also, my MP3 stash is not the cleanest. It was built from P2P, windows, mac, and linux systems. I've been crawling through the tags and filenames and fixing all the out of range characters from the non-MS OS's, but it's going to take me years. If it's excepting on something doublebyte or the like, I wouldn't be surprised.
My setup - Win2kServer, trio 0.1.4, Java 1.4.2, Jreceiver 0.2.5, ARM (dell cd), tigerdirect rio
#223495 - 07/09/2003 04:34 Re: Periodic Crash in Trio server [Re: TinnedFish]
pauln
Bruce,
To fix the "java.lang.NoClassDefFoundError: javax/net/ssl/SSLSocket" error, we need to add jsse.jar to your java classpath. To do this, edit trio.bat and find the following:
-Djava.class.path="%JAVA_HOME%\lib\tools.jar;..."
and then change it to read:
-Djava.class.path="%JAVA_HOME%\lib\tools.jar;%JAVA_HOME%\lib\jsse.jar;..."
Hopefully this will fix your problem. But I'm still clueless as to why it's wanting to use a secure socket.
Let me know how you get on.
Paul
Paul (the tRio guy)
#223496 - 07/09/2003 04:39 Re: tRio 0.1.4 a4 - WebInterfaceCrash Jukebox mode [Re: TinnedFish]
pauln
Bruce,
I can't for the life of me get this to happen on my system. But please PM with your email address and I'll send you a fix that *MIGHT* fix it.
Paul
Paul (the tRio guy)
