#233140 - 10/09/2004 10:11 http://empeg.comms.net not found
Micman2b
Loc: Central, NC, USA
I have not been able to connect to http://empeg.comms.net since yesterday. I can access http://empegbbs.com however. Which address should I be using???
Sean in NC
Edit: I just noticed that this is being discussed HERE
#233141 - 10/09/2004 13:16 Re: http://empeg.comms.net not found [Re: Micman2b]
RobotCaleb
you should be using http://empegbbs.com now
#233142 - 10/09/2004 14:18 Re: http://empeg.comms.net not found [Re: RobotCaleb]
Aware of that, but Tom made sure to set it up so that empeg.comms.net still resolves, so that all the existing links (BBS-internal, Riocar.org, the FAQ, and all the ones out there on the web) redirect to the appropriate place. There's something wrong with DNS at the moment, where only some people are getting empeg.comms.net to resolve.
#233143 - 10/09/2004 14:47 Re: http://empeg.comms.net not found [Re: tfabris]
genixia
Not resolving for me either - old links are borked.
#233144 - 11/09/2004 00:17 Re: http://empeg.comms.net not found [Re: tfabris]
RobotCaleb
i answered that question, alone.
#233145 - 11/09/2004 02:19 Re: http://empeg.comms.net not found [Re: Micman2b]
I'll contact PaulH about this, he has access to the comms.net domain, and I don't. empegbbs.com is the proper correct address, hence every attempt to go to empeg.comms.net redirecting to it.
