#245107 - 02/01/2005 20:59
Re: Empeg Web Lite - Stylesheet for Hijack's http server
[Re: Gleep]
Loc: Erie, CO
Quote: Don't the tweak functions remove things from the playlist?
If you long press the tweak by artist, it will remove ALL artists matching the currently playing track. Probably not the desired effect if you want to just remove one track.
#245108 - 05/01/2005 04:14
[Re: cushman]
The XML page cannot be displayed Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
Invalid at the top level of the document. Error processing resource 'http://192.168.0.178/?FID=101&EXT=default.xml'. Line ...
artist=Various
I GET THAT ERROR WHEN I TRY TO RUN THE WEBPAGE default.xml
#245109 - 05/01/2005 04:18
[Re: kendrick]
Nevermind I fixed it, My computer was renaming the .xsl file to .xml.
#245110 - 25/01/2005 23:41
[Re: cushman]
Just wanted to give a friendly bump. ![](/ubbthreads/images/graemlins/smile.gif)
#245111 - 26/01/2005 00:57
[Re: SE_Sport_Driver]
Loc: Erie, CO
Quote: Just wanted to give a friendly bump.
Just got a new Linux dev box up and running, so I'll be working on this in the nearer future, but I'm currently adding support for 480x320 resolution to Palantir (for Tungsten T3 and T5 owners, plus Tapwave Zodiac and maybe some of the Sony devices). It's coming, though.
#245112 - 23/06/2005 11:58
[Re: cushman]
If one uses player v3, the player data is utf-8 encoded. But the http output claims it is iso-8859-1 encoded.
Where to fix that? In the stylesheet or in hijack?
Thanks, Pim
#245113 - 23/06/2005 12:26
[Re: pim]
That would be a Hijack issue.
What should it be returning, for v2 and for v3?
#245114 - 23/06/2005 12:48
iso8859-1 for v2 and utf-8 for v3.
Pim
#245115 - 23/06/2005 12:50
[Re: pim]
Quote: iso8859-1 for v2 and utf-8 for v3.
Pim
Should it be "iso8859-1" (as above), or "iso-8859-1" (as currently done)?
#245116 - 23/06/2005 12:52
And for that matter, should it be "utf-8" or "UTF-8" ?
#245117 - 23/06/2005 14:26
Browsers don't seem to care about the extra hyphen or the case.
I did a test with a small cgi script, sending out various content-type charsets and appropriately encoded body texts.
Firefox 1.04 and IE 6.0 always get it right.
I'm not sure what the preferred notation is. I guess if you leave the v2 output as it is, and use "utf-8' for v3, we would be pretty safe.
Thanks, Pim
#245118 - 23/06/2005 18:16
[Re: pim]
Okay. Hijack v433 in a few minutes, then.
The only change is the UTF-8 charset type for XML ouput.
I suppose someday I should also set it for regular browser output, too.
#245119 - 23/06/2005 21:25
Great! Works as expected.
Yes, it applies to al output that uses tag data. The encoding for regular playlist views is still wrong.
Thanks, Pim
#245120 - 24/06/2005 00:37
[Re: pim]
Hijack v434.
#245121 - 26/07/2005 00:23
Quote: Hijack v434.
Sorry it took this long to test.
There's a typo that makes html playlists fail to display correctly.
The header says "charset-utf-8' instead of 'charset=utf-8'.
The bug is there too for xml output, but it is unnoticed, as
there's another encoding tag in the xml itself.
Pim
#245122 - 26/07/2005 01:14
[Re: pim]
There's a typo that makes html playlists fail to display correctly. The header says "charset-utf-8' instead of 'charset=utf-8'.
Hijack v438, shortly.
#245123 - 26/07/2005 16:11
Thanks Marc! Works as advertised. Another plea: I'd like to be able to use both Empeg Web Lite and Charcoalgray's XSL stylesheet, but there's only room for one default.xsl. How about having the XSL sheet configurable in the URL, like http://player/?FID=101&EXT=.xml&XSL=my.xslThanks anyway, Pim
#245124 - 26/07/2005 16:18
[Re: cushman]
Is the attachement in the first post from 30 Dec 2004 still the current version?
--Nathan
#245125 - 26/07/2005 16:30
[Re: Mataglap]
Loc: Erie, CO
The latest version can always be found here.
#245126 - 26/07/2005 16:35
[Re: pim]
Loc: Erie, CO
#245128 - 26/07/2005 17:15
[Re: cushman]
Quote: http://your_empeg_ip/?fid=101&ext=.xml&style=my.xsl
I just use: http://my_empeg_ip/?FID=101&EXT=.xml and it works fine...
Mark, can you add on the download page that notify=1 needs to be in the config.ini for your style sheet to work? I know I should have known better, but my display wasn't working properly because I had forgotten that I started with a "stock" config.ini and it took me a while to remember. It just might save someone else some time.
I still love how this works/looks! Are you still planning on some other versions?
#245129 - 26/07/2005 18:19
Loc: Erie, CO
Quote: I just use: http://my_empeg_ip/?FID=101&EXT=.xml and it works fine...
Yes if you have the correct xsl file listed in config.ini for hijack (or keep the default of default.xsl). pim was asking about being able to switch on the fly. In a post above, I described a way we could have an index.html in the root directory with different links to different stylesheets - that would depend on having the stylesheet support passing that style= parameter in all subequent links.
Quote: Mark, can you add on the download page that notify=1 needs to be in the config.ini for your style sheet to work?
Will do.
Quote: I still love how this works/looks! Are you still planning on some other versions?
Yes, but not high on my priority list.
#245130 - 28/07/2005 15:16
[Re: pim]
Quote: Thanks Marc! Works as advertised.
Another plea:
Thanks anyway,
Pim
Isn't that what the existing "&STYLE=xxxxxx" parameter does?
#245131 - 28/07/2005 19:50
Indeed.
I only knew about the config.ini customization.
And let me apologize for spelling your name wrong.
Pim
#245132 - 28/04/2007 00:07
[Re: cushman]
Gahd the BBS Search is pitiful. Typing Empeg Web Lite into the search box doesn't find this page for me. But google.ca found it right away, so here I am again. Hijack v471 is now released. This version automatically looks for the /default.xsl file and changes the "Click Here for Playlists" links to .xml (rather than .htm) when that stylesheet exists. Well, actually, it looks for the khttpd_style file, which defaults to /default.xsl and can be set to anything you want in the [hijack] section of the config.ini file, as in: [hijack] khttpd_style=/drive0/my_stylesheet.xslThat's an old feature, of course, but automatically using it now is the new one. -ml
#245133 - 28/04/2007 00:09
Here (attached) is a slightly hacked version of Cushman's Empeg Web Lite. Nothing wrong with his, but I wanted it to show the time-remaining on the display. Also, the year is not set on most of my tunes, so seeing () on the page was a bit annoying, and I removed that field altogether.
298416-default.xsl (161 downloads)
#245134 - 28/04/2007 00:48
Quote: Gahd the BBS Search is pitiful. Typing Empeg Web Lite into the search box doesn't find this page for me. But google.ca found it right away, so here I am again.
Immediately above the search box is the text:
Quote: (Default is any word, use + in front of words for all words searching)
So if you type in "+empeg +web +lite", the first result is this thread.
Also, not that it's documented on the same page -- you have to actually click on "Advanced search tips" to see it:
Quote: "Use quotes around a phrase to search for a phrase"
So typing in ""empeg web lite"" also has this thread as the first result.
Then again, just typing in "empeg web lite", without additional quotes or plus-signs, also results in this thread as the first in the list.
#245135 - 28/04/2007 02:07
Loc: Erie, CO
Hey Mark, ever go back and look at this request from a while ago? This was the next step to getting a list of currently playing tracks on the web interface. I was thinking about revisiting some changes I was hoping to make to the stylesheet, and your post got my attention. Also, the parens around the year parameter could be removed if the year was null. That would be fairly simple to do in the stylesheet.
#245136 - 28/04/2007 10:11
[Re: cushman]
Quote: Hey Mark, ever go back and look at this request from a while ago?
Oh, fooey! How did I ever forget about that one. All right, nag me again in a few weeks if the feature hasn't appeared by then.
Yeah, if I wasn't such a crappy javascript novice!
