#251013 - 15/03/2005 23:27
Re: set_empeg_max_fid (version 7 binary)
[Re: frog51]
I dunno where any speed difference would come from.
But "only 14000" tracks is plenty enough to benefit. If each track appears in two playlists, that's a shuffle of 28000 on down-down-down.. well past the previous player limitations here.
#251014 - 16/03/2005 07:50
It always seemed to pause and wait - when I had only a few tracks on and pressed down/down/down, I'd get the hourglass then it would go straight into the new playlist. With many tracks there would be a pause in the music, after a long period of time with the hourglass. Now the pause is gone again
#251015 - 16/03/2005 12:28
[Re: frog51]
If anything, it should be a tiny fraction slower if you've got a huge playlist. Before it'd truncate your playlist when it ran out of room but now the playlist area has grown so it will write more.
#251016 - 16/03/2005 12:58
[Re: tman]
wonder if it was truncating and getting upset about it before? I know sometimes after uploading new tracks the rebuild database would fail, and I'd need to pull power, wait for the empeg to do its long rebuild, then resync with emplode - that no longer happens (or has not yet, even though I added 200 tracks last night)
#251018 - 17/03/2005 22:26
[Re: Taym]
Mark, how can I do this? I am afraid I'm missing the proper command. I could do all up to that step. I have the set_empeg_max_fix.v7 in /empeg/bin/player , but then?
Just run the set_empeg_max_fix.v7 program (no args required).
But your original text worries me.. /empeg/bin/player is a file, not a directory. It's not possible to have set_empeg_max_fix.v7 "in /empeg/bin/player", unless the instructions messed you up somewhere..
#251019 - 17/03/2005 22:39
Sorry, I meant set_empeg_max_fix.v7 is in /empeg/bin/ But now I have my ftp client open on /empeg/bin . What should I type at the command prompt?
#251020 - 17/03/2005 23:10
[Re: Taym]
site rw
cd /empeg/bin
chmod 755 set_empeg_max_fix.v7
site exec /empeg/bin/set_empeg_max_fix.v7
site ro
site reboot
Edited by mlord (17/03/2005 23:10)
#251021 - 18/03/2005 00:11
Thank you thank you. I worked perfectly! Sorry, I also realized you had mentioned the SITE EXEC command before. Now that I think about it, is this also fixing the random-marked fids bug? Were those two issue related?
#251022 - 18/03/2005 00:51
[Re: Taym]
Quote: Now that I think about it, is this also fixing the random-marked fids bug? Were those two issue related?
Nope and nope.
#251023 - 17/04/2005 12:55
[Re: tman]
Hi Guys - I am new to this scene and have just bought an empeg and I have today managed to upgrade to 2 x 80Gb drives, I have read this thread numerous times and I dont seem to be able to get it into my thick skull, can someone please give me a basic step by step explanation on how to complete this. Also I have aquired an illumination Kit and I wondered if there was anyone in the UK who could do the fitting?
#251025 - 30/09/2006 17:18
[Re: Robotic]
Greetings! I am not quite sure what you mean by a "layman's" version, but will this help?
