#282463 - 06/06/2006 01:11
Sigbus Error?
Loc: Massachusetts,USA
Just got this Sigbus error today.Had to pull the player from sled to reboot.I have occasionally gotten the Segfault error and had to pull player to reboot also.All the errors occurred when starting car and player freezes at the static logo screen. Back in March I tried v3 alpha 11 for a few days but then went back to v2.0 final.I've always used Hijack,not sure what version I had on before I upgraded but probably one that didn't show the error.After I reverted back to 2.0 I put on hijack v448 which I guess is why I now see the errors.Although the player never locked up before I tried alpha11 Anyway,do I need to be concerned?I hate pulling the player that way as it pops the speakers.
MIKE 80Gb RIO
#282464 - 06/06/2006 01:53
Re: Sigbus Error?
[Re: newguy1]
You're right: It's only recent hijacks that show the error. The error isn't caused by hijack, it's just reporting them now.
I agree that locked up player software sucks because of that speaker-pop. Sometimes, even when the player software is locked up, you can still make the Hijack menu appear and select the "reboot machine" option to get the player to reboot nicely without needing to pull it and make the pop happen.
So. Back to the problem at hand: sigbus and segfault errors. These can be caused by:
- Running alpha software. Your best bet is to stick with 2.0 final or 2.0 beta 13.
- A specific bad MP3 file that screws up the decoder.
- Disk drive, IDE header, or disk cable trouble.
- RAM trouble.
- Other hardware trouble.
I'm guessing that the fact you're specifically getting a "sigbus" error indicates a certain kind of hardware trouble that others might be able to diagnose. But first give us a full boot log and a RAM test log. Instructions on how to do this are in the FAQ, search for Hyperterminal.
#282465 - 06/06/2006 23:49
Re: Sigbus Error?
Ok thanks Tony,It will take me a couple days but i'll get the info posted.
MIKE 80Gb RIO
#282466 - 08/06/2006 01:44
Re: Sigbus Error?
[Re: newguy1]
Well I took the player out of the car(it worked fine on my 45 minute drive home today)and connected it to AC power and the serial cable.Now I get the No hardrive found error and can hear the hardrive starting/stopping starting/stopping over and over. Anyway here are the logs
282788-Boot.txt (235 downloads)
MIKE 80Gb RIO
#282467 - 08/06/2006 01:44
Re: Sigbus Error?
[Re: newguy1]
Ram log.
282789-RAM.txt (198 downloads)
MIKE 80Gb RIO
#282468 - 08/06/2006 02:32
Re: Sigbus Error?
[Re: newguy1]
Yup, as you can see pretty clearly in the log, you've got one of the usual problems.
#282469 - 08/06/2006 09:28
Re: Sigbus Error?
I guess it possible,but support has already replaced the drive,the cable,and repaired the header.I don't remember exactly but maybe it was 2 years ago.I'll try it back in the car later today and see what happens.
MIKE 80Gb RIO
#282470 - 08/06/2006 11:08
Re: Sigbus Error?
[Re: newguy1]
If it is okay in the car, you might want to check to see if your AC power supply / wall wart is dying. Maybe it is not supplying enough power to keep the drives spinning...
Another thought, if you have one of Mark's docks, is to try it in there - that uses the DC power channel.
Edit: Note - this assume that it was working in the car. It was in one of your posts, but not in the first post. You might also just want to check to see if the hard drive cable worked loose from the connector due to use or vibration.
#282471 - 08/06/2006 23:39
Re: Sigbus Error?
[Re: pgrzelak]
It seems to work in the car fine.I've only had the sigbus/segfault errors about 5 times. I have the original home power supply that came with the player.When I plugged it in last night it wouldn't boot but tonite it did. here is the new boot log and new ram test.
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v448 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Thu Mar 16 19:43:10 EST 2006 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Found custom animation at offset 0x99380 Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004780). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xbbc4 -- FAILED ide_data_test: wrote 0xffff read 0xbbc4 -- FAILED ide_data_test: wrote 0xaaaa read 0xbbc4 -- FAILED ide_data_test: wrote 0x5555 read 0xbbc4 -- FAILED hda: FUJITSU MHR2030AT, ATA DISK drive ide_data_test: wrote 0x0000 read 0x045a -- FAILED ide_data_test: wrote 0xffff read 0x045a -- FAILED ide_data_test: wrote 0xaaaa read 0x045a -- FAILED ide_data_test: wrote 0x5555 read 0x045a -- FAILED hda: FUJITSU MHR2030AT, ATA DISK drive ide_data_test: wrote 0x0000 read 0x045a -- FAILED ide_data_test: wrote 0xffff read 0x045a -- FAILED ide_data_test: wrote 0xaaaa read 0x045a -- FAILED ide_data_test: wrote 0x5555 read 0x045a -- FAILED hda: FUJITSU MHR2030AT, ATA DISK drive ide_data_test: wrote 0x0000 read 0x045a -- FAILED ide_data_test: wrote 0xffff read 0x045a -- FAILED ide_data_test: wrote 0xaaaa read 0x045a -- FAILED ide_data_test: wrote 0x5555 read 0x045a -- FAILED hda: FUJITSU MHR2030AT, ATA DISK drive ide_data_test: wrote 0x0000 read 0x045a -- FAILED ide_data_test: wrote 0xffff read 0x045a -- FAILED ide_data_test: wrote 0xaaaa read 0x045a -- FAILED ide_data_test: wrote 0x5555 read 0x045a -- FAILED hda: FUJITSU MHR2030AT, ATA DISK drive ide_data_test: wrote 0x0000 read 0x045a -- FAILED ide_data_test: wrote 0xffff read 0x045a -- FAILED ide_data_test: wrote 0xaaaa read 0x045a -- FAILED ide_data_test: wrote 0x5555 read 0x045a -- FAILED hda: FUJITSU MHR2030AT, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2 e Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To Compěŕlayer redirected to /proc/ttyH Timezone: Atlantic/South_Georgia Hijack: intercepting config.ini khttpd: listening on port 80 kftpd: listening on port 21
And the new ram test.
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace... 0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com> 0100 ram test starting 0110 testing ic 1 (0-15mb, low word) 0120 testing ic 2 (0-15mb, high word) 01f0 ram test done 0200 ide detect 0210 command issued 0220 drive id FUJITSU MHR2030AT 02f0 ide ok 0300 dsp/i2c test 03f0 dsp/i2c ok 0400 temperature detect 0410 temperature is 00 04f0 temperature ok 0500 usb detect 0510 usb rev 1012 05f0 usb ok 0600 ethernet detect 0610 ethernet rev 334b 06f0 ethernet ok 0700 cs4231 detect 0710 cs4231 rev a0 07f0 cs4231 ok 00f0 tests complete
MIKE 80Gb RIO
#282472 - 09/06/2006 10:38
Re: Sigbus Error?
[Re: newguy1]
So sometimes the hard drive works (second log), and sometimes not (first log).
Time to check out the cable and connections.
#282473 - 10/06/2006 14:31
Re: Sigbus Error?
Quote: So sometimes the hard drive works (second log), and sometimes not (first log).
I unplugged and reconnected the cables but still got the IDE failure tests in the log. By coincidence I upgraded to hijack 461 from 448 and the IDE failures are gone.I downgraded back to 448 to see if failure notice was still there and it was.Then upgraded back to 461 and they were gone. Does that mean my drive is good or maybe on its way out?
version 448 log
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v448 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Thu Mar 16 19:43:10 EST 2006 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Found custom animation at offset 0x99380 Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005c80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED ide_data_test: wrote 0x0000 read 0xbbc4 -- FAILED ide_data_test: wrote 0xffff read 0xbbc4 -- FAILED ide_data_test: wrote 0xaaaa read 0xbbc4 -- FAILED ide_data_test: wrote 0x5555 read 0xbbc4 -- FAILED hda: FUJITSU MHR2030AT, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2 e Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: Atlantic/South_Georgia Hijack: intercepting config.ini
khttpd: listening on port 80 kftpd: listening on port 21 Using non-standard cache size 124 (adjustment 10) player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x407cd000 serial_notify_thread.cpp: 116:@@ N145 serial_notify_thread.cpp: 117:@@ F0x4cb0 serial_notify_thread.cpp: 118:@@ TDaughter serial_notify_thread.cpp: 119:@@ APearl Jam serial_notify_thread.cpp: 120:@@ GAlternative serial_notify_thread.cpp: 180:@@ #4cb0 0:01:17 serial_notify_thread.cpp: 170:@@ S0
version 461 log
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v461 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Thu Jun 8 15:00:28 EDT 2006 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e28cc001 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Found custom animation at offset 0x99380 Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005d80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xbbc4 ide_data_test: wrote 0xffff read 0xbbc4 ide_data_test: wrote 0xaaaa read 0xbbc4 ide_data_test: wrote 0x5555 read 0xbbc4 hda: FUJITSU MHR2030AT, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 Using non-standard cache size 124 (adjustment 10) player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x407cd000
MIKE 80Gb RIO
#282474 - 10/06/2006 14:40
Re: Sigbus Error?
[Re: newguy1]
No, the messages are still there, they just lack the "FAILED" text that I nuked from recent Hijack versions (see the changelog, if you like).
All that really matters is whether it finds the drive or not at the end of it all. It looks like sometimes it works, and sometimes it does not work. Flakey hardware. Changing the software won't help here.
Not likely at all. Much more probable is a bad connection somewhere, almost certainly on the cable crimps or the mainboard IDE header. Same as for 99.99% of all other cases of this happening to anyone else here.
#282475 - 10/06/2006 15:05
Re: Sigbus Error?
I did have the cable replaced and the header repaired by support.Don't remember exactly when but I guess the easiest is to try a new cable first or recrimp this one. With a properly working player what should the boot log look like(the part after probing primary interface)
MIKE 80Gb RIO
#282476 - 10/06/2006 15:38
Re: Sigbus Error?
[Re: newguy1]
The last log you posted above looks nice.
As long as the player works reliably, no need to fuss with it.
#282477 - 10/06/2006 16:12
Re: Sigbus Error?
Great,thanks for your help
MIKE 80Gb RIO
