#303030 - 13/10/2007 07:44
HD and Ethernet woes
My main player has been getting the 'No Harddisc' error more and more recently. I initally suspected the HD as it's been in since I first had the player and has had it's fair share of knocks and bumps. So I just bought a new 100GB drive and tried installing that. Now, it's been literally 'years' since I looked at the boot log or added any music to it. Upon connecting I found it had the following in the boot log: Code:
ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080
(I actually stole this from someone else's post so the numbers aren't the same) I also connected the ethernet up for the first time in a long time and found that inop too. A further inspection of the boot log revealed: Code:
smc chip id/revision 0x0249 smc_init couldn't find card
So it looks like it can't find the network chip. Could this arise from a dry joint or damaged pin on the IDE header? If so, does anyone have a part number for a suitable replacement header? I can get it replaced at work.
#303031 - 13/10/2007 10:45
Re: HD and Ethernet woes
[Re: andym]
1. When things fail, the exact numbers in the IDE data test boot log *matter*.
2. The header never needs replacing. But it often does need to be soldered down properly.
#303032 - 13/10/2007 13:20
Quote: 1. When things fail, the exact numbers in the IDE data test boot log *matter*.
In which case: Code:
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0x0000 ide_data_test: wrote 0xaaaa read 0x0000 ide_data_test: wrote 0x5555 read 0x0000
hda: FUJITSU MHV2100AH, ATA DISK drive
hda: FUJITSU MHV2100AH, 95396MB w/8192kB Cache, CHS=12161/255/63
#303033 - 13/10/2007 18:54
[Re: andym]
ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 .. ide_data_test: wrote 0xaaaa read 0x0000 ide_data_test: wrote 0x5555 read 0x0000
Okay, IDE bus is fine. Maybe post the entire boot log now, and we'll see about the other devices from that.
#303034 - 14/10/2007 09:35
Here we go..... Code:
On DC power, quick boot e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue Sep 4 09:18:20 EDT 2007 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: passed. c1100000: passed. c1200000: passed. c1300000: passed. c1400000: passed. c1500000: passed. c1600000: passed. c1700000: passed. c1800000: passed. c1900000: passed. c1a00000: passed. c1b00000: passed. c1c00000: passed. c1d00000: passed. c1e00000: passed. c1f00000: passed. c2000000: wrote ffffffff, read 00000000 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101731) 32MB DRAM Command line: mem=16m noinitrd Calibrating delay loop... 207.67 BogoMIPS Memory: 31232k/32M available (988k code, 20k reserved, 524k data, 4k init) Dentry hash table entries: 4096 (order 3, 32k) Buffer cache hash table entries: 32768 (order 5, 128k) Page cache hash table entries: 8192 (order 3, 32k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 32768 bhash 32768) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x99778 Tuner: loopback=1, ID=-1 Forced AC/Home mode show_message("Hijack v479 by Mark Lord") empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005480). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0x0000 ide_data_test: wrote 0xaaaa read 0x0000 ide_data_test: wrote 0x5555 read 0x0000 hda: FUJITSU MHV2100AH, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHV2100AH, 95396MB w/8192kB Cache, CHS=12161/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc_init couldn't find card Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 VFS: Mounted root (ext2 filesystem) readonly. Freeing unused kernel memory: 4k init Timezone: Atlantic/South_Georgia empeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To Com Starting player Timezone: Atlantic/South_Georgia
Using non-standard cache size 324 (bonus 16Mb, adjustment 0) player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. ! tags.cpp : 61:Failed to open tags (0xc0041002). Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4153a000
#303035 - 14/10/2007 14:29
[Re: andym]
Quote: Here we go..... Code:
... hda: FUJITSU MHV2100AH, 95396MB w/8192kB Cache, CHS=12161/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc_init couldn't find card ...
Okay, it mostly all looks normal except for that bit about the smc ethernet chip.
In your first posting, you wrote a different value for the "smc chip id/revision" line. Was that correct?
Does it now always give 0x3349 for you?
Here's the "normal" output from one of my Mk2a players:
Quote: Code:
hda: FUJITSU MHT2080AT, 76319MB w/8192kB Cache, CHS=9729/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:ea
The detection/initialization code (in linux/drivers/net/smc9194_tifon.c) is rather difficult for me to follow, so I'm not sure exactly why it first sees the chip (0x3349) and then later decides that there's no chip present (?).
But one could instrument that code (add a bunch of printk() lines to see exactly where it bops out) to get a better idea of what the trouble might be.
There's nothing definitive there yet.
Edited by mlord (14/10/2007 14:32)
#303036 - 15/10/2007 19:09
Yes, it always returns 0x3349 now. Must've been a typo, had to copy that bit over by hand.
Well, i've just got my empeg dev environment together and I've just sucessfully rolled and installed a new kernel (my version prints a swear word in the boot log). So I'll have a look at the code tomorrow and stick a load of printk()'s in.
#303037 - 17/10/2007 16:48
[Re: andym]
I'm wondering wether there is a fault with the IDE header.... This is what happens when I put the good disk on the other connector of the drive cable.... Code:
If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 (root@empeg-builder) (gcc version 2.95.3 20010315 (release)) #4 Mon Oct 15 05:04:35 PDT 2007 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: passed. c1100000: passed. c1200000: passed. c1300000: passed. c1400000: passed. c1500000: passed. c1600000: passed. c1700000: passed. c1800000: passed. c1900000: passed. c1a00000: passed. c1b00000: passed. c1c00000: passed. c1d00000: passed. c1e00000: passed. c1f00000: passed. c2000000: wrote ffffffff, read 00000000 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101731) 32MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 31232k/32M available (988k code, 20k reserved, 524k data, 4k init) Dentry hash table entries: 4096 (order 3, 32k) Buffer cache hash table entries: 32768 (order 5, 128k) Page cache hash table entries: 8192 (order 3, 32k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 32768 bhash 32768) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Tuner: loopback=0, ID=-1 show_message("Hijack v479 by Mark Lord") empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004100). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xff7f ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xff7f ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xff7f ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xffff ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xffff ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f Probing primary interface... ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xffff ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xfeff ide_data_test: wrote 0x5555 read 0xff7f empeg-flash driver initialized smc chip id/revision 0x3249 smc_init couldn't find card RAMDISK: Couldn't find valid RAM disk image starting at 0. VFS: Cannot open root device 03:05 Kernel panic: VFS: Unable to mount root fs on 03:05
#303038 - 17/10/2007 16:56
[Re: andym]
....and this with 2 disks.... Code:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 (root@empeg-builder) (gcc version 2.95.3 20010315 (release)) #4 Mon Oct 15 05:04:35 PDT 2007 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: passed. c1100000: passed. c1200000: passed. c1300000: passed. c1400000: passed. c1500000: passed. c1600000: passed. c1700000: passed. c1800000: passed. c1900000: passed. c1a00000: passed. c1b00000: passed. c1c00000: passed. c1d00000: passed. c1e00000: passed. c1f00000: passed. c2000000: wrote ffffffff, read 00000000 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101731) 32MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 31232k/32M available (988k code, 20k reserved, 524k data, 4k init) Dentry hash table entries: 4096 (order 3, 32k) Buffer cache hash table entries: 32768 (order 5, 128k) Page cache hash table entries: 8192 (order 3, 32k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 32768 bhash 32768) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Tuner: loopback=0, ID=-1 show_message("Hijack v479 by Mark Lord") empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004180). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0xd0d0 ide_data_test: wrote 0xffff read 0xd0d0 ide_data_test: wrote 0xaaaa read 0xd0d0 ide_data_test: wrote 0x5555 read 0xd0d0 hdb: FUJITSU MHV2100AH, ATA DISK drive ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xffff ide_data_test: wrote 0x5555 read 0xffff hdb: FUJITSU MHV2100AH, ATA DISK drive ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xffff ide_data_test: wrote 0x5555 read 0xff7f hdb: FUJITSU MHV2100AH, ATA DISK drive ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xffff ide_data_test: wrote 0x5555 read 0xff7f hdb: FUJITSU MHV2100AH, ATA DISK drive ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xffff ide_data_test: wrote 0x5555 read 0xff7f hdb: FUJITSU MHV2100AH, ATA DISK drive ide_data_test: wrote 0x0000 read 0xffff ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xffff ide_data_test: wrote 0x5555 read 0xff7f hdb: FUJITSU MHV2100AH, ATA DISK drive ide0: unexpected interrupt, status=0xff, count=1 ide0 at 0x000-0x007,0x038 on irq 6 hdb: FUJITSU MHV2100AH, 95396MB w/8192kB Cache, CHS=12161/255/63 empeg-flash driver initialized smc chip id/revision 0x3249 smc_init couldn't find card Partition check: hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4 RAMDISK: Couldn't find valid RAM disk image starting at 0. VFS: Cannot open root device 03:05 Kernel panic: VFS: Unable to mount root fs on 03:05
