Andy thanks for the link.
Below is the output. The last line says
Kernal panic: VFS: Unable to mount root fs on 03:05.
After doing a search, I saw
this post about that. Will this SSD not work?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v334 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sat Apr 26 10:31:47 EDT 2003
empeg-car player (hardware revision 9, serial number 30102262)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9a790
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TS128GPSD330, ATA DISK drive
hda: TS128GPSD330, 122105MB w/1kB Cache, CHS=15566/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:d
6
Partition check:
hda: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
