#374537 - 01/02/2025 22:09 Android Auto / AA Wireless suddenly not working on my car (VW GTI)
Haven't posted here in a while. Sorry about that. I need some extra brainpower to help debug / troubleshoot my phone talking to my car. This one's a real head-scratcher.
Up to this morning, everything worked just fine. 2017 VW GTI, AA Wireless (v1), running 3.5 firmware, Pixel 9 Pro phone running the latest Android 15 and Android Auto version 13.4.645054-release. I drove to see a friend for lunch, using all of the above and it all worked properly. Got back in the car (*), and then total haywire.
Blank screen in the car, occasionally popping up "Reading USB" but making no progress. On the phone, "Android Auto is searching for the car".
So I tried a bunch of troubleshooting. Plugged the phone directly into the USB for the car. Didn't work! Discovered that USB was in charge-only mode so switched it to allow for file transfer & Android Auto. Still didn't work! Tried using Bluetooth. And that's where things get weird.
Phone screen: "Problem connecting. Turn device off & back on"
Car screen: (After selecting my phone on the Bluetooth menu) "Pixel 9 / Unable to connect to mobile device. The device AA Wireless is already connected through Android Auto."
I tried all the remaining obvious things after that. I told the car to forget the phone. I told the phone to forget the car. I disconnected the AA Wireless box. I power cycled the phone and the car, multiple times. I redid the Bluetooth pairing. I did an upgrade from the 3.5 firmware to the newer 4.5 firmware. I tried the USB cable again. Nothing worked.
So, something is really messed up here. I'm particularly unsure how to interpret the message in the car's screen, refusing to connect to my phone. Somehow, my car has associated my phone's Bluetooth with the AA Wireless device, even though I had it completely disconnected at that time. Like it refuses to talk to my phone any other way. This issue persists even after powering the car and phone, both down and back up again.
I'm usually pretty good at this sort of troubleshooting, but this time I'm stumped. I even pulled the logcat from the phone, but I don't really know what I'm looking for, and there's nothing obvious jumping out at me.
(*) This is a stretch, but here's an additional detail that might matter. I took my car to a carwash. Everything was working correctly while I was waiting in line. After it came time to hand my keys to the staff, I turned the stereo off but the car was still on while they were working on it. I went inside, which means that my phone and my car were presumably in and out of radio range. After this, the haywire behavior began. So, it's possible that something about this situation triggered the bad state of affairs.
#374538 - 02/02/2025 12:21 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
When you "powered down" the car, did you disconnect the battery, then wait a few minutes, and reconnect it? Or did you just power off the radio? A battery disconnect would reboot all of the myriad computers in the car and possibly solve the problem or at least give a few more paths to investigate.
#374539 - 02/02/2025 15:02 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
This is a third party device?
#374540 - 02/02/2025 15:39 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
Powered down = turn car "off", then open the car door. This seems to cut power to most of the car's systems, e.g., turning off the stereo. I've let it sit overnight and will try again today. After some Google searching, it's also possible to hold down the power/volume knob for 10 seconds to force a reboot.
AA Wireless: if you have a car with USB Android Auto but not the newer Wireless Android Auto, this is one of the gadgets that's seen as a solid alternative. There's also a cheaper one from Motorola, which I originally had, but it flaked out and died.
Some additional background and then a few hypotheses:
The original Android Auto ran over USB. The idea was that your phone could take over the screen in your car. Also, there was some amount of extra metadata, like whether your headlights were on, as part of the protocol. At least with my car, one of the problems with this was that the physical USB connection became unreliable. I'd go over a bump and it would go blank for a second then reconnect.
The newer wireless variant is the solution. I don't entirely get how they managed this, but if you're in a car with wireless Android Auto, integrated from the factory, then the initial Bluetooth pairing process will (sometimes) also lead to a wireless Android Auto pairing. I believe it then uses local WiFi for moving the bulk data around. In other cases (rental cars are awesome), you do initial setup with a USB cable, and you get a Bluetooth pairing automatically. Subsequent times you get into the car, it's automatically using wireless Android Auto.
So, back to the AA Wireless box. They were originally an Indigogo solution to adding wireless Android Auto to cars, like my VW, which only had the wired version. Where the cheap Motorola adapter just does "pass thru" of the protocol, the AA Wireless software has a variety of toggles in it that explicitly work around bugs with different cars. So far as I can tell, it's the best solution to my problem, and it worked without issue, for years, until yesterday.
Anyway, enough background. I'm really curious about that error message I got on the screen in the car. "Pixel 9 / Unable to connect to mobile device. The device AA Wireless is already connected through Android Auto." When my AA Wireless is disconnected and yet I try to do a Bluetooth pairing, this still happens. The hypothesis I'm coming around to is that the VW headunit has some concept of Android Auto "overriding" Bluetooth from the same device, and it's gotten into a weird / buggy state where it can't recognize that the Android Auto connection ain't there. The test for this hypothesis is that I need to reset the head unit. Maybe that's just the ten-second press of the power button. Maybe that's disconnecting the battery. TBD.
#374541 - 03/02/2025 05:27 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
I also have the IOS equivalent, a third party wireless CarPlay puck connected to my 2017 Honda which doesn't have built-in wireless CarPlay.
I do believe that those things start with a brief bluetooth connection to the phone which then negotiates the handshake which hands off to the phone's wifi and drops the bluetooth connection. Not entirely certain about the way it works though.
If I understand it correctly, that AA Wireless device of yours is plugged into the car's USB port, correct? Mine needs the car's USB port. Basically it's a wireless puck which translates the wireless carplay communications into wired USB carplay communications.
The error message from the car thinks that your third party puck is still connected and it's still paired with it. Correct me if I'm wrong here... was your initial working connection this?
Car Stereo
Car Stereo's USB Android Auto Connection
AA Wireless Box
Your Phone's Wireless Android Auto Connection
And then something went wrong and it stopped working, so you tried to change it back to this:
Car Stereo
Car Stereo's USB Android Auto Connection (*)
Your Phone's Wired Android Auto Connection
And it still doesn't work because it's getting an error message saying that it thinks it's still joined to the AA Wireless Box. Am I reading the situation correctly?
If so, I think the error message is saying that the car stereo still thinks its USB AA connection is configured for that wireless box (*). See if you can find that connection and delete it.
The thing to remember is that this is all a completely separate thing from a bluetooth pairing. Simply telling the car to forget your bluetooth pairing isn't enough in this case, if I'm remembering correctly. You've got to dig in and find the AA pairing and delete that. I think.
You may have already tried this, so forgive me if I'm repeating something you already tried.
#374542 - 04/02/2025 00:42 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
You're absolutely correct. The car somehow thinks it's still paired with the AA Wireless dongle, even though I disconnected it. Very strange.
Now I just need to find a spare hour to dig deeper into the lore of factory resetting all the things.
#374543 - 04/02/2025 02:02 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
I don't think it needs a factory reset, in theory there might be a menu screen on the car which lets you delete the connection. It wouldn't be the same menu as the bluetooth one; if I recall correctly, in my car there's a separate section, different from bluetooth, under the "settings" menu labeled "Smartphone" or "Smartphone Connection" or something like that. Maybe you have a similar menu where you can delete the connection.
#374544 - 04/02/2025 13:49 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
This is what I was going to suggest
#374545 - 04/02/2025 13:50 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
Have you deleted and reinstalled the AA dongle?
#374546 - 04/02/2025 18:37 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
The AA dongle firmware has improved quite a bit since the early releases. I think our two of them now use "passthrough" mode, with better results than the earlier modes. Something to look at in the management app.
#374547 - 05/02/2025 21:37 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: mlord]
I've been using the "passthrough" mode. It's been substantially more stable than the earlier modes.
#374548 - 05/02/2025 21:38 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: tahir]
That's the problem. There's a menu option to delete Bluetooth connections, but there's no menu option to delete whatever kind of connection the AA dongle has with the car. That's why my next step is to dig into the unpleasant world of doing a factory reset on my head unit.
#374549 - 06/02/2025 10:41 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
Is it connected via USB? If so can you just unplug it?
#374550 - 06/02/2025 17:35 Re: Android Auto / AA Wireless suddenly not working on my car (VW GTI) [Re: DWallach]
For posterity, the solution:
First, I dug into the VW head unit menus. There's a "factory reset" menu with a bunch of choices. I reset the Bluetooth, the screen casting, and a few other things.
This was enough for my phone to work with Android Auto, over the USB cable. It wasn't enough to make the AA Wireless work.
The AA Wireless app troubleshooter walked me through some other steps, like deleting the Bluetooth pairing between the phone and car. None of this worked. So then I did a factory reset on the AA Wireless box, from within the app. This worked. After going through the setup process again, the phone and car now talk to each other.
Moral of the story: when things get weird, factory reset all the things.
