Page 2 of 2 < 1 2
#38977 - 27/09/2001 04:26 Re: Tuner Availability [Re: altman]
JaBZ
Loc: NZ
what is the avalibility of the Sleds? say in the near future...
I've convinced myself to order a Tuner and extra remote VERY soon,
however would'nt be able to afford a Sled at the moment as NZ has a SHOCKING exchange rate :)
cheers,
Jai
#38978 - 27/09/2001 04:38 Re: Tuner Availability [Re: JaBZ]
Sleds are currently in stock, and we have a pile of metalwork awaiting looms (which are on their way). I suspect that we'd post when sleds were getting low.
#38979 - 27/09/2001 06:35 Re: Tuner Availability [Re: teemcbee]
mardibloke
Loc: Penarth, UK
Mine arrived this morning, fitted over lunch break, its a radio, it works.
Rod , UK Mk2 64gig Red S/No.341
Rod, UK
#38980 - 27/09/2001 08:01 Re: Tuner Availability [Re: mardibloke]
tigloo
Loc: Hamburg, Germany
I received my tuner this morning, I am currently installing it (upgrading software as I post). I did not receive shipment confirmation or anything.
But I rather have a tuner without confirmation than a confirmation without a tuner! :)
Till
#38981 - 27/09/2001 08:40 Re: Tuner Availability [Re: tigloo]
mardibloke
Loc: Penarth, UK
I got shipment confirmation plus TNT tracking number - poor old Peter M must be working his socks off this week
Rod, UK
#38982 - 27/09/2001 10:40 Tracking airmail? [Re: mardibloke]
Ionic
Loc: Frankfurt, Germany
Anyone knows how and where to track "airmail"? Link would be fine...
Ciao
Frank
Mk2 40GB #090000592
Regards,
Frank
#38983 - 27/09/2001 10:51 Re: Tracking airmail? [Re: Ionic]
www.royalmail.co.uk and go to track & trace - but international recorded delivery has very little tracking information. It's really just regular mail with proof of delivery.
#38984 - 27/09/2001 15:59 Re: Tuner Availability [Re: mardibloke]
beaker
Loc: England
Got mine Tuesday. Installed it Wednesday (took all of 5 minutes). Decodes FM great even with a low signal (1 - 2 bars). Doesn't seem to get much on AM though. Isn't anyone transmitting on AM anymore in the UK? Ordered a Rio remote too since 'the announcement'. I just wish they'd left the Stun/Kill option on it .
Marcus (beaker)
32 gig (various colours)
#38985 - 28/09/2001 00:52 Re: Tuner Availability [Re: beaker]
Yes, 693/909 (5 live) in the UK should be ok. Note that if you have a powered antenna (VW/Audi bee-sting, for example) then you will get *nothing* on AM without an antenna power adaptor - this is the case in my new beetle.
#38986 - 28/09/2001 03:10 Re: Tuner Availability [Re: beaker]
tigloo
My tuner works great, too. I am a little surprised by the bad quality of the sound (even if there is full signal strength), but that might be due to the fact that I am not used to radio anymore. I will have to test against my Kenwood unit that I was using before.
The Empeg has not quite the same reception as my Kenwood, while the Kenwood was able to decode (both the music and the RDS) of stations with a low signal strength, the Empeg gets into a little bit of trouble.
However, this was just a few minutes of testing and weather conditions might have been non-ideal for such a test. :) I will use the unit some more next week (especially on the highway) and try to see how well it performs there.
Till
#38987 - 28/09/2001 03:29 Re: Tuner Availability [Re: beaker]
mardibloke
Loc: Penarth, UK
AM worked fine on mine, about 5 strong signals ( 5 live, Virgin, and a few local stations ), even parked alongside the house.
Rod, UK
#38988 - 28/09/2001 07:58 Re: Tuner Availability [Re: mardibloke]
beaker
Loc: England
Thanks for the replies guys. I've got a BMW with the antenna in the rear window. Don't know if it has an amp on it. It picks up FM fine so I don't think that this is the problem. I did manage to get Virgin but it was very faint & didn't show up on the signal strength meter at all. Could there be something wrong with the AM part of the circuit in the Tuner? I've been round all the frequencies several times but it's always the same. I do get a medium strength signal right at the bottom end of the range but it's just noise. The car's in for it's MOT until tomorrow so I can't fiddle until then.
Marcus (beaker)
Edited by beaker on 28/09/01 04:40 PM.
#38989 - 28/09/2001 08:54 Re: Tuner Availability [Re: beaker]
It's a powered antenna. My beetle picked up FM fine without power, but no AM; see:
http://www.autotoys.com/New_Tech/Misc_Info/bmwant/body_bmwant.htm
...it appears that there is a white antenna power wire in the BMW harness.
#38990 - 28/09/2001 11:31 Re: Tuner Availability [Re: altman]
beaker
Loc: England
aha!!!... Thanks Hugo. I'll have a look at this when I get the car back tomorrow. I guess the antenna is tuned more for the shorter wavelengths of FM than the longer wavelengths of AM, which is why it picks up FM reasonably well. Or am I talking complete b*ll*cks?
Marcus (beaker)
#38991 - 28/09/2001 18:43 Re: Tuner Availability [Re: beaker]
I've no idea, which is why I wasn't doing the tuner module's PCB design with its stripline track thingummies...
#38992 - 29/09/2001 07:37 Re: Tuner Availability [Re: altman]
beaker
Loc: England
OK, I got the car back from having new rear suspension bushes fitted & a new MOT. I've added the Tuner extension cable and joined the Blue flying lead to the White on the BMW loom and I can now receive AM fine. FM is also improved. Since your last reply I've taken another look at the installation instructions and it does mention that AM reception can be particularly affected where you have an antenna amp which doesn't have any power going to it. s'pose I shouldn't have been in such a hurry to get it fitted. Classic case of RTFM.
thanks again...
Marcus (beaker)
#38993 - 29/09/2001 14:14 Re: Tuner Availability [Re: altman]
andygjones
For anyone with poor reception you might want to try adding an amplifier if your car doesnt have one. I live in a pretty bad area for most stations but bought a little booster from Maplin (£7.99) - reception is a lot better and im able to pick up a lot more stations. Very simple to fit. Just a small pen-sized unit that plugs in between your tuner module and the antenna cable, and connects to the tuner's power feed.
RioCar 10GB RGB - can never decide
RioCar 40GB RGB - can never decide
#38994 - 01/10/2001 03:18 Re: Tuner Availability [Re: rob]
AndyGuy
Has any Mk1 client got an email about this yet? I haven't.
Andy.
#38995 - 01/10/2001 05:24 Re: Tuner Availability [Re: AndyGuy]
Geoff
Loc: Northern Ireland
I received my tuner module last Friday, the only email I got was the one telling me it had been dispatched (apart from the email Rob sent a month or two ago saying they were available, but on the wrong side of the Atlantic!)
Geoff
Got one of the first Mark 2 empegs...
Geoff
Mk1 Blue - was 4GB, now 16GB
Mk2 Red - was 12GB, now 60GB
#38996 - 02/10/2001 04:34 Re: Tuner Availability [Re: Geoff]
Happy Birthday Taym
Wow, I got my tuner yesterday. Can't believe it. Finally! I'll install it in the weekend and post my impressions.
MK II BLUE/RED 12GB #923
Page 2 of 2 < 1 2
