#43884 - 27/10/2001 04:13 Dimmer control
thinfourth2
I love the new cycling through the sound controls with the push of the rotary control but up here in the north where it takes a long time to get dark can we have so that after the sound controls i can get the dimmer control to tweak the display in hours of almost darkness
#43885 - 27/10/2001 04:56 Re: Dimmer control [Re: thinfourth2]
muzza
Could you connect the dim sense line to a switch on the dash?
#43886 - 27/10/2001 10:10 Re: Dimmer control [Re: muzza]
thinfourth2
Okay maybe you have got the wrong end of the stick here.
What i would like is so that i can access the dimmer easily as Dusk lasts about 2 hours here being so far north so there fore you have to drive around with your lights on when it isn't fully dark so my normal setting for the dimmer when it is dark is about 10% but at dusk i have it at about 80% so instead of going through the menus i would like just to cycle up to it.
I have the light sense connected so it does go onto the lights on setting when i turn on the head lights it would just be nice to be able to reach it quckly for tweaking.
And while i am at it i still want a awake up timer when it is in home mode for when i am on the ship with it. I don't need it in the car but in the home so hopefully there is no complicated power issues.
Please
#43887 - 27/10/2001 11:08 Re: Dimmer control [Re: thinfourth2]
Another solution compaired to having easier dimmer settings would be to erect a giant mountain range to the west of you, thus making the sun set earlier and higher in the sky. This would elliminate your need for changing the dimmer
I live near the foot of Pikes Peak, and I didn't realise the benefits of this particular issue until a drive in L.A. around sunset while heading west. I'm also not someone who wakes up early enough to deal with it when it's rising, so it all works out. The fun thing is that due to the fact that the sun appears to set in different places over the year, we get several more minuets of sunlight in the summer time, due to the sun setting over some of the lower parts of the mountain range, and not near the peak of Pikes Peak in the winter time.
#43888 - 27/10/2001 16:27 Re: Dimmer control [Re: drakino]
muzza
The other option may be to wire the dimmer line on the headlight wire. Then only when it is dark enough for you to need headlights, the dimmer activates
#43889 - 27/10/2001 17:41 Re: Dimmer control [Re: muzza]
beaker
Loc: England
What would be really cool (but totally OTT) would be either a Phototransistor or LDR and A/D converter and RS232 out into the RS232-in on the player and some software to alter the dimmer setting according to the ambient lighting conditions. I'm sure someone here could come up with a design for one .
#43890 - 27/10/2001 19:07 Re: Dimmer control [Re: muzza]
The problem is that he turns his headlights on before sunset, thus he wanted an easier way to get to the dimmer settings.
Another way that could work is a time based dimmer program. I'm sure something like this could be hacked in from the kernel or userland, and set up to set the dimmer at 80% at 6:00, then %50 or whatever at 7:00 pm. If someone was really creative, they could allow a list of sunrise/sunset times to be entered, and base it off that
If only I could program at the level needed to do this...
#43891 - 27/10/2001 23:42 Re: Dimmer control [Re: drakino]
jarredduq
Loc: California, USA
I second that, it would be very cool for the dimmer to be controled by the time. Since I like to turn my headlights on in the daytime, the auto dim function does not work for me.
#43892 - 28/10/2001 03:43 Re: Dimmer control [Re: jarredduq]
thinfourth2
I just want a nice simple extra button press to let me get at the dimmer Please
A timed auto dim would be great but it would need to be tweakable as in summer it gets dark about 11pm and in winter it gets dark about 5pm and if there is any empegs residing further north i am sure they agree
#43893 - 28/10/2001 04:18 Re: Dimmer control [Re: thinfourth2]
beaker
Loc: England
That's why I came up with the ambient lighting level controlling the brightness of the display idea.
#43894 - 28/10/2001 13:52 Re: Dimmer control [Re: thinfourth2]
mtempsch
Most definately!
I'm still thinking about how to wire my dimming line. As it comes in my VW Polo (see http://www.tempsch.org for install prOn) the line appears to be connected to the potentiometer that controls the instrument cluster lighting level. It varies between apprx. 2 to 12V, higher if brighter. That wouldn't be a problem if it weren't for the fact that this line always is active as the dipped beams are automatically turned on with the ignition (by law we have to have dipped beams on even in full sunlight) though with reduced power.
The main light switch has 3 positions, Auto, Off and On. In auto the dipped beams come on as described above, and you can't turn on full beam - only flash them. In Off, only parking lights are on. In On you get full power dipped beams and the ability to turn on full beam...
As it gets darker I turn the switch to On - and this is when I'd like the empeg to dim, no time else. I figure my best bet is to find a pin in the switch that does what I need and rewire the dimming line to that...
If anyone has any other idea, please let's hear it.
#43895 - 29/10/2001 05:46 Re: Dimmer control [Re: jarredduq]
Happy Birthday Taym
I second that too! That's exactly the reason why I always have dim at maximum: I often go withj headlights on during the day, having the dim depend on the headlights is totally useless for me.
#43896 - 30/10/2001 07:08 Re: Dimmer control [Re: drakino]
Dearing
Loc: Florida
How about a kernel mod like mlord's menus that has a Dimmer selection that you can change with the knob/vol+- buttons? Mcomb, mlord, is this doable?
_~= Dearing =~_
#43897 - 30/10/2001 14:44 Re: Dimmer control [Re: Dearing]
mcomb
Loc: San Carlos, CA
I am not sure how I got included in this question since I don't really speak C well enough to do anything more than compile other peoples patches, but... there is a function called display_sendcontrol in empeg_display.c that appears to be intended to set the display brightness (among other things). I assume it would be pretty simple to call this function from one of mlord's menus to adjust the brightness.
Personally I don't see it as being worth the trouble though. It would only save a button press or two from doing it through the empeg settings menu. If someone is going to go to the trouble of coding this why not do it right and calculate sunset time and duration based on date and longitude/latitude and then fade the display from a max setting to a min setting during that time?
-Mike
#43898 - 30/10/2001 15:18 Re: Dimmer control [Re: mcomb]
Dearing
Loc: Florida
Firstly, it would allow for dimmer control in situations where we don't have it now. ie, Mark 1 players and Mk2's in the home. Do we really NEED dimmer control at home? Probably not.
Either way, user control of that dimmer setting would probably get done faster and more to the users' liking if we don't have to wait for the Empeg team to do it.
Maybe there could be a text file in /empeg/var or something with various times-of-day and their respective dimmer setting. This file could even be modified depending on the date or something. I'm just trying to justify this wish, but it would probably never be REALLY needed - just another cool user hack.
Edit: The lack of dimmer in the Mk1 is a hardware limitation, isn't it?.....if so, nevermind about the Mk1.
Edited by Dearing (30/10/2001 15:20)
_~= Dearing =~_
