#55117 - 04/01/2002 19:45 Queuing Question
Happy Birthday Micman2b
Loc: Central, NC, USA
How do you que the next playlist of songs when you have a playlist on the Empeg already running? Is this possible?
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
#55118 - 04/01/2002 19:48 Re: Queuing Question [Re: Micman2b]
Dang I should have 'spell checked' that one...
Repaired the previous posting properly
Edited by Micman2b (04/01/2002 20:20)
_____________
Sean in NC
#55119 - 04/01/2002 19:52 Re: Queuing Question [Re: Micman2b]
if you are running the 2.0 beta you can by browsing to the next list you want to play and press and hold the knob then a menu will come up it insert, append, and replace select append and that's it.
if you still have the software version (1.02 or 1.03 ?) that came on the player you can't do this
#55120 - 04/01/2002 20:19 Re: Queuing Question [Re: msaeger]
Hmmm. Maybe I should figure out why 2.0 beta7 does not see the Empeg on WinblowsMe/usb...
_____________
Sean in NC
#55121 - 04/01/2002 21:33 Re: Queuing Question [Re: Micman2b]
Maybe you should use ethernet, because my brother's ME also won't see his new player over USB (I upgraded it to b7 last night).
#55122 - 06/01/2002 10:09 Re: Queuing Question [Re: hybrid8]
So then I have a silly question, Can you just connect the cat5 cabling from the ethernet connector on the Empeg to the ethernet card on the computer without using a hub?
_____________
Sean in NC
#55123 - 06/01/2002 10:14 Re: Queuing Question [Re: Micman2b]
Yes you can if you're using a crossover cable. I used to go about it that way before I got my hub.
#55124 - 06/01/2002 13:13 Re: Queuing Question [Re: Micman2b]
thinfourth2
That is what i do with mine when at the girlfriends or using laptop and i even have one threaded through the car into the back of the empeg when it is in the car.
#55125 - 06/01/2002 13:29 Re: Queuing Question [Re: Micman2b]
bonzi
Yes, but it has to be a crossover cable. Search a bit the BBS and you will even find how to crimp one yourself (along with advice not to, but to buy a pre-asembled one, but not in Raadio Shack ) See also FAQ.
Ah, yes, see this post and attachment to this one.
Edited by bonzi (06/01/2002 13:35)
#55126 - 06/01/2002 13:39 Re: Queuing Question [Re: bonzi]
Gracias.
_____________
Sean in NC
