#55578 - 06/01/2002 08:07 Hijack v103 and Button 4
LTJBukem
Just installed Latest Version of Hijack.
Button 4 on the Rio Remote pops the QuickTimer. Probably useful as of course there is no functionality tied to this button.
However, when in Search by Title, the Quick Timer still kicks in when hitting Button 4 meaning that g,h,i cannot be used in any searches. Real Pain !
Can anyone help ?
LTJ
#55579 - 06/01/2002 08:23 Re: Hijack v103 and Button 4 [Re: LTJBukem]
kojak71
Button 4 is use to mark a track (using 2.00b7). Installed v103 of Hijack afterwards, and button 4 functionality is retained, i.e. I can do searches and it doesn't pop the QuickTimer
#55580 - 06/01/2002 08:42 Re: Hijack v103 and Button 4 [Re: LTJBukem]
LTJBukem
Am I missing something somewhere.
I just used Emplode b7, to put back the base version of Dev b7 for the player. Then added v103 of Hijack and it still does the same ?
Do I need to downgrade, then upgrade, then add Hijack? And can I do the downgrade and upgrade both from b7 of Emplode ?
LTJ
#55581 - 06/01/2002 09:52 Re: Hijack v103 and Button 4 [Re: LTJBukem]
kojak71
Try getting it back down to 1.03, then upgrade to 2.00b7. You should ensure that everything works ok (including the 4 button) beofre uploading Hijack using LogoEdit's kernel flash utility
#55582 - 06/01/2002 09:56 Re: Hijack v103 and Button 4 [Re: kojak71]
Happy Birthday bonzi
Maybe it should be made even more clear in the FAQ that up/down-grading complete empeg SW and uploading a kernel are two very different things. I see that several users have it mixed up.
#55583 - 06/01/2002 10:31 Re: Hijack v103 and Button 4 [Re: LTJBukem]
LTJBukem
Right,
I have downgraded to b3 and the 4 button worked fine.
Upgraded to b7 and 4 button still worked fine,
Added Hijack v103 and the Quick Timer kicks in again when searching.
I'm using the Rio Remote and its a Mk2a not other patches applied
Please help ... realistically I only want to use VolAdj with the Menu Options switchable Off, Low, Medium, High. The rest of the facilties I can manage without for now.
LTJ
#55584 - 06/01/2002 10:40 Re: Hijack v103 and Button 4 [Re: LTJBukem]
kojak71
How did you upload Hijack onto your eMpeg?
#55585 - 06/01/2002 10:42 Re: Hijack v103 and Button 4 [Re: kojak71]
LTJBukem
Using the Kernal Flash Utility in LogoEdit.
Everything else in Hijack seems to work fine apart from this one annoyance.
LTJ
#55586 - 06/01/2002 10:53 Re: Hijack v103 and Button 4 [Re: LTJBukem]
kojak71
Scratches head...............
...............you are using the right image of Hijack?
Total voodoo now, but I would downgrade to 1.03 first and then upgrade to 2.00b7 (consumer). Generally you shouldn't use beta software when trying to iron out problems.
#55587 - 06/01/2002 12:58 Re: Hijack v103 and Button 4 [Re: kojak71]
beaker
Loc: England
I've just upgraded to the latest Hijack (v103) and I'm getting exactly the same symptoms, Quicktimer pops up when entering search criteria using the '4' button.
#55588 - 06/01/2002 15:03 Re: Hijack v103 and Button 4 [Re: beaker]
muzza
which remote are you using? Kenwood or Rio?
#55589 - 06/01/2002 15:20 Re: Hijack v103 and Button 4 [Re: muzza]
beaker
Loc: England
Rio, but I've just tried it with the Kenwood and it does the same.
#55590 - 07/01/2002 03:03 Re: Hijack v103 and Button 4 [Re: beaker]
LTJBukem
Well i'm glad its not just me !
Any one else got any ideas ? tfabris / mlord ?
Many Thanks
LTJ
#55591 - 07/01/2002 03:55 Re: Hijack v103 and Button 4 [Re: LTJBukem]
LTJBukem
For everyone who had the same problem as me .... (one of you ?), this is now FIXED, using Hijack v107
Button 4 now works as expected in searches.
Thanks Mr Lord
LTJ
