Page 4 of 4 < 1 2 3 4
#59032 - 17/01/2002 11:57 Re: Hijack v131 (soon) [Re: andy]
mandiola
I never removed the button catch. So when you click a button it still goes to that frame. It saves a lot of problems. So that doesn't need to be changed for v130. I'm looking into other was to show the empeg screen since updateing the picture the way im doing it now is kind of obnoxious since its choppy and makes the mouse point go crazy. Hopefully I'll get something out tonight since this seems like something people are enjoying. I think i'll also setup a webpage, unless (Mark) you want to set me up someway I can put it on the page with Hijack since they do go hand in hang ; ) I got to go to work and network an office so i'll work on it when i get home.
-Greg
#59033 - 17/01/2002 12:44 Re: Hijack v129 [Re: mlord]
Diznario
Loc: Portland OR
heh heh... sounds cool.
I'm a little busy at work today... I'll try it when I get home tonight.
So... Where exactly is it going to spit out the debug info...? I'm guessing it makes some log file somewhere?
Dario
MK2 in an Impreza 2.5RS
#59034 - 17/01/2002 14:52 Re: Hijack v129 [Re: mlord]
crazymelki
Loc: Switzerland
I think I found finally the bug. First I did try the empegweb with Linux. There is the app. really working well.
But I deleted in the index.html the line with the ftp info and then it works.
bye
crazymelki.com
#59035 - 17/01/2002 19:43 Re: Hijack v131 (soon) [Re: mandiola]
If you want to visit http://sourceforge.net/ and create a userid for yourself, then I can add you to the "empeg-hijack" project to give you direct access to the directories there..
Or you can find another home for your wonderful hack, and I'll put a prominent link for it onto the hijack site.
#59036 - 17/01/2002 20:15 Re: Hijack v129 [Re: mlord]
Diznario
Loc: Portland OR
Or you could try connecting up your serial port, setting [hijack] kftpd_verbose=1 in config.ini, and then running ftp again, and sending me some useful diagnostics.
Well, I'd love to do that, but I can't seem to figure out how. I'm at a loss here... I made the config.ini change, but where does it output the debug info? Is there a log file somewhere or something? I can't seem to find it... Do I need to be using the dev image?
Also, I tried the command line version of FTP, and that works fine. It's only the IE6 FTP that's having the trouble. I just tried Hijack v133 too, and same thing. IE hangs immediately...
Dario
#59037 - 17/01/2002 21:41 Re: Hijack v129 [Re: Diznario]
The debug output will appear on the serial line, which you can connect to with kermit, cat, or even hyperterminal, and it will show exactly what the issue is with your FTP client not liking Hijack.
#59038 - 17/01/2002 23:54 Doh! [Re: mlord]
Diznario
Loc: Portland OR
*Me shoots self*
ok... I should have been able to figure that one out. I blame it on the fact that I've been sicker than snot for the past week...
Anyway, here ya go...
kftpd: connection from 192.168.0.42
kftpd: 220 Connected.
kftpd: 'USER anonymous'
kftpd: 230 Okay.
kftpd: 'opts utf8 on'
kftpd: 500 Bad command.
kftpd: 'syst'
kftpd: 215 UNIX Type: L8.
kftpd: 'site help'
kftpd: 216-The following SITE commands are recognized
BUTTON CHMOD HELP POPUP REBOOT RO RW
216 Okay.
Bad mode in prefetch abort handler detected: mode SVC_32
Vectors:
00000000: ef9f0000 ea0000cd e59ff3d0 ea0000bb ea00009a ea0000ea ea000078 e3a0c0
04
00000020: e58bc018 e5dac000 e5dad000 e18cc40d
f8
Stubs:
00000200: e59fd1dc e24ee004 e58de000 e14fe000 e58de004 e3a0d093 e161f00d e20ee0
0f
00000220: e79fe10e e1b0f00e c0009e20 c0009bc8 c0009bc8 c0009ce0 c0009bc8 c0009b
c8
00000240: c0009bc8 c0009bc8 c0009bc8 c0009bc8 c0009bc8 c0009bc8 c0009bc8 c0009b
c8
00000260: c0009bc8 c0009bc8 00000000 00000000 00000000 00000000 00000000 000000
00
00000280: e59fd164 e24ee008 e58de000 e14fe000 e58de004 e3a0d093 e161f00d e20ee0
0f
000002a0: e79fe10e e1b0f00e c0009de0 c0009bb4 c0009bb4 c0009c80 c0009bb4 c0009b
b4
000002c0: c0009bb4 c0009bb4 c0009bb4 c0009bb4 c0009bb4 c0009bb4 c0009bb4 c0009b
b4
000002e0: c0009bb4 c0009bb4 00000000 00000000 00000000 00000000 00000000 000000
00
00000300: e59fd0e4 e24ee004 e58de000 e14fe000 e58de004 e3a0d093 e161f00d e21ee0
0f
00000320: 059fe004 159fe004 e1b0f00e c0009ee0 c0009ba0 00000000 00000000 000000
00
00000340: e59fd0a0 e58de000 e14fe000 e58de004 e3a0d093 e161f00d e20ee00f e79fe1
0e
00000360: e1b0f00e c0009e80 c0009bdc c0009bdc c0009d60 c0009bdc c0009bdc c0009b
dc
00000380: c0009bdc c0009bdc c0009bdc c0009bdc c0009bdc c0009bdc c0009bdc c0009b
dc
000003a0: c0009bdc 00000000 00000000 00000000 00000000 00000000 00000000 000000
00
000003c0: e25ef004 eafffffe 00000000 00000000 00000000 00000000 00000000 000000
00
000003e0: c000a000 c0102960 c010296c c0102978 00000000 00000000 00000000 000000
00
00000400: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffff
ff
00000420: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffff
ff
00000440: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffff
ff
00000460: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffff
ff
00000480: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffff
ff
000004a0: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
Internal error: Oops: 0
CPU: 0
pc : [<4f4f4244>] lr : [<00000072>]
sp : c0441f88 ip : c0103cc4 fp : 00000000
r10: 000000d8 r9 : 00000000 r8 : 52202020
r7 : 5055504f r6 : 50202020 r5 : 20504c45 r4 : 48202020
r3 : 00000000 r2 : 00000072 r1 : c08421d0 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process kftpd (pid: 24, stackpage=c0441000)
Stack:
c0441fc0: 00000072 4f4f4244 60000013 ffffffff 52202054 2020204f 52202020 320a0d
57
c0441fe0: 4f203631 2e79616b c0000a0d c00fc5c4 c00cf334 c00cf3c0 c00cf334 c000b4
44
Backtrace: no frame pointer
Code: pc not in code space
Dario
#59039 - 18/01/2002 03:02 Re: Hijack v129 [Re: Diznario]
IE6's FTP client is terrible. Just use any other FTP client fro W32 platforms. My favorite's SmartFTP, and that's free. There are dozens out there, a lot of them are free, and all of them are better than IE6's built-in one. IE6 is a great browser, I believe, but a really really poor ftp client.
#59040 - 18/01/2002 04:01 Re: Hijack v130 [Re: mlord]
Any chance of getting hijack menu options for these mount options now that the commands themselves are in the kernel?
#59041 - 18/01/2002 07:27 Re: Doh! [Re: Diznario]
For that backtrace to have any meaning, I also need to know exactly which Hijack version was installed at the time of the crash..
#59042 - 18/01/2002 07:33 Re: Doh! [Re: mlord]
Never mind.. found it. Buffer too small for new response_table[] code in ftpd.. only crashes if you use the HELP or SITE HELP commands.. Doh!
Fixed in the forthcoming v135.
#59043 - 18/01/2002 09:45 Re: Doh! [Re: mlord]
Diznario
Loc: Portland OR
heh... I was just going to say, nevermind, it's fixed in 135...
Dario
#59044 - 18/01/2002 09:54 Re: Hijack v129 [Re: Taym]
Diznario
Loc: Portland OR
Heh, you can say that again. I've never tried SmartFTP, but I think any FTP client has to be better than their built in one. I used CuteFTP back in the day, and I loved that app. Haven't gotten around to installing it on this system yet...
Dario
#59045 - 18/01/2002 10:56 Re: Doh! [Re: mlord]
crazymelki
Loc: Switzerland
And now it works for me also with V135 and IE 6.0!
thanks a lot.
crazymelki.com
#59046 - 20/01/2002 02:30 Re: Hijack v124: kftpd & khttpd stuff [Re: mlord]
silmonkey
Loc: Redmond,WA
Kind of off topic. forgive me please, but I was browsing earlier and was reading about someones proposal to MLord to make a "file writable area". A thought is that possibly I could use the XML dump option in emplode and dump this file and move it to the root and use a XSL to make it queue software that writes to the "file writable area" that of course is assuming we could possibly play song by fid? just a thought though?
silmonkey
MKIIa 30gb
#59047 - 21/01/2002 23:18 EtherFlash with Hijack [Re: silmonkey]
mandiola
I wrote a small program in vb that connects to the empeg and then flashes the hijack kernel to the one you choose through ftp. I still have a little bit of work left on it to make it more user friendly. I need to add 2 things to it. Does hijack have any ftp calls that will (1) pause the player and (2) reboot the player? I have it so that it dectects to see if the player is flashed first, but then i need it to reboot it... and more importantly, pause the player before it tried to flash it to make everything work faster.
-Greg
#59048 - 22/01/2002 09:11 Re: EtherFlash with Hijack [Re: mandiola]
Your script should do something like this:
site popup 999 Downloading new kernel
binary
put v137.hijack...zImage /proc/empeg_kernel
site popup 2 Done
site reboot
You could also try using "site button 20df16" to pause the player, but since the "pause button" is actually a toggle "pause/play", it's kinda difficult to guarantee success that way.
#59049 - 22/01/2002 14:49 Re: EtherFlash with Hijack [Re: mlord]
mandiola
Hmm... site doesnt work for me.. can't do site popup.
-Greg
#59050 - 22/01/2002 14:57 Re: EtherFlash with Hijack [Re: mandiola]
Happy Birthday bonzi
On which version of HiJack? Works for me on 136.
#59051 - 22/01/2002 14:58 Re: EtherFlash with Hijack [Re: bonzi]
mandiola
Just in general.. im trying to send it through a dos ftp for testing.
-Greg
#59052 - 22/01/2002 15:07 Re: EtherFlash with Hijack [Re: mandiola]
Same here. It's just that features get introduced, improved, broken, fixed again, and all site commands (and others, for that matter) I tried seem to work in 136.
#59053 - 22/01/2002 15:11 Re: EtherFlash with Hijack [Re: bonzi]
mandiola
Ahh i got it... forget that windows ftp needs literal in front of it ; )
-Greg
#59054 - 22/01/2002 15:51 Re: EtherFlash with Hijack [Re: bonzi]
mandiola
Hmm.. vb doesn't like literal nor just plain old SITE. Im using inet control and it works for PUT but nothing else. Any suggestions.
-Greg
#59055 - 22/01/2002 16:11 Re: EtherFlash with Hijack [Re: mandiola]
Hm, I was using cmd-line FTP client that comes with Cygwin (port of bash shell, gcc and assorted *ix utils to Win), and it works OK. The client that comes with Win98 does not seem to support SITE command at all (HELP does not list it).
A GUI ftp front end (LeechFTP) I sometimes use lets you issua arbitrary command, so SITE works there, as well.
Try to search around for free full implementation of command-line client (or download LeechFTP - I don't remember where I found it - TwoCows perhaps?). Sorry, I have nothing more helpfull...
#59056 - 22/01/2002 16:39 Re: EtherFlash with Hijack [Re: bonzi]
Nosferatu
Loc: France, Champagne
Here is the link to LeechFTP free , and best FTP freeware avalaible in many languages :
LeechFTP
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#59057 - 22/01/2002 16:41 Re: EtherFlash with Hijack [Re: Nosferatu]
mandiola
I think you guys are missunderstanding what im doing. Im writing a program that lets you quickly update the kernel through ethernet. All I have left is to display whats happening and make the empeg reboot, otherwise it works perfectly.
Im not having problems uploading or anything like that.
-Greg
#59058 - 22/01/2002 21:49 Re: EtherFlash with Hijack [Re: mandiola]
mandiola
OK. Still havn't gotten EtherFlash to send what its doing to the empeg screen. I am going to post everthing at: http://www.empeg.tk in a few minutes. I will put up my empegweb and this EtherFlash that I've been working on + the source. So if anyone can get it to show up on the screen let me know. Its a really simple program I wrote in a few minutes.
-Greg
#59059 - 22/01/2002 23:20 Re: EtherFlash with Hijack [Re: mandiola]
charcoalgray99
I know a little vb. Instead of using the inet control, you could use the socket control and just send the raw commands. That would allow you to use SITE.
Tom
