#80918 - 20/03/2002 11:48
Re: Tempermental No Hard Disk
[Re: skamp]
Well I guess I spoke too soon. It happened this morning. It was about 60* when I started my car so I do not think that temperature is the problem. So after that I drive to work, and went out for lunch and it works fine. I really don’t se any pattern of when and why it happens. I think I will go back to 1.03 and see what happens.
Steve
#80919 - 20/03/2002 12:25
[Re: skamp]
Loc: MI, USA
have you even tried contacting support for a new cable?
guardian__J MKIIa 20g Smoke
#80920 - 20/03/2002 13:26
[Re: skamp]
Yes, I already installed a new cable and that did not make a difference.
Steve
#80921 - 20/03/2002 14:22
[Re: skamp]
Loc: MI, USA
sorry....I didn't read the whole thread...
I know I haven't had an issue with mine since I got a new cable...
have they offered to have you send it in for support?
#80922 - 20/03/2002 17:34
[Re: guardian__J]
I have not asked. I don't think it is a hardware problem. Like I said the problem only happened after updating from 1.03 to 2.0BXX. I think I am going to backrev and see what happens.
Steve
#80923 - 25/03/2002 11:59
[Re: skamp]
Loc: San Jose, CA
I backreved to 1.03, it worked fine all yesterday, and this morning the same thing happened, no boot up. Like many have mentioned, after a few hours in the sun I bet the unit will start up again.
#80924 - 25/03/2002 16:20
[Re: njdboy]
Loc: San Jose, CA
So I just went to the post office, and the empeg booted just fine. It was outside in my car the whole day at work, and the car was warm. Leads me to lean more in favor of the Fujitsu theory that the drives are sensitive to weather, or weather changes. If anyone has anything else to add, please do, it will help a lot of us out with Fujitsu drives. Just trying to make sense of all of this and pinpoint the problem.
#80927 - 26/03/2002 10:40
[Re: drakino]
Loc: San Jose, CA
good to hear yours is working out. I brought mine in last night, thinking maybe my underground garage is cold for some reason. I had it in my apartment the whole night, where I have the heater on to 68-70 degrees. But again this morning in my car it wouldn't boot. The madness never ends. If history repeats itself, when I leave work the player will be back to normal.
#80928 - 26/03/2002 14:13
[Re: tracerbullet]
How do we tell what drives are installed?
Previously in this thread Mark Lord said:
If you use HTTP to surf to /proc/ide/hda/model on your player, it will tell you the brand/model of hard drive.
Or remove the lid to read the label.
#80929 - 27/03/2002 19:24
[Re: mtempsch]
I have two IBM drives and it happens to me. It happened today. I left to go get food and got the no hard disk, contact support message. I unplugged and replugged for a few minutes with no luck. I ran in got my food and fired up my car and the empeg worked like a champ. It is around 60-75 today so I don't think it is temp related. Has this happened to anyone with just 1 drive? It may be a timing issue? Also for people who have not read my previous posts, yes I have tried a new cable.
Steve
#80930 - 28/03/2002 10:20
[Re: skamp]
Loc: Utah, USA
When this happens to me, I get the feeling that it's an issue with the drives not spinning up fast enough. I can unplug it and replug it without success. But, if I reboot from the Hijack menu it works every time.
I'm guessing that rebooting rather than unplugging allows the drives to remain spinning, so they're recognized the next time. So, to all who are experiencing this, I'd recommend a quick Hijack reboot first before yanking the power.
-Aaron
#80931 - 28/03/2002 11:05
[Re: adavidw]
Loc: San Jose, CA
adavidw,
so you have ALWAYS had success doing this technique? Has it ever been where hijack couldn'r reboot it successfully? I was just running 2.0 beta 11 when I had all these problems. And how often do you get the error of no hard disk?
#80932 - 28/03/2002 12:09
[Re: njdboy]
Loc: Utah, USA
I only get it once in a blue moon, but rebooting through hijack always makes my player work.
-Aaron
#80933 - 28/03/2002 16:51
[Re: adavidw]
I have tried the Hijack reboot many times and never once has it worked. I am just stumped.
Steve
#80934 - 28/03/2002 17:34
[Re: skamp]
Loc: Utah, USA
If the problem is a cabling issue, then rebooting it wouldn't really fix it. My thought is that my specific case is just a case of the drive(s) taking too long to spin up sometimes (like when cold). So, keeping them spinning while rebooting works for me. Doesn't work for everyone, though, I'm sure.
-Aaron
#80935 - 04/04/2002 15:05
[Re: adavidw]
Loc: Auckland, New Zealand
hi everyone. im a brand new user/poster on the board but i have tried to lurk here for a while to understand where everyone is coming from and also get used to the empeg so i dont come on asking dumb questions and just annoying people or getting reverted to the FAQ. now however i really have to post a question so ive registered and all that jazz.
ive had the empeg since mid february 2002, bought from www.carplayer.com with a 10gb hdd in it. it was working flawlessly till recently, a few days ago i pulled the unit from my car and stuck it in my room awaiting a 30gb drive to be added. yes, fujitsu. i didnt get around to it and it was left in my room a few days. tried to get it up and running - No Hard Disk Found. panicked, but i remember reading similar problems on the board, and people talking about fujitsu drives and cold temperatures. ok, checked temp - 28C. blasted it with the heater for a bit, till it reached 36C - worked. was fine.
cut to 3 days ago. finally took the unit apart, found out the original drive was the good old IBM Travelstar 10gb. so much for the conspiracy theory (i think others also have had similar errors with the IBM's now?) ok, added new drive, formatted it, fitted jumper for slave setting, reconnected everything - No Hard Disk found. hmm. checked temp - ok, 26C again. blasted with heater till past 38C - still no go. ripped everything out, checked all cables, still nothing. tried just the IBM back in its default config - it worked! ok, just the fujitsu by itself - also worked!! both drives back in... no go!! just when i decided i knew what was happening, it booted. with both attached. sync'd it with emplode - reported 38gb capacity, 28gb free, etc etc. all good! played a few songs (for about an hour) - great. ok, pulled power out, reattached immediately after pulling it out - No Hard disk. F_!(@#*. rip it all out again. checked all the pins...
anyway you get the idea. i have no idea what is causing this problem for me.
-i am using the IBM Travelstar 10gb, and a new fujitsu 30gb, model MHN2300 or something (full details at home)
-i have never gotten the "failed to unmask IDE" message.
it has been running 2.0b7 till b11 came out, and has been fine with 2.0b11 for ages now.
-has had hijack 251 in there for 2 weeks now? was running hijack from day 1 too, updating regularly.
-have tried on AC and DC power. my AC adapter was 110V, unusable by me as i am in 220V land, so i have always hooked it up to my bench power supply - 14V at 5 amps, more than enough current - still no go.
-used hijack to force AC or DC modes - no go.
-used hijack reboot feature about 10,000 times - no go.
-as mentioned, heating it also no effect
-fiddled with the ide cable for 3 years, pushing it all the way in, only half way, 1/3 in, 3/4 in, blah blah. no go.
the unit decides for itself when it comes on and when it doesnt. in the car this morning it booted and played perfectly for 40 mins on my way into town. got there, pulled it out, pushed it back into the cage immediately - no hard disk. pulled it out and pushed it in another 25 times - no go. even got to the point of me pulling it out, tapping it, shaking it, putting it back - no go.
someone please help me. please.
[P] '86 Civic Si turbo
Mk2a 40Gb Smoke, 030102710
#80936 - 04/04/2002 15:12
[Re: lofreq]
Did you, as suggested in the Drive Upgrade guide, try swapping the master/slave order of the disk drives?
#80937 - 04/04/2002 19:35
[Re: lofreq]
mine had that problem because the 10 GB travelstar in my player was not mounted using spacers under the drive as recommended in the upgrade faq.
#80938 - 04/04/2002 19:36
hi tony - youre legendary
but yes, i tried that, but will try again. right now the ibm is the master (no jumpers) and the fujitsu is the slave (one jumper in the rightmost position as listed on the drive label).
i did the opposite and tried the fujitsu as master - this actually worked (i only tried this one time) but the boot time took forever. it loaded the startup screen where it reads off its status like "loading playlists"..."loading visuals"... you know, that short bootup screen that only usually is there for like 2 secs - with the fujitsu as master, the bootup stopped at "building music database" or something like that, for like 15 seconds, before continuing. i figured it was something to do with the fujitsu being empty? but i didnt think too much about it. surely other users with 2 drives set up dont have to wait this long...? i did not sync with emplode after this to see if all 40gb were recognised. - i tried the ibm by itself, sometimes this works, sometimes not. i have not tried the fujitsu by itself.
i have been going on the assumption that the IDE cable works the same way as a normal PC one, ie, slave in the middle, master at the end. am i fundamentally wrong here? does it make a difference? the original drive was plugged into the middle connector... making it a slave? but it was a master cus it was the only one??
i will go over all this again tonite extensively and post my findings... its just a bit confusing and annoying that it hasnt been a simple task. the current fail rate (or, number of "No Hard Disk found" versus successful boot rate) is very very high. ![](/images/icons/frown.gif) i can put up with it failing on every other cold morning, in fact if all i had to do every day was reboot it or pull power and replug it in, to get it to work, id be happy. but right now its basicallly unusable
oh, my other concern is possibly faulty IDE cable? visually it looks fine but of course it does, i guess. i am unsure how to test it (i dont have a laptop) or how to order a replacement? can i get another generic laptop one or should i get one from empeg/rio somehow?
thank you to you and anyone who can help - sorry to be long winded. on the plus side i just got a renewed 'warrant of fitness' for my car (road legal requirement here in NZ) even tho its turbocharged when it shouldnt be, so thats my happy side of today ![](/images/icons/smile.gif) hassle-free boost for another 6 months! yay for slack dodgy mechanics!
#80939 - 05/04/2002 02:18
[Re: lofreq]
The reason the database error happened at bootup after swapping the drives is because the new drive order did not have the database on the primary drive.
You simply need to put the drives into the order that "worked" and then synch with emplode once (the thing you specifically said you did NOT do) to rebuild the database and get it to work properly.
#80940 - 05/04/2002 23:37
i understand about the database error side of things... after i did that i returned the drives to how they DID work, like you said - the master (with all the music, and the original database and whatnot) is the ibm, like from factory. then the fujitsu sucker is on slave. thats how i left it, and it has been temperamental
when i got home i opened it up and was about to start swapping all the units over, all i had done was sorta jiggle the ide cable about and press all the connections in again (nothing moved, they were all in fully), and just decided to try to power up - it worked!! without changing any drive order or resynching or anything. after test booting it a couple of times i seem now to have a fully working player, once again. one would have to assume, dodgy IDE cable connection somewhere along the line? id hate for this to crop up again in a few days, brought on by vibrations in the car...
could you direct me where to go to find out about ordering a replacement cable, OR like i said before, can i simply use a generic laptop style cable instead? just in case my problems have stemmed from the ide cable
anyway all seems ok for now so we'll see.
you other guys who have been having this problem - have you all sorted out the issues as well? what are your findings?
#80941 - 06/04/2002 00:14
[Re: lofreq]
Email carsupport@empeg.com
A generic laptop IDE cable will probably not have the connectors - well the middle one anyway - in the proper position, or be of the same length, to fold in the same way the original (custom) cable. That could cause trouble for the drive plate to move properly, or rub or press against some component.
#80942 - 06/04/2002 00:28
[Re: lofreq]
Anonymous
Unregistered
To all problem-diagnosers,
MKIIa, 30GB, not sure what brand drive, 2 beta 11, No Hijack, only used on AC at room temperature. Have had Failed to unmask IDE error and no HD error several times, but it never fails to boot up successfully 10 seconds later.
#80943 - 06/04/2002 06:16
[Re: ]
To read make and model of harddrive:
cat /proc/ide/hda/model
or view it / download it via ftp
#80944 - 10/04/2002 18:01
[Re: lofreq]
Lofreq - I have the same problem. I have swapped cables. Swapped master/slave and I still get the no hard disk found every so often. I have 2 exact drives. They are both 48GB IBM Travelstor. I am not sure I will ever figure out why it happens. There is no rhyme or reason. It can happen even if I don't touch the unit. For example it works fine I go run into the store to get something, come back out and boom get the error. It makes no sense as I have not touched the unit.
Steve
#80945 - 10/04/2002 19:12
[Re: skamp]
yeah same - i also notice that it does seem to crash sometimes just before it f*cks out - it starts going real slow and staggered, then finally stops altogether. reboot = no hard disk. has yours crashed like this?
for example... youre playing a song perfectly fine... suddenly the whole thing slows down - the song breaks up into staggered segments, with gaps of silence inbetween... maybe 5 to 7 gaps per second... so like if youre listening to freddie mercury yelling "we will we will rock you" it slows down to become "w-w-w-e-e-e-e- - - w-w-w-i-i-l-l-l-l- - - w-w-w-e-e-e- - -w-w-w-i-i-l-l-l-l-l-l- - - -r-r-r-o-o-c-c-k-k-k - -y-o-u-u-u-u" with each dash representing a pause. i dunno how else to explain it, sorry if that sounds retarded.
the visualisations also stop and start, in time to the pauses. the scrolling of the title (if youre in INFO:Line mode) ALSO stops and starts all in synch. the buttons stop responding - holding down the top button will not pause or turn the unit off. the only way i can kill it is to pull the sled. push it back in - no hard disk found. wait a few mins/hours randomly, and it will either start coming up with 'failed to unmask ide', or if youre lucky it will start going again.
just something to put up with for now i guess. i really supect the initial problem is a dodgy IDE cable... what else could it be! its too random! so i will look into ordering a replacement.
i havent read up enough about the crashing to see if other's units (that are crashing) crash in the same way so i'll go look around now. knowing my luck theres probably a solution already in the FAQ that i have missed
#80946 - 11/04/2002 02:27
[Re: mtempsch]
Could we maybe get some input here from someone at Empeg/SB? It seems like this is an official epidemic and that, judging by the lack of similar reports until recently, it's caused by b11, no? Mine is tempremental as hell!
MEast
40GB MK2a in '04 BMW 330CiC with BSW 300w Amp & 10" Custom Sub
#80947 - 11/04/2002 05:13
[Re: meast]
If Beta11 is the problem, then the answer is to go back to 1.03 until the next release. There's no support for beta releases, and we're already way past B11 with the alpha team.
