#91347 - 30/04/2002 18:45 Similar startup problem
amthar
Loc: North Carolina
I've been using my unit for a few months now without a problem. Then one day I go out to my car, put the empeg in and start the car... empeg doesn't come up. I played with it a bit more and when I start the car the blue standby light in the front will "blink" tiwce, then go off completely. I hear the hard drives spin but that's it. If I press the little round button on the left and the arrow buttin directly below is at the same time, the blue light will begin flashing again BUT if I hit ANY key after that... it stops blinking again.
Below is what console tells me:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 9, serial number 40103941)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:6
5
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
Then it sits here. I can connect to it with emplode and hit syncronize and it seems to syncronize fine.
Any thoughts? Is this the infamous hard drive cable? Something else? Thanks all.
- Josh
#91348 - 02/05/2002 02:12 Re: Similar startup problem [Re: amthar]
pupvogel
Loc: Hamburg, Germany
maybe your dimmer-setting is at 0% ?
i had this once after upgrading the firmware.
i was able to correct this when it was very dark in my car (in daylight it wasn't possible to see the player's menu).
at least i don't see anything suspicious in your serial-log.
#91349 - 03/05/2002 10:52 Re: Similar startup problem [Re: pupvogel]
amthar
Loc: North Carolina
how do I go about fixing that?
