#96248 - 28/05/2002 20:55 EQ Memory NOT Working
JeffreyB
Loc: Cincinnati, OH
This has gone way beyond aggravating. I posted a message a couple of weeks ago about this same problem. I'm running HiJack v269 and v2.00 beta11. The EQ memories between car and home are somehow getting scrambled. All is usually well, meaning that the home dual 10 band and the car 4 ch 5 band stay separate and work properly until I edit the home setting. Today I edited the home dual 10 band and later when I put the unit back in my car instead of automatically changing back to the 4 ch 5 band, it defaulted to what I thought was dual 10 band, however it was a corruption of both car and home settings. Even though in the car it came up in dual 10 band, the EQ settings were still the ones for the 4 ch 5 band. The first 5 bands were what the front channels were and the last 5 bands were what the rear settings were. The bands still had the same level and freq as the 4 ch, but they were stuck in the dual 10 band mode. When I went in and reselected 4 ch mode, the 4 ch, 5 band came up default flat. All of my car settings were lost. Again this happens when I have edited the home EQ and then returned the unit to the car. Any ideas?
Thanks,
Jeff
#96249 - 28/05/2002 21:38 Re: EQ Memory NOT Working [Re: JeffreyB]
Sounds like a bug. Did you write bugs@empeg.com like it says at the top of the Bug Reports forum here on the BBS?
#96250 - 29/05/2002 00:48 Re: EQ Memory NOT Working [Re: JeffreyB]
David
Loc: Cambridge
Reinstall 2.0b11 without Hijack and give that a try before reporting it as a bug.
