#96521 - 30/05/2002 11:09
Radar Detectors
Okay, sure, everyone agrees the Valentine One is the best.
But day-yam, it's expensive, even on ebay. And its remote-display mount is rather bulky.
My goal: A completely stealth install, so that even someone who is combing my car LOOKING for a detector will not see it. I want to run some very small unobtrusuve LEDs to the instrument cluster, and have them be behind the panel in such a way as to not be visible until they light up. I think I can handle this part myself, as long as I can do it as individual loose LEDs and wires (as opposed to some sort of a velcro-on-box-kit).
So. Advice on what to get? Something with remote-mount capability that's reasonably priced?
#96522 - 30/05/2002 11:28
Re: Radar Detectors
Although I have to say, this guy's install of the V1 is rather cool...
#96523 - 30/05/2002 11:36
Re: Radar Detectors
Loc: San Jose, CA
#96524 - 30/05/2002 11:52
Re: Radar Detectors
[Re: eternalsun]
I didn't say I didn't like V1 installations, it's just that it has a rather bulky remote-display which won't fit in the places in my dash that I want to put it.
I'm reading up on stuff at www.RadarTest.com and one of the first things I've decided is that I don't want a V1. I'd prefer to have a less "chatty" detector than that.
#96525 - 30/05/2002 12:32
Re: Radar Detectors
/me wonders if any of these things could be hacked to talk to the empeg in some way??
#96526 - 30/05/2002 12:38
Re: Radar Detectors
[Re: genixia]
I'm sure they could, but I wouldn't want to. I need the displays and audio output to be separate from the stereo.
#96527 - 30/05/2002 12:41
Re: Radar Detectors
Gets me thinking, though... If the empeg puts out a little bit of RF interference while driving, would it affect the range of a detector?
#96528 - 30/05/2002 12:42
Re: Radar Detectors
No information but I saved this picture from somewhere...
Tom
#96529 - 30/05/2002 12:44
Re: Radar Detectors
[Re: charcoalgray99]
Oh YEAH, now that's what I'm talkin' about!
#96530 - 30/05/2002 12:59
Re: Radar Detectors
Loc: San Diego, CA, USA
Here's a similar install. It was actually bookmarked from the link Tony posted.
http://apexcone.com/Radar/RadarLove.html
__________________
Scott
MKIIa 10GB - 2.0b11 w/Hijack
MKIIa 60GB - 2.0 final w/Hijack
#96531 - 30/05/2002 13:02
Re: Radar Detectors
[Re: svferris]
Cool. I found some more pictures I saved. Looks like it could be the same mirror as the one in the link.
Tom
94993-v1 mirror.JPG (469 downloads)
#96533 - 30/05/2002 13:04
Re: Radar Detectors
#96534 - 30/05/2002 16:38
Re: Radar Detectors
Loc: Long Island, NY
You might want to check out K40 - they have front/rear remote mount units. All you see is 2 small led's (can even be mounted in the instrument panel) and an on/off/volume knob. We used to use them a couple of years ago and ISTR their stuff worked very well... Here's a link to their website.
Cheers.
Phil
60GB Amber
10GB Blue
#96535 - 30/05/2002 16:48
Re: Radar Detectors
[Re: philp69]
Their stealth mounting is pretty much what I'm looking for, but they seem to be more pricey and did not get a good review at radartest.com.
#96536 - 31/05/2002 16:12
Re: Radar Detectors
Loc: San Jose, CA
Take the remote display apart. It's just a bunch of LEDs. You have enough technical knowledge to remount each of those lights anywhere you want. :-)
Calvin
#96537 - 31/05/2002 21:55
Re: Radar Detectors
[Re: eternalsun]
Please also keep in mind that in addition to relocating the display in a stealthy position, you also have to mount the receiving antenna (or in the case of the V1, antennae) somewhere stealthy. This will not be easy to do, as the antenna is built into the case itself, and the unit (with or without the LEDs) is not designed to be mountted outside the friendly environs of the car's interior.
#96538 - 07/06/2002 14:36
Re: Radar Detectors
Loc: San Jose, CA
The Valentine1 has a separate remote display that doesn't require digging into the actual unit. Remounting the V1 is completely out of the question. I e-mailed the V1 designer and he says opening the unit will eliminate the shielding and vastly reduce the efficiacy of the whole detector. Remoting the antennas (there are several) -- will cause problems because the code in the box depends on timing characteristics that will be affected by adding length to the wires.
However, remoting the display is not an issue since the V1 uses ordinary phone line cable to send serial bits to light up the remote display...
Calvin
#96539 - 07/06/2002 15:54
Re: Radar Detectors
I wouldn't put much faith in most review summaries of the V1. All of the reviewers claim to hate the ergonomics, because they seem to prefer fiddling with tiny little buttons rather than a nice quick twist of the knob on a V1. I've had both kinds, and the V1 is WAY simpler to use.
My suspicion is that since V1 sells direct, with few ads and no middlemen, the magazines/sites don't like them so much cuz they don't get a "cut" from them. Same as any PC mag comparing MS products with others.. MS always wins because they buy the biggest ads.
Back to that site.. they claim the "locator" feature to be not worthwhile.. Excuse me? Driving without those arrows is like driving blind. You've got no idea at all where the source of the radar is, and without that information.. any detector is damn near useless.
They also complained about 3 bogus alerts in a hick town somewhere.. the V1 is very sensitive, and reports EVERYTHING, unless you tell it not to. Two presses of the knob and it's then in "Logic" mode where nearly all bogus warnings disappear, leaving only the "real" ones, and the occasional too-strong-to-ignore bogus source.
Sheesh! If you need an Empeg in your car, then you could not possibly be happy with anything less than a V1.
I keep my V1 remote display stuck to the dash with black peel-and-stick velcro, with another patch of velcro under the dash for discreet storage. Works great, took 20 seconds to install.
Concealing the main unit is trickier, but I do like the idea of installing it into the ceiling trim.
#96540 - 07/06/2002 15:58
Re: Radar Detectors
Plastic wrap is your friend -- instant environmental enclosure. But there are lots of places INSIDE most vehicles for a V1 as well.
#96541 - 07/06/2002 16:35
Re: Radar Detectors
Loc: San Jose, CA
The problem is the magnesium case is also the shielding. Exposing the guts will allow the microwaves to leak out allowing the unit to be detected by radar detector detectors of all things.
Calvin
#96542 - 21/06/2002 15:58
Re: Radar Detectors
Loc: Southern California
Tony,
I have to agree with Mark on this, the reviews don't tell the whole story. For whatever reason they are biased by something, most likely $$$. I have owned or currently own the Escort, K40 and the V1 and the V1 is my hands down choice when it comes to detectors. The K40 (which was already installed in a car I purchased) was the worst one when detecting radar, missed it or found it too late in more cases than I care to hit the brakes for. The Escort (my wife bought it for me for x-mas, and now it's in her car) was good at detection but leaves you with a neckache looking for the coppers. Not to mention, it was the king of false alarms while driving around town. It was so bad that most of the time I drove around with it turned off, and that's not very helpfull. The V1 pulls in radar early enough to give you ample time to do something, plus tells you where it is (this is a very nice feature no matter what anyone else says). It's often super helpful to have the most info about the radar your trying to dodge to make your efforts more effective, the V1's directional reminder makes it easy to fully examine the "danger" you're in. For me, the V1's ergos are fine. I haven't found it hard to use at all. To address something you mentioned in your post, the V1 is not "chatty". When used in "logic" mode the V1 eliminates 99% of bogus warnings. I run mine in "logic" mode all of the time and never change it. The mute feature is helpful too if your worried about the "chatty" V1.
On a recent trip from So.Cal. to Northern Utah, I was able to AVERAGE 87mph over a 696 mile trip, due mostly to my confidence in the V1 (the 75 gallon gas tank in my truck didn't hurt either). While blasting up the 15, the V1 "saved" me at least 8 times that I would have definately gone "downtown" and probably more. With a minimun of those annoying false alarms.
Bodybag - So Cal Not a Whiner any more!!!
#96543 - 21/06/2002 16:02
Re: Radar Detectors
[Re: bodybag]
Unfortunately, I can't afford a V1 at this time. I'm going to have to find something cheaper.
I know, I know, you get what you pay for. I totally understand this. But I'm at a point now where I think that any radar detector would be better than none.
#96544 - 22/06/2002 13:57
Re: Radar Detectors
I know how you feel... I've just dropped $600 getting my car chipped. I definately need a radar detector now!
#96545 - 22/06/2002 13:58
Re: Radar Detectors
[Re: genixia]
And can anyone answer my wife question as to why I can't buy anything without upgrading the firmware?
#96546 - 23/06/2002 18:50
Re: Radar Detectors
[Re: genixia]
Not with out using extrem sarcasim!
What chip did you get put in? and how big is the grin on your face?
#96547 - 23/06/2002 20:27
Re: Radar Detectors
[Re: Phoenix42]
Loc: New Orleans, LA
Hehehe... Same here. The g/f always laughs when I get a new computer. The FIRST thing I do is take it apart and move everything around until it's how -=I=- like it. and that's before I even turn the thing on once. -=shrug=-
#96548 - 23/06/2002 20:28
Re: Radar Detectors
[Re: lectric]
Hey cool... That was post 200. Now I'm enthusiastic.
#96549 - 24/06/2002 11:54
Re: Radar Detectors
[Re: Phoenix42]
#96550 - 24/06/2002 19:09
Re: Radar Detectors
[Re: genixia]
Did you check out the superprogramers before you bought that chip.I was told that the programmers are better than the chips.
040103958 60g
#96551 - 26/06/2002 17:59
Re: Radar Detectors
[Re: thrasher]
No, I wanted something that is plug and play, relatively cheap, well-proven and wife-friendly. I could just see it now..."Sorry Hon, just give me a minute to re-program the boost maps.", "Yes I know we're late for your parents, but I've only got the fuel map left to do...", "Ok, I'm done now...it'll just be a couple of minutes for the throttle body adaptation.", "Oh dammit, I forgot to correct that air map I screwed up yesterday"
.....and just to top it off, then realising that my empeg needed a stable version of Hijack because I'd left one of my dodgy development kernels on it..
I really like my wife, and I'd like her to keep liking me!
#96552 - 28/06/2002 11:18
Re: Radar Detectors
[Re: bodybag]
Loc: San Jose, CA
I have to agree with you. It's very baffling that of all the valentine 1 reviews, this is the one bad review. Strangely enough, all the car magazines for the passport features and highlights that web site as authoritative. I suspect the web site is not very independent at all.
Calvin
#96553 - 23/07/2002 21:00
Re: Radar Detectors
Loc: Arizona, USA
What I would like to see the radar detector manufactures do is have an option that would turn off the sound if you are going under 25 mph. Most of the time it would be in a parking lot at the grocery store or Mall. And you aren't concerned about speeding tickets when you are going under 25 mph.
#96554 - 24/07/2002 05:53
Re: Radar Detectors
[Re: Caps]
That's a great idea. Wish there was a way for them to implement it easily and inexpensively.
My detector will still beep at me in "City" mode if I drive very close to a door opener. But the 25mph mute would solve that problem. Heck, I wouldn't even need the City/Highway mode if it did that.
Hmmmmmmmmmmmm.... Since I've already dismantled the detector and could easily put a relay switch on the speaker wire........................................
HMMMMMMMMMMMMM................
Okay, who's got ideas on how to implement this?
#96555 - 29/07/2002 05:57
Re: Radar Detectors
[Re: genixia]
I've noticed a strange side effect though - a desire to drive at least 10 miles to buy convenience items that I'd normally just go down the road for.
I have a similar issue with one of my siblings - chipped his TVR Chimeira 4.5 and did a serious bit of outlet manifold insulating. Now when he comes round for a chinese he is insistent that I don't get the food in before he gets here. We go down to the restaurant via the roundabouts!!!
Wheeeeeeeeeeeeeee! Much sideways-ness
#96556 - 29/07/2002 16:40
Re: Radar Detectors
[Re: frog51]
As someone who is (a) an American, and (b) extremely tired, that sentence had
multiple points in it where the cognitize dissonance caused me to start over and
reparse.
Perhaps this is the simplest sentence which has caused me to back up and re-read
it 3 or 4 times.
Varied images: issues with your siblings, chipped paint, chimeras on TV VCRs,
picking up a Chinese person on a motorcycle, dangling a forkful of food
just outside your mouth.
Uh, maybe it's just me. I need a nap.
Or maybe... maybe... I just need to buy a Coke at that little convenience store
just 100 miles from here.
#96557 - 29/07/2002 19:41
Re: Radar Detectors
[Re: music]
Hmm...I had no problems with that sentence...except that it gave me a yearning to go to Milton Keynes. There just aren't any decent roundabouts here in MA. The ones that are here suck.... the designers obviously didn't have a clue, and people don't seem to know how to drive around them.
#96558 - 30/07/2002 03:20
Re: Radar Detectors
[Re: genixia]
Loc: Lochcarron and Edinburgh
... a yearning to go to Milton Keynes ...
Now that's a phrase I've never heard before!
#96559 - 30/07/2002 03:39
Re: Radar Detectors
[Re: tms13]
They do have one of the only 2 indoor real snow-slopes in the UK though, which is my excuse to visit it.
That and the roundabouts, anyway
#96560 - 30/07/2002 05:59
Re: Radar Detectors
[Re: genixia]
Loc: Seattle, WA, U.S.A.
The problem is that not everyone understands the rules, which in Mass are different from everywhere else.
The rules:
1) Highest velocity wins
2) Anyone making eye contact automatically forfeits the right of way.
Simple.
Jim
#96561 - 30/07/2002 06:01
Re: Radar Detectors
[Re: jimhogan]
That is unusual - most places go by momentum. Hence, White Van Man.
#96562 - 30/07/2002 08:19
Re: Radar Detectors
[Re: tms13]
Predatory drivers in the Bay State know that White Van Man generally has higher and more lucrative liability insurance than they do. White Van Man knows it, too. So they keep it simple, mass-wise.
IIRC, the rules I saw in Germany were more complex, but mass was still not a dominant factor. Something like
Roundabout ROW = (velocity*(sqrt(vehicle mass)) / (vehicle value in Euros)
Again, however, if eye contact is initiated, that driver's velocity is set to zero for purposes of the calculation.
Jim
#96563 - 30/07/2002 09:00
Traffic priority
[Re: jimhogan]
When I was growing up on a farm, it came as quite a shock to go from driving tractors and combines to driving little things like landrovers and 16-ton flatbeds, and having to sometimes give way. Size definitely counted for more than speed (prolly 'cause speed isn't an option on our narrow, bumpy Yorkshire lanes). I think that having a big bale spike on the front helps, too.
#96564 - 30/07/2002 13:15
Re: Radar Detectors
[Re: jimhogan]
OK, now... you have forced me to jump to the defense of East Coast drivers.
Admittedly, my East Coast experience is limited to just two cross country trips (New Hampshire to Alaska), one year apart. But both times I was amazed and impressed by the courtesy and by the "lane awareness" of the drivers on the freeways.
In rush hour traffic in Boston (four lanes each direction, bumper to bumper, occasional spurts to the utterly mad velocity of 25-30 MPH) time after time I saw people "trapped" in one of the inner lanes turn on a blinker to change lanes and thus get to an exit, and immediately the person behind and to the right would slow, open up a gap for him to get in.
But most amazing of all was when the freeways "opened up" with less traffic. Average speed would be (like everywhere else) speed limit +10MPH. My average speed was somewhat (not a lot) higher than that -- my near-invisible ShoWagon equipped with V1 radar detector made me feel pretty secure. It was so amazing to me to look ahead and see traffic lined up nose to tail literally for miles -- and all of it in the right hand lane! Occasionally someone would pull out to pass, and then tuck right back into the right lane. If I caught up to someone in the left lane that was passing a line of trucks, almost always he would slip in between a couple of them to let me by, then come back out and continue passing himself.
This was such a refreshing change of behavior from the drivers in my part of the country that I was just simply amazed.
It should be noted that the further West I got, the less prevalent this kind of driving became. By the time I got to Idaho, it was business as usual, and California and Oregon were... oh, don't get me started.
So, if you're driving on the East Coast, count your blessings.
#96565 - 30/07/2002 13:21
Re: Radar Detectors
/me considers moving to the east coast.
Either that, or finding out what they're putting into the water back there to make people obey this rule.
Think it's a question of enforcement? Or perhaps public awareness campaigns on the subject?
#96566 - 30/07/2002 13:30
Re: Traffic priority
[Re: tms13]
I don't disagree. I was just being a PITA (note my little "things are different in Mass" inertia joke!). I'm just being penzantic...or crafting a euthanism. None of my rotary/roundabout formulae are destined, alas, to make it into a college physics textbook.
I *do* hold my general generalities to be true....In Mass, the vehicle *in* the rotary only has right of way to the extent that the driver avoids eye contact and behaves fearlessly....in Germany the clapped-out VW Polo has supreme right of way over the shiney new Mercedes!
Jim
#96567 - 30/07/2002 14:50
Re: Radar Detectors
You have taken on a difficult job!!
I agree with some of what you say, but I think that some of your experiences may have been atypical.
Camping in the left lane with cruise control set to speed limit +2 is terrible in Washington State, worse only in Oregon. I have approached cars at 5AM on I-5 in Oregon -- no other cars in sight -- camped in the passing lane. My theory is that it is easier for the driver to sight over the driver's side fender and line it up with that yellow stripe. West coast loses this one in a big way. Some of it is made worse in Washington by a higher proportion of left-lane exits -- bad traffic engineering.
Things may be better in Mass because such ill behavior has been met with more aggressive responses over time -- tailgating, high beam flashing. Anyhow, it it is true that folks aren't as brain dead.
There are a few really nasty highway intersections in Boston (the old I-93 northbound split that will be retired by the Big Dig) that rank as the worst anywhere and where folks have developed altruistic merging behaviors. Overall, though, I'd still rate Boston as the capital of antisocial, drive-like-hell-and-execute-a-no-eye-contact-forcible-merge-at-the-last-moment merge behavior. I still drive in Boston a few times a year (after driving there 1969-1988) and can contrast it with Seattle where *generally* people begin a cooperative merge maneuver when first they see a "X lane closed ahead" sign. I must assume you didn't get in the merge for the Callahan Tunnel!
Better. Unlike Washington/Oregon, the Massachusetts DMV may no longer issue licenses to the deceased!
Agree re: The West, but I still feel like your eastern experience was atypical....but this is from a refugee!
Jim
#96568 - 30/07/2002 17:38
Re: Radar Detectors
So, if you're driving on the East Coast, count your blessings. Well, maybe in the Northeast. In Raleigh, N.C., it's awful. People camp in passing lanes. People rush ahead to pass you and then slow down. People refuse to let you merge from an entrance ramp. People slow miles before getting in their exit ramp/turn lane. People rubberneck over cans in the road. But at least you can't see anything except the SUV the size of a barn in front of you.
Of course, this is all contributed to by poor traffic engineering. We had cloverleafs that were removed because people couldn't figure out how to use them. We have roundabouts with stop signs to get in them. We have stop signs at the end of entrance ramps. There is only one left-hand entrance onto a highway that I can think of, but it occurs about 500 feet before a right-hand exit that has basically no slowing-down room, so that you're forced to slow down to about 40mph on the highway, so that you've got ridiculously slow-moving traffic in the right lane, and merging going on in the left lane.
Even so, it's much easier than trying to drive in Winston-Salem, which I'm pretty sure is the capital of the putrid-driving ignoramus.
And I've driven in Boston and other areas of the Northeast. The thing is that, while they're remarkably aggressive drivers, they're also very good drivers.
#96569 - 30/07/2002 20:58
Re: Radar Detectors
And there I was believing that recent report that put MA drivers as the worst in the country....
Anyway, the Brits are definitely the best drivers....and they know how to design and drive around roundabouts. The key to roundabout design is all about controlling the entrance speed.
#96570 - 30/07/2002 23:16
Re: Radar Detectors
[Re: genixia]
Yeah, got to be true if they can design and master something like the Magic Roundabout.
If I had encountered this sign while on vacation in the UK, I'd have turned around...
#96571 - 30/07/2002 23:48
Re: Radar Detectors
[Re: genixia]
Another thing beyond huge roundabouts that impressed me while in the UK was all the country highways. Most of the time, they were three lanes, with the middle lane dedicated to passing. Every mile or so it switched what side could use it for passing. Much better then the two lane system where noone drives properly to allow safe passing.
#96572 - 31/07/2002 01:15
Re: Radar Detectors
[Re: genixia]
I dunno, growing up in california, I just view roundabouts as a cheap and dangerous alternative to real interchanges. Nothing beats a well designed cloverleaf...
#96573 - 31/07/2002 01:18
Re: Radar Detectors
[Re: drakino]
We have that sort of thing in random places; There are 3 lane stretches on US22 between Pittsburgh and Altoona, and then scattered further east across the state. It's ok, if the zones are long enough. Otherwise it's "tromp it, see how much you can get around, slow down, wait" and sometimes someone else pulls out to pass and is in no hurry. It's worse when there are hills involved, which is often.
Thankfully, since I got my license in 1989 they've been upgrading this to 4 lanes divided. It also connects near Altoona with a nice north-south highway, US220 (also known as I-99. what a travesty) which they're extending north. Can't wait for that to be done.
#96574 - 31/07/2002 06:18
Re: Radar Detectors
[Re: matthew_k]
Waaah, that's out West, pardner, where you got all that spaaaace, and all them thar deer and anteelopes.
If there's any excuse for how hosed up some of Boston traffic/rotaries are, it's that they were constructed in the 20s and 30s literally as recreation roads for Sunday drives for the 200 or so people in town who owned cars. Roads like the scarred-tree-lined Jamaicaway slowly became major commuter arteries without anyone noticing or changing anything. Many of those old MDC roads run through dense neighborhoods where there's no room to expand.
I think anyone looking for a representative driving experience there should fly into Logan, rent a car, and drive through the Sumner/Callahan then follow Storrow drive out towards Brighton during mid-day traffic. Fun for masochists!
Jim
#96575 - 31/07/2002 07:04
Re: Radar Detectors
[Re: matthew_k]
The only cloverleaf around here[1] is notorious as the most congested junction locally, and will be removed when the Highways Agency get their way. Part of the trouble is the amount of westbound A14-A14 traffic that's crammed into one lane around the tight radius, then it's got to weave across the traffic leaving the M11-A14 eastbound before it can join the motorway. It's nasty.
[1] only 2 lobes, really
#96576 - 31/07/2002 07:42
Re: Radar Detectors
[Re: mtempsch]
My brain practically exploded when I saw that. I have absolutely no idea how the rules would work on something like that. That's just insane.
#96577 - 31/07/2002 09:18
Re: Radar Detectors
[Re: drakino]
You would have been less impressed around 15 years ago, before we abolished the three lane system - whereby drivers on EITHER side could use the middle lane for passing. Eeep!
#96578 - 31/07/2002 09:24
Re: Radar Detectors
[Re: genixia]
If only that were still true. Almost all major roundabouts are now traffic light controlled, completely defeating the point of them because a few brain dead morons don't know how to use them properly (main problem is pulling onto the roundabout when your exit is backed up, thus blocking the roundabout for everyone else).
#96579 - 31/07/2002 10:30
Re: Radar Detectors
[Re: rob]
Yes, they're scary. Modern ones, that are basically crawler lanes on uphills, feel much safer.
The last real 3-lane road I used was the A6 near Garstang about 5 years ago; I was there recently and it's simply been reduced to 2 wide lanes with advisory hatching down the middle. Even though the 3-lane roads are mostly (completely?) gone, people still use wide 2-lane roads (e.g. A5 Oswestry bypass) as if they were 3 lanes, ignoring the white lines. You soon learn to keep left after the first near miss with oncoming cars straddling the line!
#96580 - 01/08/2002 22:52
Re: Radar Detectors
[Re: rob]
Loc: Dallas, TX
They put a couple of these in Austin a few years ago ... but they hid them in some strange neighborhoods ... tiny little circles.
The first time I saw one it looked like a dead end street from half a block away. Even after I figured out what it was, I was too baffled to actually drive through it. I had this mental picture of some road crew guys hitting the bottle a little too hard before starting their work, and winding up with these whirly-doos or whatever.
Greg
#96581 - 01/08/2002 22:59
Re: Radar Detectors
[Re: mtempsch]
Loc: Dallas, TX
This thing made me vomit in terror. I'm probably going to have nightmares about that for a week. And I thought red turn signals in California were mystifying ... I mean do I turn, or stop ... or turn half way through the intersection, then stop. Or stop, but have my wheels turned in preparation for a green arrow? Or does it mean that it's pointing in the wrong direction of a one way street? Luckily there was no cops around, otherwise they would've though I was high, freaking out as I was in front of a traffic light.
Greg
#96582 - 01/08/2002 23:29
Re: Radar Detectors
[Re: grgcombs]
Remind me never to get in a car with you.
#96583 - 01/08/2002 23:30
Re: Radar Detectors
[Re: grgcombs]
Well, see, if you've got a red arrow, you know you're gonna get a green arrow when the time comes... What I really love are green right turn arrows. I hate stopping or knowing I'm illegally rolling through stop lights with the other traffic is turning left and blocking all the other traffic...
Try driving in san francisco sometime. Half of the signals on some hills are for street cars. I don't know if i'll ever be as baffled as I was the first time I encountered a red 'X' signal.
#96584 - 02/08/2002 08:39
Re: Radar Detectors
[Re: tms13]
Lots of 3 lane stuff on the A68 in the Borders and thereabouts. Mostly works quite well, except for the cruel placement of speed cameras in a couple of places.
The M8/M74 junction east of Glasgow is quite good - nice feed in and visibility of the roundabout so during the night it's a stay at the speed limit job. During rush hour you're going at 10mph anyway so it isn't an issue.
#96585 - 04/08/2002 03:38
Re: Radar Detectors
[Re: matthew_k]
Including the one that resulted in the worst traffic messes here in Colorado Springs, and the death of Seymour Cray. After that accident, the intersection of Acadmey and I-25 was completly reworked.
Cloverleaves are very dangerous when they mix traffic getting on and off.
#96586 - 17/08/2002 00:17
Re: Radar Detectors
Loc: Mission Viejo, California
I just got a little radio shack radio detector for free (I'm guessing it's not that great). Anyways... do these things have to be right up by the dash, or could I aim it towards the dash and mount it more near the rear of the car?
John Heathco - 30gig MKIIa w/ tuner module
#96587 - 17/08/2002 09:36
Re: Radar Detectors
[Re: jheathco]
depends on the detector, I'd suppose. I don't know anything about the Rat Shack units.
#96588 - 25/08/2002 21:44
Re: Radar Detectors
[Re: eternalsun]
Loc: Dallas, TX
So really all you need is a serial converter and you've got your empeg as a display for your V1.
Greg
#96589 - 25/08/2002 21:54
Re: Radar Detectors
[Re: grgcombs]
Loc: San Jose, CA
#96590 - 25/08/2002 22:02
Re: Radar Detectors
[Re: eternalsun]
Loc: Dallas, TX
If someone donates a V1 to my, ahem, "testing purposes", I'll be happy to test that theory
g
#96591 - 21/10/2002 16:16
Re: Radar Detectors
[Re: grgcombs]
Loc: Helsinki, Finland
Please note that there's a new toy in town. A thing called 'Spectre' (previously Stalcar, but it was too easily mixed with Stalker, so the Australian-based company changed its name).
This thing is a radar-detector-detector, currently detecting 'ALL' radar-detectors, including BEL's latest, PNI, Cobra and also Valentin 1.. A lot of people got severely punished a couple of months ago here in Finland, because the police had acquired one of these things.
So, if radar-detectors are illegal in your country, please do consider this. See also http://www.spectre-rdd.com/.
#96592 - 30/10/2002 08:07
Re: Radar Detectors
[Re: Amarth]
Loc: USA
I think the thread got a little off topic....but I'll chime in on the radar detector....
I've got a V1 stealth installed in my BMW M3, mounted in the rear 3rd brake light housing. I have connected to it a remote audio adaptor in the center console to turn it on or off, and to adjust volume. I have Jim Powell's display (see http://www.apexcone.com/Radar/RadarLove.html) and it works magically. I live in VA so they are illegal and have been pulled over twice (for other things) and the cops don't even notice.
Attenuation of signal is minimal (of course it's not going to be as good as in the front windshield), and the rear deck is cardboard and 3rd brake light housing is plastic so they are almost completely transparent to radar.
Jim will install the 'concealed display' in any mirror, so long as it's thick enough to hold the components.
Good luck!
Wes
#96593 - 30/10/2002 11:11
Re: Radar Detectors
[Re: NicolasW]
By "in" the third brakelight, do you mean that it's in there with the light or as a replacement? Is there really room for all that? The V1 isn't the smallest thing out there, from the pictures... Your install sounds great, it seems like the only viable anti-theft option if I was going to get a V1.
#96594 - 09/11/2002 15:24
Re: Radar Detectors
[Re: matthew_k]
Loc: USA
I meant in the 3rd brake light housing....my inspiration is at this site.... http://www.vb.quik.com/jmciver/
Yes, it is the most anti-theft thing I've ever seen. That combined with the double-lock (i.e. deadbolt) feature on most BMW's makes it near impossible to steal.
Good luck!
Wes
