Christian, aka "Shonky" did them last year.
The bare connector with all pins worked out at ~ $13
Then to supply and construct the harness there was an additional $18, though I recall this turned out to be a little low compared to the effort Christian put in & the parts cost. If your'e reading this Christian, thanks again for a quality job.
For reference only, the harness included..........
Front RCA preamp out connectors
Rear RCA preamp out connectors
Aux In RCA preamp in connectors
3AG fuse holder with 3A fuse in the battery line
DB9 Serial port connector
Labelled power/mute/headlight wiring
Cheers, Sim
Your order number is 73
Order placed at Mon 3 Feb 2003 8:27 am
