Hold up.. I did a capture to file and here it is correct:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v335 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Tue May 13 15:01:19 EDT 2003
empeg-car player (hardware revision 9, serial number 30103111)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:27
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Hijack: intercepting config.ini
hijack_exec("/usr/local/bin/emphatic"), rc=0 (okay)
hijack: removed menu entry: "Hard Disk Detection"
khttpd: listening on port 80
kftpd: listening on port 21
opening display...
Using non-standard cache size 86 (adjustment 48)
starting notify thread...
notify thread started (tid=1026)...
lyrics thread started (tid=2051)...
emphatic v1.10 (built Feb 18 2003 20:15:18) running as pid 11
Vcb: 0x4056d000
And then when I synchronize:
Adding Swap: 16596k swap-space (priority -1)
disk.cpp : 876:Couldn't cleanly unmount drive 0 (c0041010)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
hijack: removed menu entry: "emphatic"
Restored terminal settings
Restart code received
Starting player
opening display...
emphatic v1.10 (built Feb 18 2003 20:15:18) running as pid 33
Vcb: 0x4056d000
One of the last MK2's from SonicBlue...
Blue/60gig
S/N: 030103111
