There are actually only 39 pins in an ATA66/100/133 connector; and 78 conductors in the cable because each pin is individually grounded instead of all pins sharing one ground (If I recall correctly). What exactly are you trying to do? Trying to McGuyver something together with the old 40 pin ATA connector and ATA66/100/133 devices could be troublesome.
