Pickle, are you working on a Palantir for CE?
I just started looking into it yesterday, and was planning on writing one possibly in Java. I haven't done much win32 programming before, but I was under the impression that the OBEX functions on the webpage you linked to only worked with CE version 4 and above (CE .NET).
Also, are you aware that Empire will take appx. 5 seconds to recieve an OBEX object? It's not very quick, so I did not consider using it for a remote type function. See some of my previous posts about a solution that could be possible using IR pulse shaping to get the CE device to output the consumer ir signal to emulate the remote.
