When I copy and paste files from explorer (on win2k), emplode always switches the first and last file in the selection. Is this a known bug ?
Yes. Windows does strange things with the ordering. Simple answer, select the first file, shift-select the last file, and then drag the first file into emplode. Usually works.
Also, when I'm dragging and dropping files in a playlist, to change the order, I don't see a way to scroll while dragging. I have to drag a file to the top/bottom, scroll the window, then drag it the rest of the way. am I doing something wrong ?
No. This is a bug. It should be fixed in v1.1
Roger - not necessarily speaking for empeg
roger
