More useful: blow V2 Developer. From the command line discard the current playlist and start the player from scratch with "player -i" (see the FAQ for this). Then reboot, connect with emplode, change one single piece of data, then do a sync.
Sorry but I do not understand what you mean by "blow v2 developer", I searched the FAQ for this and "player -i" with no results. The boot messages look normal but here is what I received when I captured three complete boots with Hyperterminal.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 120001063)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Vcb: 0x4086d000
serial_notify_thread.cpp: 116:@@ N0
serial_notify_thread.cpp: 117:@@ F0x14e0
serial_notify_thread.cpp: 118:@@ TBamboo
serial_notify_thread.cpp: 119:@@ AJoe Satriani
serial_notify_thread.cpp: 120:@@ GOther
serial_notify_thread.cpp: 180:@@ #0 0:00:00
serial_notify_thread.cpp: 170:@@ S0
e000 v1.04
Copying kernel...
Partition check:
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
Partition check:
Freeing unused kernel memo player.cpp : 385:empeg-car 2.00 2003/04/01.
Vcb: 0x4086d000
serial_notify_thread.cpp: 180:@@ #14e0 0:00:00
