Sorry about that, I knew that. I am not thinking straight tonight for some reason. Here is what I came up with...
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (root@genixia.genixia.net) (gcc version 2.95.3 20010315 (release)) #3 Thu Dec 9 20:42:29 EST 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 120001063) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Powerfail is now disabled (1)
Powerfail is now enabled (0)
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Powerfail line current level is 0
empeg state support initialised 0089/88c1 (save to d0004180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
serial_notify_thread.cpp: 116:@@ N0
serial_notify_thread.cpp: 117:@@ F0x950
serial_notify_thread.cpp: 118:@@ THands in the Air
serial_notify_thread.cpp: 119:@@ AJoe Satriani
serial_notify_thread.cpp: 120:@@ GOther
serial_notify_thread.cpp: 180:@@ #0 0:00:00
serial_notify_thread.cpp: 170:@@ S0
serial_notify_thread.cpp: 116:@@ N1
serial_notify_thread.cpp: 117:@@ F0x1090
serial_notify_thread.cpp: 118:@@ TIs There Love in Space
serial_notify_thread.cpp: 180:@@ #1090 0:00:00
serial_notify_thread.cpp: 170:@@ S1
serial_notify_thread.cpp: 180:@@ #1090 0:00:01
serial_notify_thread.cpp: 180:@@ #1090 0:00:02
serial_notify_thread.cpp: 180:@@ #1090 0:00:03
serial_notify_thread.cpp: 136:@@ V1
serial_notify_thread.cpp: 136:@@ V2
serial_notify_thread.cpp: 180:@@ #1090 0:00:04
serial_notify_thread.cpp: 136:@@ V3
serial_notify_thread.cpp: 136:@@ V4
serial_notify_thread.cpp: 180:@@ #1090 0:00:05
serial_notify_thread.cpp: 180:@@ #1090 0:00:06
serial_notify_thread.cpp: 180:@@ #1090 0:00:07
serial_notify_thread.cpp: 180:@@ #1090 0:00:08
e000 v1.04
Copying kernel...
Partition check:
Mounting proc
Vcb: 0x4086d000
serial_notify_thread.cpp: 180:@@ #950 0:00:00
