Just thinking out loud, but couldn't you concatenate several files together? I assume because they're audio books a tiny gap will probably not matter. I assume if you remove any ID3 tags the files would join quite easily. I could do it in linux with the cat command, I assume there must be some windows freeware that would do the same.
