Is this line high when the empeg is sleeping? Hopefully, but probably not. If it isn't, you need a way to prevent the empeg from sleeping when you turn the car off until it's sure you're not at home.
Any chance of delaying the sleeping? Hijack could get the sleep command, look and see if you're home, and shut off or sync depending on what it finds?
Does your amp thump when you start the car with the empeg playing? That'd be the only real downside to delaying the sleeping for me...
Matthew
