#276931 - 05/06/2007 17:58
Re: Aux in recording XM source
Quote: Also from the source code, the kernel device driver for the cs4231a is currently set up for a choice of three sample rates:
static struct { short samplerate; char setup; } samplerates[]={ { 11025, 0x0d }, { 22050, 0x0c }, { 29400, 0x0a }, { 0, 0 } };
The usual rate used for visuals is 29.4KHz, Stereo, 16-bits/channel. Not quite CD-Audio, but sufficiently good for high-quality radio in an automobile.
Working backwards from those three existing values, one determines that the maximum possible sample rate with the existing empeg clock sources is 29.4KHz (clock source 1), or 14.7KHz (clock source 2).
So that's the best it can do -- good enough, I think.
