So sometimes the hard drive works (second log), and sometimes not (first log).
Time to check out the cable and connections.
I unplugged and reconnected the cables but still got the IDE failure tests in the log.
By coincidence I upgraded to hijack 461 from 448 and the IDE failures are gone.I downgraded back to 448 to see if failure notice was still there and it was.Then upgraded back to 461 and they were gone.
Does that mean my drive is good or maybe on its way out?
version 448 log
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v448 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Mar 16 19:43:10 EST 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005c80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED
ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED
ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED
ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED
ide_data_test: wrote 0x0000 read 0xbbc4 -- FAILED
ide_data_test: wrote 0xffff read 0xbbc4 -- FAILED
ide_data_test: wrote 0xaaaa read 0xbbc4 -- FAILED
ide_data_test: wrote 0x5555 read 0xbbc4 -- FAILED
hda: FUJITSU MHR2030AT, ATA DISK drive
hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2
e
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Starting player
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 124 (adjustment 10)
Vcb: 0x407cd000
serial_notify_thread.cpp: 116:@@ N145
serial_notify_thread.cpp: 117:@@ F0x4cb0
serial_notify_thread.cpp: 118:@@ TDaughter
serial_notify_thread.cpp: 119:@@ APearl Jam
serial_notify_thread.cpp: 120:@@ GAlternative
serial_notify_thread.cpp: 180:@@ #4cb0 0:01:17
serial_notify_thread.cpp: 170:@@ S0
version 461 log
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v461 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Jun 8 15:00:28 EDT 2006
c1000000: wrote ffffffff, read e28cc001
empeg state support initialised 0089/88c1 (save to d0005d80).
e
Partition check:
Mounting proc
Starting player
hijack: removed menu entry: "Serial Port Assignment"
Vcb: 0x407cd000
MIKE 80Gb RIO
