got errors on /dev/hdc:
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102286) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: IBM-DJSA-220, ATA DISK drive
hdb: ST9808211A, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: ST9808211A, 76319MB w/8192kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:ee
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin# cd /tmp
empeg:/tmp# ./smartctl.bin -l error /dev/hdc
smartctl version 5.33 [arm-empeg-linux-gnu] Copyright (C) 2002-4 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF READ SMART DATA SECTION ===
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 4
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 3887 hours (161 days + 23 hours)
When the command that caused the error occurred, the device was in a vendor specific state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
51 01 01 00 00 43 a1 Error: UNC, IDNF, AMNF at LBA = 0x01430000 = 21168128
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
40 20 fe f9 6f 00 00 f6 12d+10:16:25.350 READ VERIFY SECTOR(S)
00 20 fd f9 6f 00 00 f6 00:00:43.016 NOP [Reserved subcommand]
00 20 fb f9 6f 00 00 f6 00:00:40.968 NOP [Reserved subcommand]
00 20 f9 f9 6f 00 00 f6 00:00:38.920 NOP [Reserved subcommand]
00 20 f7 f9 6f 00 00 f6 00:00:36.872 NOP [Reserved subcommand]
Error -1 occurred at disk power-on lifetime: 34824 hours (1451 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
19 43 f7 51 01 00 00 Error:
00 19 f7 20 0a 76 0d 2f 00:14:28.352 NOP [Reserved subcommand]
00 18 f7 20 ce 74 0d ef 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 97 74 0d af 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 8e 74 0d 6f 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 31 98 0d 2f 00:14:11.968 NOP [Reserved subcommand]
Error -2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
d0 00 6f 16 f7 51 01
76 cf 6f 16 f7 20 0a 02 22d+22:06:06.861 SEEK [RET-4]
74 cf 2f 16 f7 20 ce 02 22d+16:20:57.485 SEEK [RET-4]
74 cf ef 15 f7 20 97 02 22d+15:20:53.005 SEEK [RET-4]
74 cf af 15 f7 20 8e 02 22d+15:11:03.181 SEEK [RET-4]
74 cf 6f 15 f7 20 87 02 22d+15:03:24.429 SEEK [RET-4]
Error -3 occurred at disk power-on lifetime: 3721 hours (155 days + 1 hours)
When the command that caused the error occurred, the device was active or idle.
40 51 00 d0 ef 12 f7 Error: UNC at LBA = 0x0712efd0 = 118681552
20 00 02 cf ef 12 f7 00 6d+09:37:51.899 READ SECTOR(S)
20 00 02 cf af 12 f7 00 6d+09:37:51.888 READ SECTOR(S)
20 00 02 cf 6f 12 f7 00 6d+09:37:51.883 READ SECTOR(S)
20 00 02 cf 2f 12 f7 00 6d+09:37:51.879 READ SECTOR(S)
20 00 02 cf ef 11 f7 00 6d+09:37:51.873 READ SECTOR(S)
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
00 00 00 43 a1 01 00
d0 00 0d 00 00 40 00 8a 40d+09:21:05.071 [RESERVED]
cf 00 0d 00 00 00 02 81 40d+04:43:38.927 [RESERVED]
cf 00 0d 00 00 00 02 76 40d+04:43:38.863 [RESERVED]
cf 00 0d 00 00 00 02 6f 40d+04:43:38.799 [RESERVED]
cf ff 0c 00 00
