If you really need help to remove the disk tray, then I suggest you might want to send it to somebody else for repair!
Or just undo the four little screws on the outside of the chassis, two on each side, that hold the tray in place.
lol, i hadn't actually looked past the tray, so hadn't looked at how it came off, just didn't wanna go about it the wrong way, much equipment i used to repair had be taken apart in a certain order or you'd end up with all sorts of trouble!
thank you for the replies though, as soon as i finish my year end accounts (what a drag!) i'll test the unit.
thanks again!
Hugh
