i think i'll have to take the board out as i can't get the probes in there. will try shorting the fuse first though.
reading on the fuse is now 12ohm, i'm getting a continuity through it, i think (perhaps i'm still touching the casing or something), probably best if i take the pcb out tomorrow and do it properly.
cheers.
HUgh
edit, now only reading 2.9 - 3ohm ?
edit again...
shorting the fuse doesn't seem to do it
Edited by crazyplums (01/12/2008 14:57)
www.dragon-signs.com
