That program is only for kernels and other flash blobs, not for .upgrade files.
There was a Linux-based upgrader, Upgclient; it was released in the binary (i386) releases of Emptool. For some reason, most likely an oversight, source releases of Emptool didn't contain the source of it. And then the binary releases must have have gone missing when the support pages were rejigged.
However, Upgclient itself was only a thin wrapper around class Upgrader from inside the Emptool source distribution. Probably not much more, in fact, than (untested):
SerialConnection conn("/dev/ttyS0", 115200);
Upgrader upg;
STATUS rc = upg.CheckUpgrade("foo.upgrade");
if (SUCCEEDED(rc)) rc = upg.DoUpgrade(&conn);
if (FAILED(rc)) printf("Upgrade failed: %x\n", rc);
And it still fails on some, but not all, USB serial ports as of the Linux 2.6.2x series of kernels (on the host side) -- it used to work with older kernels.
Upgclient shared enough code with download.c that it too failed on most USB serial ports -- or, at least, on the one that we tried. In fact, I wasn't aware that there were any kernel versions on which USB serial upgrades worked more reliably than others... so far as we could tell, the problem wasn't in the kernel, it was to do with the regrettably low latency required by the player side of the upgrade protocol, latency which was exceeded by the USB overhead in some USB-to-serial implementations.
