How many receivers will you need working in the house? Is the dish on the chimney the oval dish with multiple LNB's connected?
Edit: Is the cable run more than 200"? I think that the SPI1418 is what you might need. I would call them and confirm but I believe this is used to get the signal to the power to the LNB's when the cable is to long. The amps might also need to be used to get the signal back to the receiver.
Edited by Attack (16/04/2009 11:17)
Chad
