Dagnabbit!
But still in beta, I guess.
Found a link to the beta. Also see.
tags: ssd's linux flash beta firmware update OCZs
Peachy. Just grab and use that then. It's dead easy to use, and you should totally skip on any attempt to follow that bloated "Partition magic" nonsense.
Just boot Linux (from a LiveCD or USB stick if necessary), open up a terminal window, and run the updater from the command line. It wants a single argument after the command name: the device path for the drive, which is normally /dev/sda in a single drive system.
Works on pretty much any controller, even AHCI ones. Because it's Linux.
