If that's in the *car* be careful, because the interior of some parked cars gets hot enough to melt hot-melt glue. I know from experience. If it's just indoors, though no worries.
Yes, that's in the camper. I looked at the hot glue sticks and apparently they are of the high temperature 380 F type. I'll take my chances, thanks for the heads up though. At least hot glue isn't as bad to remove as other glues.
I am able to get the Ethernet to work on my gigabit hub but when I plug direct into the server the link light is lit but no data is received. It is an Auto-MDI/X (gigabit) port so I should not need a crossover cable, but I'll try that next. I know the Empeg is a bit finicky with it's 10baseT port.
