I am able to get the Ethernet to work on my gigabit hub but when I plug direct into the server the link light is lit but no data is received. It is an Auto-MDI/X (gigabit) port so I should not need a crossover cable, but I'll try that next. I know the Empeg is a bit finicky with it's 10baseT port.
That's exactly right: Its 10baseT port is finicky. There are documented accounts where doesn't get along with some 10/100 switches, and probably plenty of anecdotal evidence that the same might happen with gigabit switches. You sometimes need to put a cheap-ass hub in between the 'peg and the faster switch to get it to work.
