So your plan is to let the Empeg freeze overnight to twenty-below-zero, then give it a 100-degree boost for a few minutes each morning? Sounds like a prescription for failure to me. That kind of hot/cold/hot pattern is bound to make the hard drive (if not the other components) fail in short order.
Now, if the electric heater warmed it to a more modest 60 degrees, and was left on overnight (so that it never froze), then you might be OK...
-- Tony Fabris -- Empeg #144 --
Caution: Do not look into laser with remaining good eye.
