I am surprised to hear that piping into the FIND command requires admin privileges, I would not have expected that, but stranger things have happened. I would suggest that you doublecheck that that's really the issue, and that it's not perhaps something else that maybe you can work around.
To truly work around admin issues, I'd recommend trying the PowerShell and VBScript variants mentioned elsewhere in the thread. Those might work even without administrative permissions, or can be made to work sans-admin with some additional code.
Another option would be to check for admin privileges before starting the script, and then refuse to run if the privileges aren't there. My favorite way to check for admin privileges in a DOS batch file is this one:
@echo off
:: MAIN PROGRAM START
echo Hello, I am a batch file. I need administrative permissions
echo in order to run correctly. I am going to check for those
echo permissions now.
pause
call :check_Permissions
echo If we have reached this point, it means permissions were
echo good. I am able to continue this batch file.
:: REST OF MAIN PROGRAM GOES HERE
:: MAIN PROGRAM END
goto :VeryEnd
:: SUBROUTINES
:check_Permissions
net session >nul 2>&1
if %errorLevel% NEQ 0 (
Echo ================================================
Echo = ERROR ERROR ERROR ERROR ERROR =
Echo Program is not running with administrative permissions.
Echo:
pause
exit
goto :eof
:VeryEnd
