Here is a dump of what happens when i boot-up:
ls
bash: ,Cls: command not found
bash-2.01# pwd
bash-2.01# ls -la
total 26
drwxr-xr-x 15 0 0 1024 Aug 6 1999 .
drwxr-xr-x 15 0 0 1024 Aug 6 1999 ..
drwxr-xr-x 2 0 0 1024 Aug 6 1999 bin
drwxr-xr-x 2 0 0 1024 Nov 26 1999 dev
drwxr-xr-x 5 0 0 1024 Sep 4 08:48 drive0
drwxr-xr-x 2 0 0 1024 Jun 2 1999 drive1
drwxr-xr-x 4 0 0 1024 Jul 12 1999 empeg
drwxr-xr-x 2 0 0 1024 Jun 19 1999 etc
drwxr-xr-x 2 0 0 1024 Jun 7 1999 lib
drwxr-xr-x 2 0 0 12288 Aug 27 2000 lost+found
drwxr-xr-x 2 0 0 1024 Jun 2 1999 mnt
drwxr-xr-x 2 0 0 1024 Jun 2 1999 proc
drwxr-xr-x 2 0 0 1024 Aug 8 2000 sbin
drwxr-xr-x 2 0 0 1024 Apr 13 1999 tmp
drwxr-xr-x 3 0 0 1024 Jun 1 1999 usr
bash-2.01# w
bash: w: command not found
bash-2.01# who
bash: who: command not found
bash-2.01# man ls
bash: man: command not found
bash-2.01# who
bash-2.01# w
bash-2.01# whois
bash: whois: command not found
bash-2.01# w
bash-2.01#
bash-2.01#
bash-2.01#
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #213 Sat Jun 23 16:35:13 BST 2001
empeg-car player (hardware revision 7, serial number 80000469)
Command line: mem=12m temp=36
Memory: 11008k/12M available (960k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK1016GAP, ATA DISK drive
hda: TOSHIBA MK1016GAP, 9590MB w/0kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:d
5
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k initKernel panic: No init found. Try passing init= option to kernel.
