I have a problem. I selected a bookmark (bookmark 3) that I had not previously set to anything since installing 2.0beta.
The player app crashed and restarted. It now starts up with an empty playlist, but then reboot repeatedly. I tried nuking /dev/hda3 to try and clear out the current running order, but that hasn't helped.
Here is what i get on the serial port when it boots:
empeg-car v0.04 19990121 (altman@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux........................ done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #125 Wed Oct 17 16:01:18 BST 2001
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00047)
Command line: mem=8m
Memory: 7324k/8M available (580k code, 20k reserved, 264k data, 4k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is 20706d65 'emp '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0004400).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: TOSHIBA MK1011GAV, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
hda: TOSHIBA MK1011GAV, 9590MB w/0kB Cache, CHS=19485/16/63
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initI see this is a developer image!
Mounting proc
Tried to mount /dev/hdc4 but got error 15
No secondary hard disStarting player
Using non-standard cache size 31 (adjustment 12)
empeg-car 2.00-beta3 2001/10/17.
Prolux 4 empeg car - 1.860 Oct 17 2001
Vcb: 0x401fe000
E !! local_audio_component.cpp 543: Invalid tune information for FID 0x0. This i
s bad.
player(19): memory violation at pc=0x0208ead0, lr=0x020ad258 (bad address=0x0000
0000, code 2)
pc : [<0208ead0>] lr : [<020ad258>]
sp : be3ffb4c ip : be3ffb70 fp : be3ffb6c
r10: 00000000 r9 : 00000000 r8 : 00000000
r7 : 00000000 r6 : 021c2da4 r5 : 00000000 r4 : 021c2e5c
r3 : ffffffff r2 : 00000000 r1 : 021c2db4 r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C83B517D Table: C83B517D DAC: 00000015
Function entered at [<0208eabc>] from [<020ad258>]
r8 = 021C2DB4 r7 = 00000000 r6 = 021C2DA4 r5 = 021A40C0
r4 = 021C2E5C
Function entered at [<020ad224>] from [<02033e58>]
r10 = 00000000 r9 = 00000001 r8 = 021C2D88 r7 = FFFFFFFF
r6 = 021A10D8 r5 = 021A40C0 r4 = 021C2E5C
Function entered at [<02033de4>] from [<0208a0ac>]
r8 = 00000000 r7 = 02192710 r6 = 0219C08C r5 = 00000001
r4 = 0219BFF8
Function entered at [<0208a054>] from [<0208acf0>]
r6 = BE3FFC04 r5 = 02192798 r4 = 0216E8F8
Function entered at [<0208acbc>] from [<02083fb8>]
r6 = FFFFFFFF r5 = 00000000 r4 = BE3FFC04
Function entered at [<02083ed4>] from [<02084b88>]
r10 = BE3FFD30 r8 = 02192710 r7 = 021927F0 r6 = 00000001
r5 = 021D8BF8 r4 = 021D8BF8
Function entered at [<0208409c>] from [<020861b0>]
r10 = 00000000 r9 = BE3FFD2C r8 = 02192710 r7 = 021927F0
r6 = 00000001 r5 = 021D8BF8 r4 = 021D8BF8
Function entered at [<02085ea4>] from [<020ca4fc>]
r10 = 020CA444 r9 = 02192710 r8 = 00002C0C r7 = 00000080
r6 = 0000000C r5 = 02192710 r4 = BE3FFD64
Function entered at [<020ca444>] from [<020d16f4>]
r5 = 02192728 r4 = BE3FFE40
Function entered at [<020d162c>] from [<0210c63c>]
r4 = 00000000
Function entered at [<0210ae30>] from [<020d1470>]
r8 = 0216DA8C r7 = 0216DA78 r6 = 020CA444 r5 = 00000003
r4 = 00000001
Function entered at [<020d13c0>] from [<0210c63c>]
r5 = 00000000 r4 = 00000000
Function entered at [] from [<00000000>]
Function entered at [] from []
Function entered at [<23a0fff3>] from [<23a0ffff>]
Unable to handle kernel paging request at virtual address 23a0fff7
memmap = C83B4000, pgd = c07b4000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [] lr : []
sp : c03cbf44 ip : c03cbf00 fp : c03cbf90
r10: 00000002 r9 : c016a0e0 r8 : 0000000c
r7 : 00000000 r6 : 23a0fff3 r5 : 23a0ffff r4 : e3a02000
r3 : 60000013 r2 : c009e1e4 r1 : 00000001 r0 : e3a01ff0
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 19, stackpage=c03cb000)
Stack:
c03cbf20: c0019630 c0089f0c 600000
13
c03cbf40: ffffffff c016a0f8 c01696a0 c03ca000 c03cbfb8 00000000 c0011924 020ad2
58
c03cbf60: 00000000 00000002 c03cbfb8 0000000f 00000000 00000000 00000002 000000
00
c03cbf80: 00000000 c03cbfb4 c03cbf94 c0011e5c c00116d4 c009c978 00000000 021c2d
a4
c03cbfa0: 00000000 00000000 00000000 c03cbfb8 c000a008 c0011d84 00000000 021c2d
b4
c03cbfc0: 00000000 ffffffff 021c2e5c 00000000 021c2da4 00000000 00000000 000000
00
c03cbfe0: 00000000 be3ffb6c be3ffb70 be3ffb4c 020ad258 0208ead0 20000010 ffffff
ff
Backtrace:
r10 = 00000000 r9 = 00000000 r8 = 00000002 r7 = 00000000
r6 = 00000000 r5 = 0000000F r4 = C03CBFB8
r8 = 00000000 r7 = 00000000 r6 = 021C2DA4 r5 = 00000000
r4 = C009C978
Code: ebfe3d44 e2440010 (e5961004) e1a035a1 e59f20cc
Restored terminal settings
No secondary hard disk
Abnormal player termination
Player received signal 11
Starting player
Vcb: 0x401fe000
E !! local_audio_component.cpp 543: Invalplayer(32): memory violation at pc=0x02
08ead0, lr=0x020ad258 (bad address=0x00000000, code 2)
id tune ipc : [<0208ead0>] lr : [<020ad258>]
nformatior10: 00000000 r9 : 00000000 r8 : 00000000
n for FIDr7 : 00000000 r6 : 021c2da4 r5 : 00000000 r4 : 021c2e5c
0x0. This isr3 : ffffffff r2 : 00000000 r1 : 021c2db4 r0 : 00000000
bad.
r4 = 021C2E5C
r4 = 0219BFF8
r4 = 00000000
r4 = 00000001
Function entered at [<02171ec8>] from [<020d4e94>]
__
Unit serial number 47 (was 330 in the queue)...
